Nokia 5200 . bty gets discharged immidiately.switches on only when connected with charger. at times bty shows full . but again within an hour or so phone is switched off. pl help
It could be 1 of the 2 carbon brushes when the autostop protection is activated replace carbon brush cb441 194435-6 is a normal problem when the working hours are arrived ,but if your battery is empty it will stopping at once a protection for li-ion deep discharge protection.
Li ION is the best to have allways 1 of the batteries on the charger ,if working and do not full unload it change after a while before its stopped its better for the expensive li-ion batteries but if forget one batterie to use over time ( because you want to save him well-intentioned ) to use it frequently is better when its to deep discharged it will not working anymore the charger will not accept the battery anymore if its deep discharged , to rewake it preloading it only like this way a safe as possible against fire hazard not use chargers of cars or other tricks do a full working loaden battery from the charger and connect with that other battery connect both to each other with 2 1,5 kwdr wires the full battery with the not accepted not working deep discharged battery that was forget for a long time BEWARE to do only connect a polarisation as the + to the + and the - to the - the poles parrallel connect to each other not longer then 3 minutes after that remove the wires and now put immediately the not working battery on the charger and see that its accepted again, if its not working repeat it one time again , not for 3 times its a real battery problem for garantee or replacement do not work on li ion with battery chargers for a car or other full overpowered chargers without knowledge do not open or disconnect wires inside the battery then the Makita battery is immediatly dead . because of fire hazard protection li ion full battery on empty battery + to + - to - not more then 3 minutes if it still not working within 3 minutes repeat it once again be shure the wires are connected correct from battery to battery to preload if there was an battery problem of an empty battery or dead battery.
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
This is your battery problem.
Just do the step below hope it will solve a bit.
get fully discharge and let automatically switched off. then connect to charging but do not switched it on after showing full charge, disconnect charging and switched your phone on.
initially do dis 4-5 time a week. After that do 1-2 a week.
This will increase your battery strength.......
make sure that charger pin of your charger supports your mobile or not. if so then there must be fault in that charger pin of your mobile. kindly change the charger pin of your mobile.
