Question about Philips Audio Players & Recorders
Hi, I have a Philips HTS9800W and the back speakers do not get any sound any more. I have tried changing the wireless channel but there is nothing, the blue light on the box dose not come on. I have also tested that there is power to the back speakers. Thanks Paul
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all please check that all the cable connections from/to the Phillips HT are fine and connected properly as per Operating Instructions. You’ll also need to check that the “Sound Mute” is not active and the volume is not set to minimum. Also check that the back “Speakers” are not set to “Off”. Change “SAP” settings. Check “HDMI1 in” or “HDMI2 in” settings when equipment is connected via HDMI. If there is a problem with digital sound connection, select analog sound connection and inform me about the results.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 07, 2010
Lg tv hts9800w
What have you tried? Is there any sound at all?
Oct 29, 2012 | Philips Cineos HTS9800W System
HTS9800W/12 and rear speakers
click this site:
http://www.avforums.com/forums/archive/index.php/t-378942.html
Jul 10, 2008 | Philips Cineos HTS9800W System
No sound or power
IF ALL WIRES ARE CORRECTLY BEEN SETUP OR INSTALLED THEN THE NEXT STEP IS TO CONFIGURE THE SYSTEM TO WORK ON ALL SPEAKERS...
Before the setup of the speakers' channels
  • Press the SURR. button on the remote to select multichannel surround mode before adjusting the speaker settings.
  • In case of sound distortion, press and hold the SOUND button to select another transmission channel for the wireless rear speakers.
Setting Speakers' Channels
  1. Press 060227073157_11231.jpg to stop playback, then press SYSTEM MENU.
  2. Press 060227073234_11234.jpg repeatedly to select { Audio Setup Page }.
  3. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight { Speaker Setup Page }, then press 060227073234_11234.jpg.
  4. Enter its submenu by pressing 060227073234_11234.jpg.
  5. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight one of the options below at a time, then press 060227073234_11234.jpg.
    • { Speakers Volume } – Volume level setting for individual speakers (-6dB – +6dB).
    • { Speakers Delay } – Delay times setting in relation to the listening position/ distance for centre and surround speakers.
  6. Press 060227073245_11235.jpg060227073234_11234.jpg to adjust to the setting that best suit your surround sound needs.
  7. Press OK to confirm.
Notes:
  • 1 ms increase/decrease of delay time is equivalent to 30 cm change in distance. Use the longer delay time settings when the rear speakers are closer to the listener than the front speakers.
  • The test tone will automatically be generated to help you judge the sound level of each speaker.
Jan 27, 2008 | Philips Cineos HTS9800W System
Philips LX3950W - no signal to rear speakers
check to se if your reciever channel number is set to the same as your transmitter channel number. press and hold down sound butten on remote to set transmitter number .set reciever number button on reciever unit. try setting both to number 4.
Dec 29, 2009 | Philips LX3950W System
Sound goes out and comes back on
If this is a pair of wireless speakers hit the button in the back of the speakers to change the channel. if it is the speakers inside the set, it could be a loose solder connection that heats up after a while and then the solder seperates preventing sound. this same issue could happen to the final amp in the tv, when they get bad they will heat up and stop working. All requiring a tech to troubleshoot the problem.
Sep 10, 2009 | Philips 60P8342 60" Rear Projection...
Problem with rear speakers
hello
can sell me the junction box?
thanks
contact brilhasman@clix.pt
urgent
Jun 01, 2009 | Philips Cineos HTS9800W System
Hi!i have Philips HTS9800W but wireless rear speakers do not work!
The wireless rear speakers aren't wireless per se. They have to be connected to a receiver box and it's that box that brings in the system's wireless transmissions, eliminating in this way any cable runs from the front of the room to the back.
Nov 28, 2008 | Philips Televison & Video
Lip sync playing ordinary tv
you need to have a sound speed equalization higher frequencies travel slow,
if you can buy a AV/RF CONVERTER the problem can finish
AV be connected to devices and RF to tv
this can over come that problem
Oct 07, 2008 | Philips Cineos HTS9800W System
HTS9800 Wireless receiver not working
I have just bought one of these today and have had the exact same problem. No rear sound and no blue light on the receiver box.
Solution:
What philips don't tell you in the manual and on the support site is that the receiver box has a switch hidden under a white sticker; next to the left of the right speaker connection. The switch has 3 positions which can be selected. I had tried each switch position and power cycled the subwoofer each time until eventually i got a blue light on the receiver box.
You may also need to select the correct channel on the control box by pressing the "sound" button for 5 seconds on the remote control.
It took me quite a while to try the different combinations until it finally worked. I can't imagine that Philips would have sent the system out without testing the wireless partnership first, so I am guessing my wireless network could have had something to do with it. (forever the optimist).
I did expect the subwoofer standby light to have gone off or changed colour once operational, but this just seems to stay on no matter what state it is in.
Sep 09, 2008 | Philips Cineos HTS9800W System
No reception or sound on rear speakers.
Here's the fix: power off the sub-woofer and wait for 60 secs before powering it on again. My rear receiver works every time now.  I guess the sub-woofer isn't just a dumb speaker; it has some kind of smarts in it too.
Prior to this, I had only tried cycling power to the DVD player itself.  I also re-seated the two, fat cables connected to the junction box. One of them had worked itself slightly loose and the result was completely absent speaker channels.
Dec 03, 2007 | Philips Cineos HTS9800W System
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
