Question about Acer TravelMate 4101WLMi Notebook
Having probs coming out of hibernation and boot up. This is also intermittent as well. Suspect the connection from hard drive to motherboard. This problem continues even after change of hard drive and re-build. Tried having an inspection of the physical connections but very difficult to get at the area to see clearly. Tried getting local pro advice - twice - but not resolved. Any ideas please Gary
  • gazathebrave Feb 07, 2010
    roger - trying now - tks
  • 11,896 Answers
I do not recommmend using hibernation. I do know why they made this because it messes up everyones computer that uses that option. Go to control panel, display option, screen saver, then power options. Turn OFF hibernation, then just set your screen and Hard discs to turn off when you want them too. You do not need hibernation enabled to use these other options.
Posted on Feb 07, 2010
  • 542 Answers
Check whether you have free space available for hibernate as mentioned in hibernate options in power settings. Also check whether any BAD sectors are there in HDD. run chkdsk /f in command line Or run scandisk.
Leave a comment for more assistance. Also give your valuable feedback/rating on the same.
  • Rajesh Pai
    Rajesh Pai Feb 14, 2010
    I didn't receive any update from you? Hope your problem got resolved!!!
    Revert back for more assistance and give your valuable feedback/rating for the solution provided.
    Thank you for using Fixya.
***a black screen appears on my acer telling me... check cable connection! PXE-M0F: Exiting Inetel PXE ROM. No bootable device --
Sorry to hear that. It sounds like your motherboard is having trouble finding your hard drive. When the BIOS screen comes up, enter setup (I believe you press F2 for Acer motherboards). There should be an entry for boot order. Make sure that the hard drive is in the list and selected to boot. If it is in the boot order list and it still won't boot from it, your hard drive may have failed. Take it to a PC specialist and they should be able to recover the info from your hard drive.
May 10, 2011 | Computers & Internet
GA-8I848P(-L) Motherboard won't boot. Was an intermittant problem as it would occasionally not boot but would be ok after a reseat of memory or a period of being off. Now it no longer boots. Have changed...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 19, 2011 | Gigabyte GA-8I848P-G Motherboard
INSTALLED NEW MOTHERBOARD FROM ASUS A7N8X TO P5S800 NEW BATTERY BIOS SCREEN COMES UP ONE LONG BEEP CONFIGURED TO BOOT FROM HD BUT ALL IT DOES IS GOES BACK TO BIOS SCREEN MAYBE JUMPERS ARE INCORRECT HOW...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 13, 2010 | ASUS P5S800-VM Motherboard
I have a lacie big disk extreme + 2.0 TB. I am using Win XP Home. Recently, I have been having problems getting the drive to boot. According to windows, I have about 850 GB of drive space left, so I don't...
> is this a problem with ... my PC?
Try connecting the drive to a different PC.
If you have the same (intermittent?) problem, then it is NOT your PC which is at fault.
I suspect that your unit is about to _permanently_ fail.
Make a backup copy of all your files, before it does.
Then, exercise LaCie's warranty to get it replaced.
Oct 06, 2010 | LaCie Computers & Internet
Hard drive not found and operating system not found
I would try booting from another device (flash drive, cd, or external hard drive). If you are able to do this, then you know that the problem is isolated to the motherboard's connection, to the cable connecting the hard drive and the motherboard, and/or to the hard drive itself. If you still cannot boot, the you may be having bigger problems. These problems could be with your BIOS.
Feb 27, 2010 | IBM ThinkPad T20 2647 Notebook
Tecra m8 boot up problem
The true test here is, can it boot into the BIOS every time. If it can, then I suspect your getting ready to have a hard drive failure. Intermittent boot failures and non-start-ups are usually caused by a faulty hard drive. If it was your boot menu or boot loader, then it would never boot period. I would suspect the hard drive overheated and is damaged, or there are damaged sectors on the drive that contain some of your windows files.
Sep 25, 2009 | Toshiba N97842 13.3 TECRA M8-S8011 INTEL...
Intel DSX58 MOTHERBOARD AND COREI7 when boots wil show no hard drive in adapter 1 but the goes on to boot and show hard drives in bios boot up also wont boot if external modem connected to usb
go to bios mode and reset all setting to their defaults, and then restart. and the prob with usb during boot is still common.
so take care
good luck
shafky
Jun 12, 2009 | HP (P2074-69003) Motherboard
My hard disk goes hang when it boots the bios and cannot detect it. but my hard disk is still running.
I have a similar problem with an 80 gb drive in a Compaq. I've isolated it to the cable or the connector on either the motherboard or the drive. Try unplugging the cable at each end, then plugging it back in. Reboot. If it finds it and works normally, you have 1) a bad hard drive cable 2) a bad hard drive controller socket on the MB (bad MB :-( ) or 3) an intermittent connector on the hard drive. 1 is easy. 2 and 3 are problems. Try a different drive and see if it boots reliably every time - if so, suspect the drive. If its the MB, probably time to UPGRADE.
Dec 04, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Slow booting
check your start up files what gets preloaded get software like reg cure it will show what is been loaded on sartup
Nov 16, 2007 | Zerus Intel Desktop Board D815EEA...
Im having serious probs here
first, ensure that only one master hard drive is connected (also disconnect cdrom(s). Next, at startup press the key (DEL or F2) to BIOS screen. then make sure that only the master hard drive in position 1 is listed or choose AUTO detect. now reboot and report if any progress. If no further progress, then master hard drive has failed somehow, but to be certain, try that drive on another pc as a slave just to test spin-up.
Sep 08, 2007 | AOpen MX46L Motherboard
Acer TravelMate 4101WLMi Notebook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
