Question about Bosch Dishwashers
The bisch sgu3002sk/01 does not wash clean.
The bosch sgu3002sk/01 does not wash clean.
there are rest of soap and dirt on the glass and plates.when she start to dry.have been running a dischwasher cleaner,with no result.have also cleaned the rotors and spreader.do you have any tip,?
  • 677 Answers
SOURCE: Bosch SHX46A dishwasher
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
Posted on Apr 10, 2008
  • 677 Answers
SOURCE: dirty glasses
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Posted on Apr 27, 2008
VOTIT
  • 2071 Answers
SOURCE: Subject is Bosch dishwasher SHU6800.
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Posted on Aug 17, 2008
SOURCE: Dry Dishwasher Soap Still in dispenser after wash.
so here it is...
get a screw driver (you may need a "star" head driver as well), get in there and take out all that you can and clean it (it all comes out pretty easily)...you will find a lot of undisolved soap and hard water build up...rinse it, scrape it, vacuum it...just get out as much as you can...keep note of how you took it apart so you can put it back together...then put 1/2 to a whole gallon of vinegar in and run a cycle (hi-temp if you have that option)...if it was like mine most of your sprayers were gummed up and the water just wasn't moving through the machine...
to avoid this problem...use half of what you have been using of your detergent...and only fill the "pre rinse" section if you are doing pots and pans....and then only fill that half way as well.
after that run a few cups of vinegar through on an empty cycle once a month...
whole job (not including the wash cycle) 1.5 hours...
Posted on Aug 31, 2008
  • 27 Answers
SOURCE: water standing at the end of the cycle in my Bosch dish washer
where is the water is it visible above the filter plate or is it in the bottom of the sump
if its in the bottom of the sump thats normal it will always leave water in the sump
Posted on Mar 13, 2009
How to clean washing machine
Put the machine on a 90 degree wash with nothing in it, wait until it has filled and then pour three quarters of a cup of neat thick bleach into the soap drawer.
Put an old towel under the machine. The bleach will foam up and foam will come through the soap dispenser and all over the floor like a scene from a 1950's "The Blob" movie (The foam will also coat the entire inside of the machine as a result and kill any smelly bacteria).
Once the cycle has finished, throw 4 dishwasher tablets into the drum and put it onto ANOTHER 90 degree wash. At the end of these treatments, you should be a lot closer to a clean machine
Jan 30, 2016 | Bosch Washing Machines
How do I remove soap part from Bosch washing machine?
There are 2 hidden screws that you have to hunt to find
Jul 17, 2014 | Bosch Washing Machines
I have tried EVERY piece of advise offered...clean both arms, filter at bottom, rinse all crockery/cutlery before placing it in Bosch, use a dishwater-cleanser on weekly base, check the water pressure, got...
If it is just glasses and coffee mugs that it refuses to wash maybe you should stop trying to wash these items in this dishwasher.
Could it have to do with the location where you put them? Maybe the direct water jet has a blind spot there while the reflected dirty water concentrates there. That may have to do with the shape of the vessel. I am just trying to make sense out of this unusual behavior. (I am thinking of some remarkable properties of parabolic and elliptic surfaces.)
Dec 22, 2013 | Audiovox Bosch 718 World Cellular Phone
Clean glass door
  1. Clean the area as normal to remove any superficial dirt and dust.
  2. Next, apply the chosen cleaner using a sponge or soft cloth.
  3. Allow it set for a few minutes. (if applicable)
  4. Use the hot water to gently scrub the area and remove the cleaner.
  5. Repeat until it is cleaned completely.
  6. Rinse with clean water.
Mercedes wheels
May 31, 2012 | Stoves Kitchen Ranges
I have a Bosch Nexxt washer, model number WFMC 32000C/01. Yesterday I noticed the fabric softener was still in the dispenser after the cycle was completed. I cleaned out the dispenser and ran another...
Could be the fine holes in upper dispenser are blocked. Remove soap dispenser drawer and use a washing up brush to clean upper dispenser, replace drawer & test. If not could be upper dispenser or inlet valve.
Jan 10, 2011 | Bosch Washing Machines
Says model # shu9915 not cleaning well .leaving residue on glasses almost easier to wash by hand and some food stuck on plates etc. and soap tablets not dissolving completely
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 14, 2010 | Bosch SHU9950 Dishwasher
Cutlery is cloudy and dirty, some food is dried onto knives and forks. Cups and glasses are cloudy and not clean on inside. Coffee or tea stains are not removed. Plates and soup bowls seem OK , and water...
they must have changed the way they treat the water in your area. those spots are caused by hard water. www.dishwasherfilter.com has a product out for this problem. it filters the water going into your dishwasher leaving them spot free and crystal clear with every load. you will love the way your dishes look.
Mar 21, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Water standing at the end of the cycle in my Bosch dish washer
Mar 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
76 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
