Question about Fedders Y Chassis AEY12F7E Air Conditioner
Unit will not blow hot air. It is about two years old and seldom used. Unit comes on the controls work but hot air no longer blows out.
    Genius:
  • 1,970 Answers
Mcdevito75 here, Are you sure your A/C unit is designed to both give heat and A/C ?? I figure the A/C of the unit works well, just doesn't give heat, if so see your local A/C repair shop in your area, they come to the house.
Posted on Jun 26, 2010
Peavey xr1200 blows 8A fuse after about one second. Old mixer, seldom moved, has worked fine for years
If it blows a fuse when powered on, it has a dead short somewhere. Old units do this when the capacitors (filters) get old and dry out. These create dead short circuits. I recommend going through the unit and change out the bad ones. They can usually be spotted easily. They look like little cans glued on the board with an "X" on top. They are usually blue, gray, or black. The X on top is a weak spot allowing the top to open or pop up when they go bad.
Mar 22, 2014 | Music
Car wont blow hot air heater
all cars... (otto cycle petrol /gasoline)
hot Air comes from hot water , in the engine,
so the first check is that the coolant does hit 180F and hold.
if not the thermostat in the engine is toast.
ok 180F , hot motor.
next ,some cars have a water valve for the heater coil
(alldata dot com, read the manual)
if the valve or its dash control to it is broken then it sticks closed.
other cars have no valve and they only block the core (bypass) the air to make hot and cold.
that too is a control. there are 3 types used, cable, vacuum and electric. on all cars.
what you have , is based on YEAR and options.
the book shows how to fix this. me ,just look at the controls.
if there is a cable then I make sure the cable works.
The heater has what are called damper, (flaps)
they open or close.
and if you have A/C more.
if the engines is hot. my guess, is the bypass damper is stuck
in the bypass mode. (fresh air only)
the best way to work on any car is RTM
you do that because these parts vary radically by year. and make.
alldata dot com is the solution , under HVAC.
Oct 07, 2013 | Pontiac G5 Cars & Trucks
Eden pure starts blowing hot air and then turns cold
I recently fixed this issue for a family member on this exact model, the same issue, it would heat fine for 15 minutes and then cold blowing air would follow afterwards non stop, and when we powered down the unit and restarted it, it did the same exact thing. ( What worked for me ) was ordering a new " Thermostat " which is a white rectangle looking plastic thing with 2 blue wires coming out of it, you can find You-Tube video's showing you how to remove the Eden-pure gen3 cover housing easily, my total cost of this do it yourself repair was just under $20 as of 10/10/14 your cost could vary depending on different factors.
1st...unplug the unit....duh ! lol
Once the housing is removed, look at the top of the unit and locate the 2 blue wires coming out near the front, remove the 2 top screws holding in the thermostat, gently pull out the old thermostat but don't disconnect any blue wires yet, put the new thermostat in facing the exact same way as the old one, re-tighten the 2 screws, next follow one blue wire ( One is longer than the other ) to its location on the block, determine if its the shorter or longer wire, disconnect just 1 wire with a Phillips screw driver, and replace it with the like sized blue wire from the new thermostat, tighten but not over tight ! next do the same for the next blue wire on block.
After thermostat is secure and wiring is secure, put the cover and panels back together......and plug it in and test it again....... Hope this works for you as it did for me.
Good Luck !
Oct 12, 2012 | EDENPURE MINT A3705 Infrared Remote...
My A/C is not blowing hard
That high pressure rest button is most likely it(A breaker from the wind/mess), try resetting it.
Aug 11, 2009 | Ruud UAKA037 Air Conditioner
Our air conditioner unit turns on but just blows hot air
our unit is realy a coleman unit but You did not have that listed.
In any case it started back up again and I was so releaved as it was at least 103 degrees yeasterday. But i haove a feeling this may not be the end of it .
I may need your service at a later date.
Thank you for your quick response.
Jul 29, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Brick Air blowing hot air
if you hear the compressor turning on,no heat, the coolant has leaked out. if the compressor doesnt turn on, its a control issue.
Jul 25, 2009 | Heating & Cooling
Climate control does not blow cool air. When I turn the temp down there is no change in air temp. It blows full hot air. Sometimes I can give the dash a smack with my hand and it will blow cool air, but...
you going to have to tear the dash apart (ac control panel) to see why your switch is not working. The control valve unit works on vacum systems and you need to find out where is leaking or the hoses is old and broke off. If your ac compessor still working and blowing cold air but does not adjust the temperature, it will be in the control valve. Is very easy to fix if you locate the leaks or a bad valves. hope that help some.
May 14, 2009 | 1991 Buick LeSabre
Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Apr 25, 2009 | Heating & Cooling
AC Wall unit is blowing hot air
Bit difficult? Brand/type of this AC?
Can't see what controls what from here.
Your fan works, but I can't see your compressor working to compress the freon (or what ever is in there).
So give some more details about electrical connection.
2 / 3 phase /grounded?
Suppose the unit is disconnected now and thawed up?
Apr 17, 2009 | Heating & Cooling
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Fedders Y Chassis AEY12F7E Air Conditioner Logo
90 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
