Question about Dishwashers
Kitchenaid dishwasher KUDS02SRSS2 start light blinking won't start
My dishwasher cycle buttons/lights all seem to work normally, then I press start and the start button blinks continually but nothing happens. But all the buttons still behave the same way even with the door open or closed. They stay lit even during this action. I'm wondering what part I may need. I'm hoping it's something simply like the door switch. I've opened up to look at this but see no obvious damage. I'm not sure what the blinking is telling me but it may be that it thinks the door was opened during a cycle and it's wanting me to open, then re-close the door to restart itself? This is why I think it may be the door switch stuck in one position? Kitchenaid was no help at all with this blinking. I'm hoping you can help me. I am not familiar with this dishwasher because I bought it as is in hopes I could fix it...I was thinking it was a "dry stall" issue because it was left out from a reno for a few months.
Please help me! Thanks in advance. Lori
  • 10 more comments
  • wolliw Feb 22, 2008
    No, it doesn't appear to be the problem. It's apart right now but the switch does have continuity when the switch is operated. As well, the latch mechanism does activate the switch when the door closes. Unfortunate but, still looking...The start button does receive power from the control board I think. Otherwise it would not be lit at all so it does recognize the start button is depressed. Still thinking...
    Hi Aborcass.
    Thanks for staying with it. OK...I've read this the other day but never tried it. (I don't have a kickplate so no wiring diagram available.) I'll give it a try with that toggle sequence but what do I do if it does go through this "diagnostic sequence". You say it will go through all the cycles, I'm assuming iun a short period of time. Then what? I guess then I know all the mechanics are working? I ordered the electronic control unit but don't want to install it just yet or I can return it. I ordered the switch and thermal fuse as well so I'll be trying those once I try this diagnostic sequence. I'll post what I find. Cheers!
  • wolliw Feb 23, 2008
    OK...I did the diag sequ, sani-heat-sani-heat and all the lites came on in the touch pad above as well as the start button, control lock, sanitized & clean buttons and the digital display window, all located on the door. But nothing is happening...they are all just staying on. I've replaced the door switch but it's still doing the same "start lite blinking" thing. I have the electronic control board but am still waiting for the "simpler solution" if there is one?? With all the lites on, wouldn't this mean user interface is ok? Not sure but I hope so.
    That's funny beacause I was looking very closely at the entire assembly wondering "is the little white button getting pressed with the latch mechanism"? and it was really hard to hear this click as you mentioned...I've played with theswitch to make sure I know what it sounds like but it's hard to differentiate between the latch sound and the click of the switch. I will try bending the latch then but I was pretty sure it was clicking as it should...will get back to you shortly...Thanks, again...It seems like we may be getting somewhere...I am optomistic!
    Nope...unfortunately nothing changed. I can trigger the switch with the door open as you say but still all the same. hmmmm...I'm alsmost ready to take out the elec control? Do you think the touch pad is ok? It seems to do what it's supposed to right? If it's the motor, what is the blinking start lite telling me? I think it's saying that vthe door was opened in mid cycle, right? And it's waiting for the door to close then to re-press the start button to finish the cycle?
    Well, when the dishwasher is in standby or off mode and you press a cycle to washer dishes, each cycle button does respond to the touch by lighting up so...I'm assuming these buttons are ok. When it says "one or more keys won't respond" then I'm assuming the light still comes on but that's as far as it goes...it still may not be responding because there's no action? I'll assume it has more to do with just lighting up. They seem to feel like they are engaging when I touch them. Since I have the elec control then, I will replace it in the morning. Will let you know. I want to thank you very much for this very interesting and useful service you have provided so reliably...step by step. Your experience has been appreciated in this world of consumerism! Not sure yet how to rate this yet...considering it's not fixed yet but I appreciate the fact that people's time is very valuable and the process involved in diagnosing, in many cases is long. Have a good night! Lori
    So now Im getting worried. The elec control replacement didnt work. Everything still the same.
    Hold on! Your going to be as happy as Im to know it was the latch after all. Right before I was to surrender to a service call, I bent the strike down as you mentioned and it work! I know I should have done that last night but I pushed the mechanism down with the screw driver instead to hear the click of the switch.
    All is good now...I canèt believe I bought the parts... now they wont take them back which I knew anyway. But...thank-you, thank-you, thank-you!! You did it!
  • jvito914 Oct 01, 2008
    rinse cycle and cancel control are both blinking unable to reset any of the controls
  • SalAdmiral Nov 28, 2008
    KitchenAid KUDM01TJ model:
    I have the same problemm. rinse and cancel cycle is blinking..
