Question about Canon PIXMA IP5200 InkJet Photo Printer
My yellow ink light flashing despite ink in cartridge. New cartridge does not solve this problem
  • 4,041 Answers
Hi not know if it work for you but you can try
re: How do I reset the ink level? e: How do I reset the ink level?
1) Disconnect the printer's power outlet
2) Press and hold the power button while connecting the power outlet back. 3) While still holding down the power button, press the reset button twice.(red circle with a triangle) 4) Release the power button
The printer takes about 10 seconds to show the number 0. (at this step, i press and hold the reset button twice, each time i press and hold is about 5 seconds. then i'm able to continue to the next step) 5) Press + to change the value from 0 to 1. 6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point feed the printer with paper. 7) Press the power button twice and the printer will print a some stuff (if this page doesn't print by itself, press the "color" button once and the test page will print). Don't worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero. (at this step, i have to wait for about two minutes or more then the printer automatically start print the document mentioned.) 8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet. 9) Close the lid and turn on the printer. 10) Refill cartridges and place them back in their nice little abode in the printer. 11) close the printer cover. Wait for 2 mins. (for my printer, i didnt wait for two minutes, the light immediately disappeared) The amber light beside the black ink and color ink will have disappeared.
Also if you take printouts now you will no longer get the ink low warning.If you check the ink status
it will show that the cartridge is full !!! THe ink level has been reset successfully."
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
MFC 240C will not print yellow despite new cartridge
check if plastic cover on ink cartridge . may need a lot of cleaning of print heads may need to get cleaning alcohol and a cloth and clean print head physically
Dec 24, 2014 | Brother Multi-Function Center MFC-240C...
Have two Brother DCP-145C printers and use compatible inks. Now the yellow won't print in either machine. Despite trying cleaning cycles and replacing the yellow cartridges, the test print will not show...
100% you need to replace the print head,in the future use only original cartrige brother not refill or compatible cartridge.If you want to replace the print head you need to take care is difficult to change the print head,you must to unzip the all printer.If a have been useful please give me a vote.
Mar 22, 2011 | Brother DCP 130C All-In-One InkJet Printer
HP Business Ink jet 1200. Yellow cartridge lite is on. Changed cartridge, but lite is still on,
Ink cartridge lights: Black, Blue, Magenta, Yellow
When light is on - ink is low (below 25%)
When light is flashing - out of ink - printer stops - replace cartridge
To get a printer status / configuration report press the info button (to the left of the on button)
Oct 07, 2010 | HP Inkjet 1200dn Printer
R1800 yellow ink out light on constantly
Do replacemen procedure from status monitor (How to..). When asked to replace ink tank, unplug and plug again all of ink tank.
Aug 18, 2009 | Epson Stylus Photo R200 InkJet Printer
Changing color cartridge on my epson stylus color 980 printer.
If you need to replace an ink cartridge in your printer, please follow the instructions below:
To confirm which ink cartridge requires replacement, please use the printer's control panel (there is a black ink out indicator, as well as a color ink out indicator ), or the Status Monitor in your computer.
Red light flashing - Low ink
Red light solid - Out of ink
1. Open the printer cover and press the INK (Cleaning) button for 3 seconds. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8 (to move printhead over to color (if black was replaced first) press the cleaning button once).
8. Press the INK (Cleaning) button once, and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
May 11, 2009 | Office Equipment & Supplies
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
Printer won't recognize the new ink cartridge
Each cartridge has a electronic chip pre-porogrammed at the factory.
If it is a reputable store they will exchange for the right color as they can return the PM to Canon as defective,
Mar 27, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Brother MFC5440CN - Yellow cartridge does not print despite being
Print head will have to be replaced. Whenever one or more colors won't print and you've gone through the cleaning process, the printhead is bad!
Jan 02, 2009 | Brother MFC-5440CN All-In-One InkJet...
Epson stylus 1280 printer
Based on the lights you are already out of one or more ink cartridge or an ink cartridge is not being recognized/expended.
-You cannot print if any ink cartridge is expended.
-Leave the empty cartridge installed in the printer until you have obtained a replacement.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
1. Open the printer cover and press the INK REPLACEMENT button, located under the printer's cover. The print head moves to the center and the lights flash.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8.
8. Press the INK REPLACEMENT button and close the printer cover. The printer begins charging the ink delivery system.
Jun 17, 2008 | Epson Stylus Photo 1280 InkJet Printer
Canon PIXMA IP5200 InkJet Photo Printer Logo
269 people viewed this question
old marine
old marine
