Bang and Olufsen - Beogram RX 2 turntable. Platter is out of level, album rubs on base frame and drags. Just tried twice with a ''professional'' repair service to correct - no luck.
Same problem. Did this work?
Posted on Feb 18, 2013
2 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: Bang and Olufsen Turntable will not platter will not spin
Normally on the RX-2 there are only 3 transit screws but if they are stuck you might need to gently try to lift them while turning anti clockwise. You can do this with a Steel Ruler and yoiu may have to use a little bit of force as some people torque them down tight. As for manuals and service manuals - they are rare!
Posted on Oct 07, 2009
My bang and olufsen 7002 wont select the phono stage
The Phono/Aux input has a slider switch to the left of it to choose whether to make it a regular line-in jack or to utilize the phono stage. The ground terminal is just above the jacks. The Beogram 4002 likely has a muting circuit that's in effect when the tonearm is in the lift position, which would explain the lack of hum til the stylus lowered to the record.
May 19, 2015 | Bang and Olufsen Audio Players & Recorders
I have a Bang&Olufsen Beogram
Similar to most Beogram 1800, the RX 2 featured record sizing by weight. When Play was selected, the centre part of the platter would raise gently, with only just enough force to lift a 45RPM single. An LP would be too heavy to lift, so the mechanism would set itself to 45RPM and 18cm if the record lifted, 33RPM and 30cm if it did not. The speed control keys could then be used to override the choice for non-standard records. The parts could also detect if a record was not present, and prevent the turntable being activated
Just put lp on and it should work
Jul 08, 2008 | Audio Players & Recorders
Beogram 1100 not turning
If your platter runs off of a belt then the belt would need to be replaced after many years especially if its been in storage. Another thing is, if you can see the motor with the flywheel on it, it is a good idea to spray just a little WD-40 down the shaft to free up the motor and just let it run for several hours after the table was sitting dormant for so long.
Apr 26, 2014 | Audio Players & Recorders
Beocenter 7007 lights but no power
It is likely the audio output ic has failed, check the speaker wires for shorts, if okay! you will need a professional to take care of this.
Mar 21, 2012 | Bang and Olufsen Beocenter 9300 Shelf...
B & O Beocenter 4600: The record player won't spin
the turntable wont spin unless a record is on the platter,the centre 45 adapter weighs the record to determine 33/45.try pressing 33 and turning the platter by hand(remove expensive cartridge first!),if it starts to spin the motor leaf switch is at fault.is the belt in position.the motor pulley can become unglued.
Jan 08, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
Oct 07, 2009 | Audio Players & Recorders
B&O Beogram 2000 turntable arm won't go down
Check to see if there is a cueing lever that is holding the arm in the up position.  If no cueing lever and it has worked recently then something has happened to the changer mechanism.  Open the bottom and look to see if there is an obvious problem like something stuck or broken.  You may be able to make the mechanism go through its cycle slowly by rotating the platter with your  hand so you can see where it is getting stuck.
May 30, 2009 | Bang and Olufsen Beosound 2000 Shelf...
Cannot unlock the turntable after shipment
Your submission is incomplete. Please resubmit.
Dec 29, 2008 | Audio Players & Recorders
Beogram 1800 wont play the record!!
possibly some kind of obstruction inside.
I had something similar with my turntable, and it had a dirt dauber nest inside it!
no kidding.
Dec 03, 2008 | Audio Players & Recorders
770 people viewed this question
 Grubhead
Grubhead