    I can 't determined either it is door or switch panel? would you please help..
    continueously rinse and clean switch blinking.. and start button never .
    Check the door.. do not have diag plate to determined what cause is? would you please help?
  • Lorraine Nov 28, 2012
    I had the same issue....its seems to be the latch on the door side is stuck...I pushed the black latch in the door side and it seem to release and then I as able to run a wash
  • 4 Answers
I have this same kitchenaid model. It would not start after selecting the wash cycle and pressing start. The light would blink as if the door was open. I did the reset by pushing the sani-rinse, heat dry, sani-rinse, heat-dry and closing the door. You can hear something going on inside. After that stopped (about 3 minutes). I was able to select the wash cycle, press the start, close the door, and it started. Good luck!
Posted on Feb 05, 2011
I had the same problem so I bent that metal thing upwards cause it was bent down. I was scared to break it off but I gave it a shot and it worked. I closed the door and it started!! Good luck to you all!
Posted on Sep 15, 2010
    President:
  • 2,651 Answers
Sounds like the a bad door switch issue, machine doesnt think door is closed so wont operate. could also be a keypad issue not recognizing start button is being deperssed
Posted on Feb 22, 2008
  • 5 more comments
  • Ron Coons
    Ron Coons Feb 22, 2008
    behind the lower kickplate if still ther eis atech sheet for this model, geting it into a diag mode would be useful, you could atleast check components operation. sani-rinse----heat dry --- sani-rinse--- heat dry, i believe is the toggle sequence t olight up all leds and then will cycle though components indivually,
  • Ron Coons
    exactly right, just wanted to check all mechanic systems, user interface most likely source of problem(push buttons board)opposed to actual electronic control board
  • Ron Coons
    Ron Coons Feb 23, 2008
    thats odd, all light's light you def are in diag mode. door closed and nothing happened?can you hear that door switch "clicking" when you close the door(listen closely), although its a good switch perhaps the strike plate is not hitting it correctly(you can always bend the striker(located on the tub) down slightly, its made with some spring in it so dont worry about breaking it.or even trippeng the switch with a screwdrive in latch assy w/ door open. that migh be the simple solution your lookin for
  • Ron Coons
    looking at tech guide for this model says "wont run AND start/resume light blinking slowly" gives a few choices to look into, allwe've discussed so far 2nd to last recomendation was "one ore more keys wont respond",, which is a nightmare to actually test them, and finally" faulty control" repalce control.
  • Ron Coons
    Ron Coons Feb 24, 2008
    GREAT JOB!!!!!!!!persistance paid off
  • greerad Nov 03, 2011
    In my case I found a wire that had become disconnected from the door switch.
    I played with the switch on the door and it seemed to release and then a wash cycle worked
Kitchenaid dishwasher kuds30ivwh3 start light blinking. Dishwasher won't start.
Press these keys :
Heated Dry----> Normal-----> Heated Dry-----> Normal
All the l.e.d.s should lite up and then, if you push start, it will go from function to function. push the button 8 or 9 times, then
Reset the power to the unit via the circuit break, then run a normal wash cycle and see if it completes...
Nov 20, 2016 | KitchenAid Dishwashers
All Cycle Lights on with one blinking sometimes working often not working.
1) tight the connector wires very well and clean with spray contact, of course unplugged the machine
2)resolder all point from the board for colder joint
3) Try again.
4) If the problem persist the problem is the board defective.
5) Call some service tech.
God bless you
Jun 19, 2012 | KitchenAid KUDS301V Dishwasher
KitchenAid dishwasher KUDM01TJBS0 does not start.
Most likely your keypad is bad. Will need to replace the console.
Nov 20, 2011 | KitchenAid Dishwashers
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
The "cancel" light blinks on and off rapidly. If we push start for the cycle the dishwasher clicks off and on intermitently.
To solve this you will have to reset the console. Do this by closing the door and press these buttons in sequence
-high temp wash -heated dry -high temp wash -heated dry
After doing this sequence all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).You should now be able to run the dishwasher as normal.
Thank you!
May 16, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Nov 16, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Feb 12, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Kenmore dishwasher wont start blinking clean light
today January 9, 2009...blinking clean light, kenmore dishwasher would not run,,,the solution on Fixya ..."keep hitting normal -heated wash-normal -heated wash buttons over and over...unlocked the blinking green light problem. Dishwasher is running as I type this....will post again when I see the results of another washing tomorrow. H.T. Las Vegas Nv
Jan 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
8,144 people viewed this question
Top Dishwashers Experts
