Question about Electronics - Others
A friend gave me some used 100MB Zip disks he had received from someone else. Before giving them to the person who gave them to me, the original owner bulk-erased the disks. None of the disks can be used now because the FORMAT command fails. Any hope of salvaging these disks?
  • 53 Answers
Try partition magic 8.0. Good Software!
Posted on Feb 11, 2010
Where can I get appropriate USB cable, i.e, parallel to USB not the original parallel to parallel?
So you have an old Zip drive with a parallel port? You can't connect that using USB. Nor can you connect that to a computer running any version of Windows newer than XP.
Two options:
1) Buy a USB version of the Zip drive and use it to read your disks. Used, USB Zip drives seem to run around $35 or so.
2) Get a computer using an old version of Windows. If it doesn't have a parallel port, you should be able to buy a PCI card with a parallel port on it.
Once you're able to access the files, copy them onto a USB thumb drive. For $10, you can get a 32 GB USB drive, which should hold everything from at least 320 Zip disks.
Sep 23, 2015 | Iomega Zip 100MB (31714) External ZIP...
How to remove manually a zip disk from driver? Iomega Zip 100MB (31714) External ZIP Drive
Hello, 1st what type of system is it ?, 2nd What type of cables do you have for this Drive ?, 3rd what happened to the power adapter ?
4th are you using Windows, What version, or Mac, What version ?
I'm Sorry, but I need more info than you gave me..
Jul 10, 2014 | Iomega Zip 100MB (31714) External ZIP...
Unable to see data on Zip Disks
You are saying that you used zip drive in 1998. i want to tell you that in 1998 the processors were of old versions.therefore,you need to install windows 95,only then you will be able to retrieve your data.
As the only reason to be found is that you used win 95 in 1998,now you are using win xp,the files you stored on your drive were only supported by win 95,hence you need to install win 95.
THANK YOU. hope you get a well experience on www.fixya.com
Oct 10, 2009 | Iomega Zip 100MB (31714) External ZIP...
Can't read specific Zip 100MB Diskette
Its probably a bad disk. The only way I have been able to fix these is to First launch disk utility THEN put the disk in. THEN run the utility. You have to do it in this order. The key thing here is utility has to be running first and then insert the disk "HOT"
Hope this helps!
Jan 22, 2009 | Iomega Zip 100MB (31714) External ZIP...
100mb zip disk not reading
These are pre-formatted and servoed at the factory.
Awhile back I was researching the 'Click of death" fault and found a guy in Belgium or Germany that coded a repair program for bad disks. Googlee for it
sometimes when it formats, it hoses the servo information (which the drive uses to keep track of things) and the disk becomes useless. This is why I stopped using ZIP disks and won't even buy a drive when I see them for 9.99 ;-)
Jan 16, 2009 | Iomega Zip 100MB (31714) External ZIP...
Iomega 100MB zip drive
i think it is damaged. because of the bad sectors . try to use third party recovery app
Jul 16, 2017 | Iomega 100MB IDE Black Zip Drive...
Cant figure out how to use zip drive when i have added a pass to my zip dr 250
1. Insert a blank disk into the zip drive
2. Give this disk a password (it can be any password, as long as you
remember it)
3. Using the Ioega toolset, set the zip drive's sleep time to a large
value (such as 1 minute)
4. Wait a while until the drive "spins down". You will hear the drive
stop spinning.
5. Take a pin or a straighten paper clip and stick it into a hole in
the back of the Zip drive. This will manually eject the blank disk.
6. Insert the disk you want to access (the one you don't know the
password to)
7. now use the IoMega toolset to remove the password. When prompted
for the password use the password from step (2).
This is just a word of warning in case you store any important information like I used to on zip disks. Perhaps move to a more secure medium.
May 09, 2008 | Iomega Zip 100MB (31714) External ZIP...
Disc won't read
what type of zip disk are you trying to read? if it is larger than 100MB, the drive will not be able to read it.
can you read other disks? can you see the drive in my computer?
what operating system are you using, and how does does this drive connect to the computer? USB? Firewire?
Mar 29, 2008 | Iomega Zip 100MB (31714) External ZIP...
Electronics - Others Logo
43 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
