Question about SmartDisk FireLite USBFLB120 120 GB USB 2.0 Hard Drive
It seems the new macbook pro does not support the firewire connector. Is there a different wire available? It looks like the macbook pro has a firewire connection but it is much smaller than the original connector of the smartdisk drive. Do I have to get a new backup drive?
    Problem Solver:
  • 8 Answers
The problem lies in your cable!
The new macbook pro still uses firewire and will be compatable with your drive. It just uses a 4-pin instead of a 6-pin connector. You can get an adapter or new cable that goes from 6 to 4-pins.
They did take away firewire from the new line of plain macbooks though (shakes fist at steve jobs)
Posted on Feb 22, 2010
I want to upload a video to my macbook pro for an iMovie, but it says I need a Fire Wire...Is it possible to connect my Vivitar DVR 410 to a FireWire cable?
As a tech, I found FireWire cables to be vastly unreliable, but if you just have to have one, do NOT scrimp. Get one that is heavy duty. The thicker the cable, the better. Avoid flexing the cable near the connectors if at all possible.
Jul 31, 2013 | Vivitar NP60ACcharger) for Vivitar...
Firewire to USB adaptor?
There are; http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2057872.m570.l2632.R2.TR5.TRC1.A0.H0.Xfire+wire+to+usb.TRS0&_nkw=firewire+to+usb&_sacat=182094
Jun 04, 2017 | LaCie d2 DVD-RW Burner
Firewire connector doesn't match
It sounds like you may have one of the newest MBPs that doesn't have a firewire port. If that is the case, it is still possible to connect firewire peripherals through a Thunderbolt to Firewire adapter cable.
Aug 06, 2012 | LaCie Super-writemaster Dvd Multi Recorder...
Macbook pro doesnt recognize the panosonic pv-gs9 when connected with firewire
I take it that your macbook pro has imovie on it. If you open up imovie and plug in your camcorder it should recognise the camcorder and give you access to putting the movie onto your mac. Have a look at http://www.apple.com/support/imovie/ it should help.
Mar 03, 2012 | Panasonic Palmcorder PV-GS9 Mini DV...
Hi, I'm wondering if you can help, I have a Sony DCR-TRV340E camcorder and wish to take the video footage from one of the tapes and record/stream it onto my MacBook pro. I've tried using the USB cable...
*reason for not streaming the video: its because you're using the wrong type of cable to stream it to a macbook
*type of cable needed: you need a firewire cable to stream videos from your camcorder to your macbook.
*please make sure to check if your macbook has a firewire(IEEE) port on it and also make sure what type of firewire port it has( 4 pin or 6 pin firewire port)
*check your macbook specification for a firewire port and make sure to check how mny pinslot it has before buying a firewire cable.
* the other end of a firewire cable would surely fit the camcorder and the other end would depend on the firewire port available in your macbook.
* you would also be needing an application on your macbook that would record streamed videos.
Jan 13, 2011 | Sony Handycam DCR-TRV340E Digital...
Swapping MacBook Screens
As long as the lcd cable connects to the new screen it should work just fine. Just power it on before putting all the screws back to make sure.
In regards to the wireless I don't understand the question completely. The 2006 will probably only have two wires...just make sure they go where the white and black ones did. You'll just lose a lot of the "N" network strength.
Hopefully that answers you questions. If not, let me know.
--RescueTechLA
Nov 29, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have a new Macbook, but it doesn't have a
Buy a USB card reader, this will show your card (which you used in the camera) as a normal disk in finder
Jul 02, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Firewire 800 cable
No such thing s a dumb question, I transfer from my Canon XL1 to my Mac IBook with firewire all the time. You have three choices: 1. Buy a cable with two different ends - one that will fit your camera (the tiny one so small it is hard to insert) and one that will fit the Mac. Your Mac should have two different types of firewire ports - the semi-round one and the square one that looks like a USB port, but isn't. The symbols are different  for firewire ports firewire and USB ports. But all firewire ports, regardless of the configuration will have the firewire symbol and all USB ports will have the USB symbol.  Either firewire symbol port will work. I have two different firewire ports on my MacBook G4 and use them both,  I keep a bunch of firewire connectors around. They usually come with outboard hard-drives in various configurations. Sold en Ebay or at computer stores Solution 2: Feed your firewire through an outboard drive that will accept the 400 firewire (many do) and then take another firewire, say an 800, from that drive into your computer. I always capture to a hard drive then edit from there. The idea of a firewire bus is that you can connect a number of drives in parallel and mount them all. Available for as little as $69.
Solution 3: Buy a firewire port card for you MacBook which slips into a slot on the side, and gives you connectivity with the 400. It also frees up your main firewire port. I bought one on Ebay for $24 that came with all the adaptors. I was pulling my hair out too until I figured out the system.
Nov 28, 2008 | Sony DSR-11 DV / Mini DV VCR
USB Connection Problems
You say have a SanMax HD-338-CB USB/Firewire External HD with a 160MB drive. You then say sometimes I have to reboot Windows XP pro 2 or 3 time before I see the drive using a USB 2.0 connection. Fire wire is a different system with a different connector style- so it should not be in a USB port or a USB connector should not be in a Firewire device. Get you device and connections sorted The desktop display simply puts up a device it will not differentiate which USB or Firewire
May 23, 2007 | SanMax 1 Bay (HD338CB) FireWire (IEEE...
SmartDisk FireLite USBFLB120 120 GB USB 2.0 Hard Drive Logo
333 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
