Question about HP Pavilion 751n PC Desktop
After replacing hard drive an rebuild, unable to get sound back again. Naturally suspect driver but unable to find a solution. Tried HP site and not obvious selection of drivers available to solve prob. Also suspect need a driver not directly connected to audio but to be able to support a driver for audio. I am a little lost as you might gleen from explanation. Can you help? Gary
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details like the operating system of your computer and the complete model number.
Thanks for using FixYa.
Posted on Feb 22, 2010
I have a Gen 8 Hp server with 5No 600GB HDD. The first two disk are mirrored, the other 5 are on raid 5. 1 of the 3 on raid 5 is flagging amber colour. How do I replace the HDD without losing Data?
Before replacing drives • Be sure that the array has a current, valid backup. • Confirm that the replacement drive is of the same type as the degraded drive (either SAS or SATA and either hard drive or solid state drive). • Use replacement drives that have a capacity equal to or larger than the capacity of the smallest drive in the array. The controller immediately fails drives that have insufficient capacity. In systems that use external data storage, be sure that the server is the first unit to be powered down and the last unit to be powered up. Taking this precaution ensures that the system does not, erroneously, mark the drives as failed when the server is powered up. Replacing drives The most common reason for replacing a drive is that it has failed. However, another reason is to gradually increase the storage capacity of the entire system. NOTE: In fault-tolerant configuration, hot-plug hard drives can be replaced when server is ON, but in case of a Non-hot-plug hard drive, it should be replaced when server is OFF. For systems that support hot-pluggable drives, if user replace a failed drive that belongs to a fault-tolerant configuration while the system power is on, all drive activity in the array pauses for 1 or 2 seconds while the new drive is initializing. When the drive is ready, data recovery to the replacement drive begins automatically. For systems that support non-hot-pluggable drives, if user replace a drive belonging to a fault-tolerant configuration while the system power is off, a POST message appears when the system is next powered up. This message prompts user to press the F1 key to start automatic data recovery. If user do not enable automatic data recovery, the logical volume remains in a ready-to-recover condition and the same POST message appears whenever the system is restarted. Automatic data recovery (rebuild) When user replace a drive in an array, the controller uses the fault-tolerance information on the remaining drives in the array to reconstruct the missing data (the data that was originally on the replaced drive) and then write the data to the replacement drive. This process is called automatic data recovery or rebuild. If fault tolerance is compromised, the controller cannot reconstruct the data, and the data is likely lost permanently. Time required for a rebuild The time required for a rebuild varies, depending on several factors: • The priority that the rebuild is given over normal I/O operations (user can change the priority setting by using HP SSA/ACU) • The amount of I/O activity during the rebuild operation • The average bandwidth capability (MBps) of the drives • The availability of drive cache • The brand, model, and age of the drives • The amount of unused capacity on the drives • For RAID 5 and RAID 6, the number of drives in the array • The strip size of the logical volume • Firmware versions of the Smart Array Controller and Hard Disk Drive • Presence of BBWC/FBWC CAUTION: Because data rebuild time may go upto the rate of 200GB/15 minutes, the system could be unprotected against drive failure for an extended period during data recovery or a drive capacity upgrade. When possible, perform rebuild operations only during periods of minimal system activity. When automatic data recovery has finished, the drive status LED changes from flashing green to solid green. If the drive status LED on the replacement drive changes to flashing or solid amber, the rebuild process has terminated abnormally. If an abnormal termination of a rebuild occurs, identify the cause and appropriate corrective steps. Abnormal termination of a rebuild If the activity LED on the replacement drive permanently ceases to be illuminated even while other drives in the array are active, the rebuild process has terminated abnormally. The following table indicates the three possible causes of abnormal termination of a rebuild. Cause 1: An uncorrectable read error has occurred. 1. Back up as much data as possible from the logical drive. CAUTION: Do not remove the drive that has the media error. Doing so causes the logical drive to fail. 2. Restore data from backup. Writing data to the location of the unreadable sector often eliminates the error. 