Question about Dishwashers
I have a Kenmore Elite Dishwasher Model 665.172824000. We think it stopped part way throught the dry cycle. The green "Clean" light has been flashing since in 7 flash cycles non stop. I tried pushing the Cancel button, it starts the drain pump then stops and we are back to where we started. I tried to start a new wash cycle but when I close the door and push the start button it just give 3 quick red flashes and then nothing but the green clean light flashing again. I shut the breaker off for a while hoping the unit may reset but that did not help.
  • 619 Answers
So sorry but the partsdirect site for sears locked down my computer. Check where the drain hose connects to your pump and see if there is a small device the hose connects to that has 2 wires going to it. If it does unplug the wires, turn power off, wait 1 minute and turn power back on and see if it works with this disconnected. If it does you will need to replace this. It is like a sensor that says there is too much debris. Stupid part that was totally unnecessary in the first place. Sorry about the inconvenience.
Posted on Feb 07, 2010
  • 93 Answers
SOURCE: kenmore elite dishwasher 665 15962990
Hold down the "HEATED DRY" button for 4 seconds to unlock.
Try to press these botton in sequence,Heated Wash, Heated Dry, Heated Wash, Heated Dry.release your hand, the unit will go into diagnostic mode. that is all leds will ON for a few seconds,and start normal operations.
If that does not work, you might need to check the electronic control board if the ribbon is seated properly.
Finally solution, is to change the electronic control board.
Posted on Jul 27, 2008
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
SOURCE: no power suddenly on the control panel... kenmore
Kenmore dishwashers should be recalled!! Their poorly designed computer circuit boards are all malfunctioning around 15 months. Look on the inside top of your door. Do you see a instructions? There should be some about your Heat Dry button and holding it down for 4 seconds to reset your computer board. Read and try it first. It's like rebooting a computer.
Posted on Jan 10, 2010
Testimonial: "This just confirms what I've already discovered."
SOURCE: Kenmore Elite dishwasher model 665 touchpad buttons falling off
WE HAVE THE SAME PROBLEM. DID YOU FIND A FIX FOR YOURS?
Posted on Mar 27, 2010
  • 523 Answers
SOURCE: Dishwasher will not operate. Kenmore 665
control panel
Posted on Jun 01, 2010
How to reset Kenmore Elite 665-16572202 Dishwasher...clean light blinks 7 times pauses then repeats. My model does not have a Heated Dry button it has an Air Dry button.
Here's the key sequence(s) to use, depending on how your keys are labeled:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
This will start the diagnostic cycle. Let the dishwasher run for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error. Please note, that this clears the error, but if you haven't found the cause (water-not-heating error), the condition will come right back the next time you run the dishwasher.
Jan 19, 2015 | Kenmore Dishwashers
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
Kenmore elite dishwasher stops in mid cycle green clean light flashes 8 times pauses and then flashes one more time
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. see the diagram
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control.
May 23, 2013 | Kenmore Dishwashers
Our Kenmore Elite Dishwasher has a blinking green light next to the clean cycle. It won't reset. We changed the motor and this has been going on ever since. Do you know what we need to do to fix it....
Hello
Blinking green light can be reset by following two buttons in sequence: press HIGH TEMP WASH-HEATED DRY buttons in sequence around 3-4 times so that the control reset itself. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Kenmore Elite 45986 Front Load Washer
Clean cycle light is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 22, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
My kenmore elite ultrawash dishwasher, model # 665.16289402, will not start. The green clean light keeps blinking and when you go to push start after selecting which wash program it does nothing.
youll need to enter a diagnistic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, htne press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Dec 24, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
I had the same problem when I bought it and it just happened again; the problem is solved by ressting the control panel: Hi Temp ---> Heated Dry two or three times. It kind of goes into a testing cycle and the clean blinking light goes off.
Dec 08, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
106 people viewed this question
Top Dishwashers Experts
