Question about Kenmore 24032\24036 Top Load Washer
Kenmore washing machine, cold water fill up is very slow, whereas the hot water fill is very fast. I checked the screening on the cold water side and it is clean and free of any debri, hose is also clear. When I remove hose and turn on cold water ,it flows fast. Any chance it is some kind of valve in the machine getting stuck?
  • Anonymous Mar 21, 2014
    water in bottom
  • Kenmore Master
  • 3,361 Answers
The internal valve on the cold inlet is most likely sticking.
You will need to replace the water valve assembly.
This video will show how to remove the cabinet to access the water valve.
http://appliancejunk.com/forums/index.php?topic=5191.0
Posted on Feb 07, 2010
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
May 11, 2014 | Washing Machines
Cold water comes out very slowly whereas hot or warm is normal
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 27, 2010 | Kenmore 12502 Top Load Washer
Cold water wash very slow fill up
Hi, you have a blockage on the cold side of your inlet valve, take the hose off on cold side of the valve and inspect screen..You may find some debris. If no debris is found you may have a bad valve..your going to need to replace it...if you have any questions please don't hesitate to contact
Jun 23, 2009 | Washing Machines
Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite washing machine will not fill as fast as usual.
You will need to get behind the washer, turn the water off, disconnect the hose from the washer, look for a screen inside the water valve, hopefully there is one that you can clean if necessary. I always put the hose over in the washer and turn the water on to check the flow.
If the screens on both hot and cold are clear, water flow is good on both hot and cold, connect the water back to the washer. If the flow is still slow then the problem is inside the valve. The valve will have to be replaced.
Dec 17, 2008 | Washing Machines
Washer fills only with hot water
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still slow, replace valve.
Regards,
reg501
Jun 28, 2008 | Washing Machines
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Jul 17, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore 24032\24036 Top Load Washer Logo
246 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
