Question about Dell Dimension E521 PC Desktop
Dell Dimension E521 BSOD Windows Vista no safe mode or repair mode Stop 0x0000c1f5
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more detailed description of the problem. Also, did you make any hardware or software changes in your computer like added or removed any programs or important operating system files.
Thanks for using FixYa.
Posted on Feb 15, 2010
Safe startup programs to disable?
Press F8 during boot to access Safe Mode.
To disable startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 06, 2012 | Dell Dimension E521 Athlon 64 X2 3600...
DELL DIMENSION E521 BSOD???? HELP?!
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 06, 2012 | Dell Dimension E521 PC Desktop
My dell dimmension e521 won't load to window screen.....i can't even get in to safe mode.......help
How did you try to get to safe mode. Have to tap F8 continuously for a while as soon as pc starts to boot. Holding key down might not work so it's better if you can keep tapping key quickly. If you have tried several times and can't get it to start in safe mode windows will normally put up an error screen to say windows didn't start properly with a few options. If you see this screen select last known good configuration and it might start to load windows normally if you are lucky.
Jan 01, 2011 | Dell Dimension E521 PC Desktop
My dell dimension e521 will only start up in safe mode ther was a power outage since then i can not use the computer,
Probably corrupted some importand windows system files.
Boot in safe mode, and do a system restore.
Start, Accesories, System Tools, System Restore..
Choose a restore date. The last one in there will likely do it.
Allow it to do it's thing.. Should be all good. Cross your fingers..
Dec 10, 2010 | Dell Dimension E521 PC Desktop
Windows vista will not start, was unable to download updates for windows
Upon starting keep hitting the F8 key and a window will appear to get into the repair mode. Use the subject that will fit your needs but do not use the standard mode if it says start in the normal mode. It will do the repairs automaticly for you
Jun 25, 2010 | Dell Dimension E521 PC Desktop
My dell pc only gives me a blue screen and i cant log onto windows vista i have a error code STOP : 0x0000c1F5 can you help
I found this article that relates to your specific problem. It looks like there is a hotfix.
http://support.microsoft.com/kb/946084
Nov 21, 2009 | Dell Dimension 4600 PC Desktop
Dell Dimension C521 w/Vista will not boot OS.
There is no way around this you need to get your OS from Dell and reload.
Sorry.
Feb 19, 2009 | Dell Dimension C521 PC Desktop
Windows startup error
I lost my password on windows xp, how can I get back on the administrator screen instead of guest screen.
Feb 17, 2008 | Computers & Internet
Dell Dimension E521 PC Desktop Logo
67 people viewed this question
Alun Cox
