Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Repeated fax cover pages
I have received at least 50 cover pages of the same fax which I received. I cannot print or do anything else because this is what the memory is full of. HELP!
    Genius:
  • 1,226 Answers
Hello;
Maybe you can do resetting that machine. You can try unpluging so that everything will be reset. and then restart the system where the machines was connected.
May this help!
Thank you!
melnavz
Posted on Feb 22, 2008
How do I print a single call report for a FAX previously sent
Printing a fax call report
A fax call report is a brief report that indicates the status of the last fax that was sent or received.
To print a fax call report
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Reports, and then press .
3. Use the < or the > button to select Fax Call report, and then press .
4. Press to select Print report now. The all-in-one exits the menu settings and prints the report.
NOTE To set the fax call report to print automatically, see Setting print times for the fax call
report.
Setting print times for the fax call report
You can set the all-in-one to print a fax call report after any of the following events:
? Every fax error (the factory-set default)
? Send fax error
? Receive fax error
? Every fax
? Send fax only
? Never
NOTE If you select Never, you will have no indication that a fax failed to be transmitted
unless you print a fax activity log.
To set the print times for the fax call report
Use the following steps to set when the fax call report is printed:
4. Press the > button once to select Print report, and then press .
5. Use the < or the > button to select the option for when you want the fax call reports to be printed.
6. Press to save your selection.
The following print-time options are available:
Including the first page of each fax on the fax call report
If this option is turned on and the page image still exists in the all-in-one memory, the fax call report
includes a thumbnail (50% reduction) of the first page of the most recent fax that was sent or
received. The factory-set default for this option is On.
To include the first page of each fax on the fax call report
Use the following steps to include the first page of each fax on the fax call report:
4. Use the < or the > button to select Include 1st page, and then press .
5. Use the < or the > button to select On or Off, and then press to confirm your selection.
Jul 06, 2011 | HP LaserJet 3050 All-In-One Printer
I would like to have the device print a Fax Confirmation for all fax sent and received. HP Officejet J4680 All-In-One
Follow the steps below to enable the Fax confirmation on Sent and recieved.
On the printer :
  1. Press Setup (c01461502.gif ).
  2. Press the right arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  3. Press the right arrow button (c01185072.jpg ) to select one of the following options:
    • On Fax Send: Print a confirmation page every time you send a fax.
    • On Fax Receive: Print a confirmation page every time you receive a fax.
    • Send & Receive: Print a confirmation page every time you send or receive a fax.
  4. Press OK .
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 24, 2010 | HP J4680 Office Jet All-In-One Printer
MX310 - faxes in memory. Cartridges have been replaced. Error of low ink remains. What is the key sequence to retrieve these faxes?
Press Fax then Menu. You should see Fax Settings across the top row. Use the left/right arrows to select Memory Reference and press OK. Again use the left/right arrows to select Print Document and press OK. Select the transaction (RX) number of the fax you want to print (received faxes start at 5001) and press OK. Then choose whether you want the first page or the entire fax (yes to first page only or no for the entire fax) and press OK. To print additional faxes repeat from the Select RX number. Print the Memory List to find out which fax is which (from the list that you see under Print Document.
Then you can delete these by selecting Delete Document instead of Print Document in the above directions. Then press OK followed by Yes or No for deleting the document.
Finally press Stop/Reset to leave the menu.
I hope this helps.
Sep 24, 2010 | Canon PIXMA MX310 All-In-One Printer
Wrong in receive fax (only one page coming)
Contact the sender and tell them to press STOP when their machine starts to dial.
Jun 28, 2009 | Panasonic KX-FM131 Fax
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My printer doesn't print anything
Head problem COPY many black text pages 50 or so run head clean if still white pages repeat up to 200 or so pages..see how you go
Apr 22, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
MFC 7300C
IT SOUNFDS LIKE THERE IS SOMETHING IN THE WAY OF THE PAPER PATH THAT IS CATCHINH THE CORNER OF THE PAPER, WHAT WE USUALLY DO IS TAKE A 8X10 FILE FOLDER AND MANUALY PUSH IT THRU THE PAPER PATHE TO SEE IF ANYTHING IS IN SIDE THEN REPLUG THE MACHINE AND SEE WHAT HAPPENS, GOOD LUCK BROTHER SR TECH
Nov 06, 2008 | Brother MFC 7300C InkJet Printer
HP 20 ink refill problem
Did you try a new ink cart? Most print problems with inkjet machines are refilled carts.
Nov 18, 2007 | Brother IntelliFax-2820 Laser Fax
Cannot receive faxes or do copies
If you still have your old cartridge reinstall it that will tell you if it is the cartridge or not. If you still have the problem,it could be the encoder.
Oct 23, 2007 | Office Equipment & Supplies
Fax received printed sideways, 50% size
If its not constant its probably on there end. Does it happen with any other party. Lawrence
Nov 20, 2006 | Panasonic Panafax UF-790 Plain Paper Laser...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
old marine
old marine
