Question about Canon PowerShot S1 IS Digital Camera
When we start the camera ,the screen is blank(black) and shows "e16" in the left bottom
  • 641 Answers
SOURCE: Screen is showing E18
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix you problem. In any case it could not make it worse Good luck!
Posted on Aug 10, 2007
sheiba19
SOURCE: Lens Error
I had the same problem and fortunately for me it was simple to fix. I gave it a little push & twist on the lens and to my surprise the lens retracted and now the camera works fine. Good Luck!
Posted on Aug 22, 2007
t00nz
  • 4738 Answers
SOURCE: E 18 message
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 04, 2009
aardvark42
  • 5 Answers
SOURCE: the camera was dropped by my son, which happened before, when turned on the canon logo shows then the screen is black. An error message in the bottome left says E1b or E18. Help!! thanks
Here is some information on the E18 error: http://www.e18error.com
A repair guide (suggestions) http://www.e18error.com/repair.html
Forum for users with the same problem http://www.e18error.com/posts/index.php
Posted on May 21, 2009
  • 668 Answers
SOURCE: the camera does shut off
E16 error means that the lens mechanism is jammed, and the lens cannot extend/retract.
Follow the steps provided below to solve this problem.
Remove the batteries from the camera, wait for 10 minutes, then put them back in and turn the camera on. If this does not work then try the compressed air. With a fine tip blow off the gun and dry compressed air set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function as fine. If this also does not work then you need to force the lens out.
Hope this helps.
Shane
Posted on Mar 28, 2011
I dropped my kodak easyshare m530 and now the screen is blank
Hello Zeidy, This is BAD NEWS no matter how you look at it, the repairs will exceed the price of a new camera.
Dec 01, 2012 | Kodak EasyShare M530 Digital Camera
Screen is black or blank. Displays still show but
LCD screen is damaged and replacing the lens is the solution for your camera.
May 24, 2010 | Panasonic Lumix DMC-LZ1 Digital Camera
E16-e19
E16 says that remaining ink is unknown, E19 is empty. You can press resume to print, but you should replace the ink.
Jul 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Kodak camera shows me a blank/black screen
You have a bad CCD imager. Find a repair shop that can strip a CCD from a camera with a bad lens. This is the least costly repair.
Jul 02, 2009 | Kodak EasyShare P850 Digital Camera
Canon A630 screen black
Turns out my husband must have pressed a button by accident. The bottom left button says "disp" for display. Pressing that fixed the screen!
Jun 24, 2009 | Canon PowerShot A630 Digital Camera
Why an ei6 error msg on canona630 suddenly after just taking pix?
The E16 error is a circuit board problem and is not user fixable. It needs to go to a Canon service facility. Try to get it fixed under warranty, if possible. If not, get an estimate before repairing, as price may be prohibitive. Weigh repair costs against replacing with a new camera.
May 30, 2009 | Canon PowerShot A550 Digital Camera
The camera was dropped by my son, which happened before, when turned on the canon logo shows then the screen is black. An error message in the bottome left says E1b or E18. Help!! thanks
May 21, 2009 | Canon Cameras
LCD SCREEN IS DAMAGED IT AS A BLACK CIRCLE IN THE MIDDLE OF THE SCREEN ONE IN THE BOTTOM LEFT HAND CORNER NO IMAGES SHOW UP ON IT IT IS JUST BLANK
there is only one way out, you need to replace the lcd screen (only screen)
there is no chance of repair in your old screen
Nov 11, 2008 | Cameras
Trouble with lens and blank screen
http://www.e18error.com/repair.htmls shows pictures of how to take apart a similar camera.
need an online translator from Bulgarian.
Canon Repair is out of the question.
Dec 09, 2007 | Canon PowerShot S30 Digital Camera
HP Pavilion dv6337us screen problem
Place you cursor on a blank spot on the black area, Hold the left mouse/touchpad button down and drag it back down to the bottom of the screen. That should get you back to where you want things to be.
If that fixes it, please return here to rank this as solved. If it doesn't, let me know and we'll see what else we can come up with. ;o)
Ron-
Nov 08, 2007 | HP Pavilion dv1000 Notebook
Canon PowerShot S1 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