3. Remove and reinsert the replacement drive. This action restarts the rebuild process. If the rebuild process still terminates abnormally: 1. Delete and recreate the logical drive. 2. Restore data from backup. Cause 2: The replacement drive has failed. Verify that the replacement drive is of the correct capacity and is a supported model. If these factors are not the cause of the problem, use a different drive as the replacement. Cause 3: Another drive in the array has failed. A drive that has recently failed can sometimes be made temporarily operational again by cycling the server power. 1. Power down the server. 2. Remove the replacement physical drive (the one undergoing a rebuild), and reinstall the drive that it is replacing. 3. Power up the server. If the newly failed drive seems to be operational again: 1. Back up any unsaved data. 2. Remove the drive that was originally to be replaced, and reinsert the replacement physical drive. The rebuild process automatically restarts. 3. When the rebuild process has finished, replace the newly failed drive. However, if the newly failed drive has not recovered: 1. Remove the drive that was originally to be replaced, and reinsert the replacement physical drive. 2. Replace the newly failed drive. 3. Restore data from backup. More Resources: • Click here for ProLiant Self Solve. • Click here for Creating and Managing Hard Drive Online Spare Technology. • Click here for 17xx Power-On Self-Test (POST) Errors and fixes. • Click here for HP Dynamic Smart Array RAID Controller User Guide. • Click here for HP Smart Array Controllers for HP ProLiant Servers User Guide. • Click here for HP Smart Array Controllers for HP ProLiant Gen9 Servers User Guide. • Click here for Configuring Arrays on HP Smart Array Controllers Reference Guide. • Click here for Array Configuration, Diagnostic, Storage Administrator and SmartSSD Wear Gauge Utility Software and User Guides.
Feb 15, 2017 | HP Computers & Internet
Toshiba MK1059GSM sudden noise?
First backup all your data asap. Noises of this type are a sign of a failing drive.
Then run the extended test... http://gsmartcontrol.berlios.de/home/index.php/en/Home
You should be able to replace the drive with in the one year warranty period.
Sep 12, 2012 | Toshiba (MK1059GSM) 1 TB Hard Drive
I formatted a dimension 8100 and I install window 7 32 bits now I can't upgrade my Ethernet or sound drivers
I suspect you already tried the drivers. Dell site only has drivers from 2001. You may have to roll back or purchase new cards. It's the same reason I can't use Win8.
http://www.dell.com/support/troubleshooting/us/en/19/Index Choose drivers and downloads..
Aug 30, 2012 | Dell Dimension 8100 PC Desktop
--NO AUDIO OUTPUT DEVICE IS INSTALLED-- little red x, the usual suspect. The problem is that there is nothing listed in device manager under sound, video and game controllers nor is there anything under...
You can download the drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Dec 16, 2010 | HP Pavilion dv9810US Notebook
Unable to scan on HP Laserjet 3055 on Windows XP
Sounds like a software issue - U might try contacting HP but do not hold your breath. If machine is out of warranty they want nothing to do with you and will refer you to some forum or whatever. Or they might tell you to get a new scanner compatible with a newer OS.
Jul 02, 2017 | HP LaserJet 3050 Printer
My hp compaq nc6000 says nonsystem or disk error wont go further?
If you get an error message - non system or disk error and the hard disk is not detected in the BIOS, then you most likely have a faulty hard disk and chances are you have also lost all your data.
If you are desparate to recover your data, there are data recovery companies that can retrieve data from faulty hard disks but it will cost you an arm and a leg for their services.
To get you computer operational again, you will need to replace the hard disk and install Windows, all the device drivers and your programs.
Jun 02, 2009 | HP Compaq nc6000 Notebook
External hard drive not recognized
I think the hard drive is causing the issue as the two computer were unable to detect the drive.
In this i want you to disconnect the hard drive & clean the golden edges of the drive and the connctors and connect it back.
Go to BIOS menu & check whether it is detected in the BIOS or not.
If it is not detected, connect the hard drive to another computer which can boot to windows.
And run the diagnostics using the software from the WD site.
http://support.wdc.com/download/index.asp?swid=1
Error code information you can get from
http://support.wdc.com/techinfo/general/errorcodes.asp
Check with this.
Good Luck.
Live, Love, Laugh.
May 09, 2008 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Missing .dll file
Uninstall the drivers and make sure it isn't in the device manager, then (leave it plugged in) reboot, your cpu will notice this change and re-install the driver, if it doesn't here is a site for a driver download: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=60259&lang=en&
Nov 01, 2007 | HP PSC 950 All-In-One InkJet Printer
HP Pavilion 751n  PC Desktop Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
