Question about KitchenAid KSCS23INSS Stainless Steel Side by Side Refrigerator
After replacing water filter in my KitchenAid refrigerator, how do I turn off the filter light on the exterior of the freezer door?
  • 35 Answers
SOURCE: KitchenAid Superba KSCS25FKSS00 SideXSide Refrigerator
Replace the ERC board.
Posted on Dec 09, 2007
aborcass
  • 2651 Answers
SOURCE: ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
Posted on Mar 25, 2008
  • 1314 Answers
SOURCE: Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
Posted on May 13, 2008
SOURCE: Kitchenaid fridge #KSCS25INSS hot door frame
how to change the waterhose my Kitchenaid fridge #KSCS25INSS
Posted on Sep 12, 2009
  • 12 Answers
SOURCE: How do you replace the water filter on a
under the freezer door there is a nob like thing. turn it and pull on it. instead of replacing it, rinse it out under runing tap water and put it back were you removed it from and push the fridge light botton 5X in a row
Posted on Oct 19, 2009
KitchenAid KBFA25ERSS01 I replaced the water
if its computerized make sure someone didnt turn icemaker off check to make sure its in all the way
Oct 27, 2013 | KitchenAid KBFS25EVMS Stainless Steel...
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
How do you turn off replace filter light on freezer door panel?
If you're referring to the water filter indicator light that goes from green to yellow to red when it's time to change the filter, you press and hold the WATER FILTER button down until it blinks 5 times. The indicator light will change from red to green when the system is reset.
Feb 13, 2011 | KitchenAid KSCS25FKSS Side by Side...
I need to replace the filter. I have the filter but directions say to replace at bottom of refrigerator -- I have done it before and think it is somewhere in the middle of the freezer door. Help!
if this is the water dispenser filter
It is on the left side behind the bottom grille.
you turn it and, pull out.
be sure the water is off to the refrigerator before you replace it.
Jul 31, 2010 | KitchenAid Refrigerators
How do you replace the water filter on a Kitchenaid Superba refrigerator. I can find the filter.
Oct 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Discoloration on floor in front of the refrigerator.
Filter is loose or gasket is bad >Have you replaced the filter?Other possible leak is plastic fill line at btm of freezer door.Tighten or replace
Jun 20, 2009 | KitchenAid KSCS25FKSS Side by Side...
Icemaker is not making ice.
check water valve /filter it maybe the ice maker
Apr 02, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Change filter?
filter is in kickplate under freezer door and it should turn counter clockwise then pull straight out then replace please rate me
Jan 04, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice won't dispense, no power to water light
Mar 21, 2008 | KitchenAid (KSRD22FKST) Side by Side...
KitchenAid KSCS23INSS Stainless Steel Side by Side Refrigerator Logo
35 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
