Question about RCA L42WD22 42 in. LCD Television
Have an RCA L42WD22, recently stopped working. When you plug it in, the green status light comes on in the front for about 20 seconds and then goes to a flashing red five times over and over. Found one leaking capacitor, replaced but unit still not working. LED starts flashing immediately when the backlight turns on. I can see the backlight come on for just a moment then it goes to flashing the diagnostic code.
  • jb97981 Feb 07, 2010
    The leaking cap was on the PS board; on my model the PS and inverter are together. Did you get anything more descriptive than "panel error"? Thanks for the help so far Rusty
  • 201 Answers
Found a post online saying 5 blinks is a panel error. Bad panels you have to replace. That could explain the leaking cap you found since bad panels can cause power supply or inverter damage. Where was it located on power supply or inverter? some models they combine the 2 together on one board. There is a small chance that the main board is flashing that error only because the board got damaged not because the panel is bad. I'd google " l42wd22 parts" and look for a deal on which board had the damage. If it is the panel its cheaper to buy another TV. Good luck!
Posted on Feb 07, 2010
    President:
  • 2,923 Answers
I think you have a ADC that went bad and needs to be checked out. You need to have a service adjustment done by your Service Tech. You just can't fix the ADC without clearing the buffers, and all the other procedures needed to fix this TV. I think your TV repair persons are probably just going over the complex procedures to fix your TV.
Good luck and have a great day!
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
My RCA L42WD22 flat screen will not power on after being turned off for an hour. When I tried to power it on the green light comes on, and I have a flash of a picture, then a black/blank screen & a...
Take the tv apart.The tv power supply board,that the board,have power a/c cord plug into it.That the power supply board,check component parts like capacitors,see if it leaking gases,these capacitors are dead.Capacitors they'll alway bulges up on it tops or puff up on it tops.Have tools like soldering iron and solders?Know basic electronic and soldering?Replaced these dead capacitors will get power to ur tv back.Or tries websites like Shopjkimmy.com to buy a whole refurbish power supply board for the replacement.
Jun 15, 2011 | RCA L42WD22 42 in. LCD Television
No signal.i think it overheated. i turn on and light goes green for a second then red flashing light but no picture
You has a bad power supply.
Inspect/replace all blown capacitors on the power supply board.
Aug 11, 2010 | RCA L42WD22 42 in. LCD Television
Blinking green status light
Unplug for a few minutes then plug back in to try to reset it. Sometimes it could take as long as overnight before pluging back in to reset. Number of blinks is usually a trouble code.
Mar 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Green to red blinking light when plug in rca lcd
It is the capacitors on the power supply...They blew on ours...took it in a they replaced 7 for less than 100.00. Common problem with this tv because it gets hot. Hope that helps.
Nov 20, 2009 | RCA L42WD22 42 in. LCD Television
No picture, status light flashes yellow
display comes on works 15 seconds no power just leds green
Sep 18, 2009 | Mitsubishi PD-5010 50 in. Plasma...
Green light on front comes on for 15 seconds then goes off
I've repaired 3 of these already. The only solution was to replace the Main board. I got all of them at " ShopJimmy.com. they came out of scrap sets, they give you a warranty. It was cheaper than buying new, of which none of my suppliers had them in stock, they were on factory back-order. (RCA)
Apr 24, 2009 | RCA L42WD22 42 in. LCD Television
I have 2 comtrend dh-10pf powerline adapters. one of the adapters status is a red flashing light and the AP light and the Ethernet light are blank. the second powerline adapter has a solid red status...
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Jan 28, 2009 | Computers & Internet
RCA d52w20 will not come on
sounds likje the flyback those sets are famous for the flybacks needing replacement.They dont always blink 3 times when the flyback fails, often they justrefuse to power up.
Sep 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA L42WD22 42 in. LCD Television Logo
297 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
