Question about Samsung YP-U3 MP3 Player
Side light is not turning off and i can't switch the player on
I put the player in the usb port and the light came on but after a little while i realised it was not turning off so i took the player out and tried to switch it on. that didn't work and the light's still not turning off
  • Anonymous Apr 03, 2008
    i put the player in the usb port and the light came on but after a little while i realised it was not turning off so i took the player out and tried to switch it on. that didn't work and the light's still not turning off
Posted on Apr 03, 2008
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Some things to check for when your player does not act like its taking a charge.
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
Hello how come my rca mp3 player doesnt charge when i plug it in my computer
You most likely have not turned the player off. Connect to your USB port, switch on the player using the slide switch on the side. The screen will light up. To make the battery charge, turn off the player by holding down the 'play' button until you get the bye-bye message. A couple of seconds later the screen will go black and the battery will start charging. Leave overnight if the battery is dead flat.
Mar 17, 2010 | RCA Audio Players & Recorders
How to use USB port
Hi
I know this was posted a while ago but i can answer your question.
Insert your USB drive or SD Card and turn on your dvd player. Grab your remote and press 'Switch' on the bottom left of the control. Select USB, Card or DVD from the list and hit Enter. Another little pop up will appear showing you that a device has been inserted. Just hit Enter again and it will display the contents. Select your file and press Enter or Play.
To switch back to the DVD you can either use the 'switch function again or just turn off, remove your device and turn back on again.
Cheers
Mar 26, 2009 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
Laser mini mp3 player 4GB
I found that MP3 players need to be plugged into a USB PORT not a USB HUB. Good Luck!
Mar 19, 2009 | Laser MVP-1G MP3 Player
My Onyx Portable MP3 player won't turn on
The most common cause of this problem is the slider switch on the side being in the down(off) position.
Slide the switch to the on position and hold the play button for several seconds and it will probably turn on.
Dec 28, 2008 | Mach Speed TRIO Onyx MP3 Player
H340 i river
Horizontal lightning blot = OK = the battery is already fully charged
Vertical lightning blot = enough power for charging not getting to player - your USB port may be less than 2.0, or may be malfunctioning for some reason - try a different uSB port first - if still the same result, go into the Device Manager and make sure there is not a yellow exclamation mark by the USB port.
Use the wall charger if it will no longer charge via USB.
-Tha Mp3 Doctor
Jun 13, 2008 | iRiver H340 MP3 Player
Disney mix stick
Be sure to try all the USB ports on your computer. The player will use all 500 milliamps that a USB port can provide to charge its battery. In most cases the back ports will provide all 500 milliamps to the player so try that. If you're using a USB hub then make sure you're connecting the player directly to the back of the computer instead.
If that doesn't work then take them back for a replacement or contact Digital Blue customer service for warranty replacement.
Mar 17, 2008 | Disney Mickey Digital Mix Sticks MP3...
Charging the coby clip 1gb m582 mp3 player
the manual says something about turning the player on when inserted into the usb port so it  can charge
Jan 06, 2008 | Coby MP-C582 MP3 Player
2 problems with my coby mp3 player
I have the same problem just bought the thing yesterday and it won't charge I downloaded music yesterday and charged it, now it isn't recognized by the computer.
Went thru the whole troubleshooting chart and nothing happened, I did email techsupport but haven't heard anything. I guess I'll take the thing back and get it replaced.
Jan 03, 2008 | Coby MP-C582 MP3 Player
New battery and still wont work...
There is a little switch on the bottom of the Gigabeat (just to the left of the mini usb port on it).
Put a pin into the little dimple in the switch and make sure its pushed all the way over towards the USB port.
Sep 28, 2007 | Toshiba Gigabeat S30 MP3 Player
Samsung YP-U3 MP3 Player Logo
78 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
