Question about Peavey PV-3800 2-Channel Amplifier
Trying to locate a voltage selector switch for a peavey cs800x any ideas
  • 88 Answers
Try contacting pv direct
Posted on Feb 08, 2010
Peavey sp5 crossover fried
well it would depend on what voltage you would want them to fire at...the poly SWITCH would trigger at the voltage you want the second series ballast resistor to kick in at, obviously you would like to have it operate at a higher voltage cause you have blown the poor thing up, the maximum power of the RX22 diaphragm is 80 watts and it is 8 ohms, so divide the 80 by 8 and then take it square rt. that will give you the max current in diaphragm..then multiply that by 8 to get it voltage across the diaphragm, which is about 25 volts, but we really need the current here as we need to understand the voltage drop across the sense circuit the kick in the next series ballast resistor to attenuate the horn....since I am to tired to get off my ass and the get the schematic out of the drawer...seem like I remember they are about 30 volts, I have about 20 in stock...
Dec 02, 2013 | Peavey PV® 900 360W Power Amplifier
Peavey Problems
Check speaker impedance or disconnect speaker leads, then use a 9V battery to verify cone movement and if this test is ok, then go inside the amp, if there's no fuses blown check opamps supply voltage which should be -15V at pin-4 and +15V at pin-8, let me know your results to help improvement.
May 21, 2013 | Peavey Electronics Peavey Max 112 Bass...
How do i switch the Hz setting on the monitor
Usually, if there is a selector switch to match electrical requirements of a monitor or computer to that which may be available in the home, it is for voltage or voltage AND frequency. Seldom is there are selector for frequency only (I've yet to see one anyway).
The selector switch it typically found near where the AC mains power cord enters the enclosure. This can be on the monitor itself - or in the case of a monitor that uses a low voltage cable and connector connected to a power adapter, it would be located on the power adapter instead. Sometimes, these devices automatically detect and switch to match the power being supplied to it. The device should clearly indicate that it will work a wide range of voltages - do not assume it will if it does not specifically indicate that it will.
The selector above is set to 230 volts.
Set the selector switch BEFORE connecting to the power outlet. Most times, the selector switch has the voltage indicated on the slide. The switch will allow the user to choose 110-120 or 220-240 volts. The 110/120 selection is likely to be the 60 Hz variety and the 220/240 selection is likely to be 50 Hz.
If you are unable to locate such a switch, the device is not intended to be changed by the user - and there is likely no "easy way" for the user to change it.
Please rate this reply - good luck!
Aug 31, 2010 | Computers & Internet
I have 2 Peavey Impact 1015s and 2 PV 118 Subs. I have a Peavey Kosmos PRO that runs from my Numark CDMix3 to my amps. My two amps that I have are a Peavey CS800x and a Crest Audio CD3000. Could you tell...
Just a note regarding connecting: USE BALANCED lines everywhere you can. Use either XLR if available or TRS type cables. This will reduce noise pickup.
Another hint: For SAFETY of your equipment run ANY interconnected devices from the SAME power source. DO NOT say power the amps from one place and your other equipment from a different outlet. Afford a power distribution system that feeds from a single receptacle or nearby receptacles near a common electrical panel. This will ALSO help avoid noise as well as the hazards to your equipment from ground loops.
Apr 01, 2010 | Peavey Music
My peavey amp worked fine. then it wouldnt turn on.
possibly it has a thermistor in the mains voltage line to the switch which cuts out when hot, I have this same problem with my Peavey TX210 combo. Pretty sure it is just the thermistor which is easy to track if you follow the mains cord wiring towards the switch and switched on light with your meter.The voltage does not get to the switch, but is stopped at the thermistor.
Sep 08, 2009 | Peavey Audio Players & Recorders
Peavey cs800x a channel drive board what goes bad?
A bit late, but I'll give it a try.
You can measure the outputsignal before the relay.
Often there's a coil, measure if you've got a DC level at that point.
If so, you're power amp is down.
Normally when the relay doesn't switch there's a DC level in your amp.
Cheers, Gerard
Sep 07, 2009 | QSC MX1500A 2-Channel Amplifier
Hi, Peavey Classic Guitar amp , Has NO SOUND
Hi Mike,
If you switch on the amplifier, do you hear nothing at all?
Or do you hear low level noise or hum out of the speaker?
Don't know if you're technician.
If the tubes are glowing, you can measure the high voltage.
Check also fuse 3 and 4, thats the neg. voltage -27V and -14V.
regards,
Gerard
Jul 06, 2009 | Peavey Audio Players & Recorders
Change the voltage from 240v to 120v
Unless there is a 240/120 switch on the back, this amplifier cannot change voltage. The only way is to replace the power transformer, and when you do that you need to use the exact model transformer Peavey uses for the 120 version. I have also seen differences in handling power outside of just a different transformer for USA/Euro models.
The differences between these two market models might be beyond what is cost-effective to convert.
If it is the Peavey blazer 158, they go for as cheap as 100 bucks here in the states. Or buy one new for 120.00 bucks and 4.99 shipping: http://www.dcmusicstore.com/Peavey-blazer-158-guitar-amplifier
Best advice: sell it for what ever you can get and buy one here.
Hope this helps!
-mike
Mar 28, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Peavey signiture EX wiring
if the signature ex has any special plugs then the actuall diagram for that guitar is needed. but if it uses the standard two or three potential meter ( volume knobs and tone knobs or (pots) ) with a pick up selector and an input. then you can use any guitar wiring diagram and i think you can find that on web. wiring the pick up should be shown in the diagram with the pick up selector.
Feb 23, 2009 | Peavey Music
Peavey PV-3800 2-Channel Amplifier Logo
60 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Steve
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
