Question about Frigidaire FRS23F4C Side by Side Refrigerator
Keeps frying defrost boards.
Hi I have a frigidaire model # FRS23F4CW3 quit cooling suddenly and i thought it might have been my 3n1 capacitor so i bought a new one and put it on still no cooling so i talked to a repairman down the road and i told him what it was doing. Internal fan blowing but compressor and condensing fan not working and he said it sounds like it's stuck in defrost and it was probably my board so i went home looked for the board, found the board, sure enough it was burnt on 2 pins 4&6 - "compressor out and freezer cold control". this board p/n is 241508001 by the way. So i went out and paid $70 for a new one and installed it. it worked great for about 2 minutes and then it fried the brand new one. If anyone can help me please do so. I think i may have a short or something. thanks
    President:
  • Frigidaire Master
  • 2,651 Answers
I would look behind rear wall of freezer, lower compartment, sounds like a short in the defrost circuit. remove the panel inside freezer and check for possible broken wire s
Posted on Feb 22, 2008
Frigidaire model number FRS6R5EMB8 Not cooling
Feel the top of the compressor and tell me what you feel
Oct 09, 2015 | Frigidaire Refrigerators
What stop the compressor, water spilled on the freezer fan though the vent by the ice maker. help
Most likely the=> 5303918476 Defrost Control Board will need to be replaced. This board can be found inside the control panel inside the fresh food compartment. Unplug power and lets examine the board. Here is another source for the board 5303918476 Defrost Control Board Here is a photo of the inside of the control panel HERE and item location 23 is that board. I am here should you have questions, Sea Breeze
Soemtimes the defrost control board will show signs of failure with burn marks and heat damage but not always. It is likely this board is the problem and in some cases the start relay and run capacitor can cause these same symptons.
Jul 03, 2013 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire upright frostfree freezer keeps icing up, needing to be defrosted. whats wrong with it?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Frigidaire 20.3 cu. ft. Upright Freezer...
It has quit cooling and the microprocessor control keeps going back to defrost our email is uccalvary@bellsouth.net
That is probably a bad sensor ...but it could be the board...
only hands on testing can begin to tell what is causing it to go into defrost prematurely...
heatman101
Aug 30, 2010 | Traulsen G20010 Commercial Refrigerator
My frigidaire refrigerator keeps defrosting on the freezer side
sounds like a bad defrost timer
or depending on the model a bad
electronic or adaptive defrost board
Oct 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refridge quit cooling suddenly inboth freezer
That could be a broad range of possibilities. The defrost timer, adaptive defrost board,compressor start relay, compressor start capacitor or a mother board. Would you happen to have the model number so I can narrow down those possibilities? If you pull away from wall remove cover over the compressor and then unplug. Touch the compressor and let me know if cool, warm or too hot to touch. Thanks, Sea Breeze
Aug 19, 2009 | Kenmore Refrigerators
My Frigidaire PLMV 169 DCD has stopped working. The turn table rotates slowly, lights are lit but no cooking being done. The fan is off and no sound at all from within. What could have happened?
HI, have the power sector tested. test the HV capacitor for its operational value. this may be the actual issue but, testing is needed to confirm. there is a running diode as well on the noise filter board. have it tested as well. replace both componets if found to be defective.
Jun 28, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidaire defrost problems
if the heater and thermostat are good and wired correctly then the only other thing would be the defrost timer board.
Jun 29, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Frigidaire FRS23F4C Side by Side Refrigerator Logo
232 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
