Question about HP PhotoSmart C4480 All-in-One Printer InkJet
Can scan & copy, but can't print
I am running Windows XP SP3. IE 6. I have a HP Photosmart c4400series installed. It scans & copies, but doesn't print. Have tried LPT1,USB, Dot 1,2 & 3 & virtual printer ports, but nothing works. It worked up to 3 months ago, then stopped printing. I have uninstalled it & reinstalled it 6 times so far since October 2009. It doesn't seem to install correctly. It stops at the install last step to configure at 96 %. Now the hour glass keeps coming up & tries to install or continue. I have been given many instructions as to fix this, but nothing helps the printing problem. Must be installed or the scanning & copying wouldn't work, right? It has to do with the wrong settings for the printer somehow.Can you help, please?
  • 518 Answers
It may not be the settings, it could be an outdated driver, if you are using the cd too install software, try downloading the software from hp website.
Posted on Feb 07, 2010
Why won't my HP Photosmart 5510 copy?
first you confirm scanning is working or not if it is working fine there is no issue with printer, if it is not working problem found with scanner assay you need to contact hp service center....
May 04, 2014 | HP Photosmart 5510 Wireless e-All-in-One...
Can you just give me a link or quick advice on scanning with HP photosmart c5180? I would like to to scan and save to disk/save to laptop.
Scanning with HP Solution Center Software in Windows
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&cc=us&lc=en&dlc=en&product=1153481&tmp_track_link=ot_search#N43
FROM THE MANUAL ON PAGE 14 http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf Scan an image You can start a scan from your computer or from the HP All-in-One. This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning. ? On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running. Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software. ? On a Mac, the software is always running. Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One. To save a scan to a memory card 1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One. 2. Load your original print side down in the right front corner of the glass. 3. Press the Scan Menu button. 4. Press to highlight Scan to Memory Card, and then press OK. The HP All-in-One scans the image and saves the file to the memory card in the JPEG format. To scan a photo and reprint it 1. Press Reprints. 2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following: To reprint your original photo using the default print settings ? Press Print Photos. To change print settings before reprinting your original photo a. Press OK. Basics Guide 13 HP All-in-One overview b. Press or to highlight a paper size, and then press OK. The paper size choices available vary depending on your country/region. Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages. c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK. The HP All-in-One scans your original and shows a preview of the photo on the display. d. Press OK to display the selection menu. Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies. If you want to edit the photo before printing, press to highlight Edit Photo, and then press OK. e. Press to highlight Done, and then press OK. The Print Summary screen appears. f. Press or to highlight one of the following options, and then press OK. Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and time stamp on your photo. By default, the Paper Type is set to Automatic and the Date Stamp setting is set to Off. If you want, you can change the defaults of these settings with the Set New Defaults option. Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and wasting paper and ink on potential mistakes. Print Now Prints your photo with the size and layout you selected. To scan to a computer 1. Load your original print side down in the right front corner of the glass. 2. Press Scan Menu. 3. Press to highlight Scan to Computer, and then press OK. 4. If the HP All-in-One is connected to one or more computers on a network, do the following: a. Press OK to select Select Computer. A list of the computers connected to the HP All-in-One appears on the display. Note The Select Computer menu might list computers with a USB connection in addition to those connected through the network. Chapter 1 14 HP Photosmart C5100 All-in-One series HP All-in-One overview b. Press OK to select the default computer, or press to select a different computer, and then press OK. The Scan To menu appears on the display, listing the applications on the selected computer. If the HP All-in-One is connected directly to a computer with a USB cable, proceed to step 5. 5. Press OK to select the default application to receive the scan, or press to select a different application, and then press OK. A preview image of the scan appears on your computer, where you can edit it. 6. Make any edits to the preview image, and then click Accept when you are finished.
Jun 05, 2011 | HP Photosmart C5180 All-In-One InkJet...
Will not scan or copy windows7 64 bit
If the machine won't make a copy (by hitting the copy button on the front panel) it may be a hardware issue.
If it will copy, but not scan - it's likely software related, as many devices have issues with the 64bit version of Windows 7 (and XP for that matter).
You may try installing the 64bit versions of the drivers and software. I've included the link below...
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4063&lc=en&cc=us&dlc=en&sw_lang=&product=441240
May 02, 2011 | HP Photosmart 2575 All-In-One InkJet...
HP photosmart copy function does not print with windows 7. I can print and scan with no problem.
it is the version of software that was released to be compatible with win 7. the copy feature was removed. you can try running the original install disk in a compatibility mode
right click on the setup.exe
left click on properties
click on the compatibility tab
check the box for compatibility mode, and choose Vista Service Pack 2
check the "run as administrator" box
right click the setup.exe and use "run as administrator" (yes, this may seem redundant)
Mar 27, 2010 | HP Photosmart C7280 Printer
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
Scan an image
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
● On a Mac, the software is always running.
1. Press Reprints.
➔ Press Print Photos.
a. Press OK.
Basics Guide 13
Defaults option.
2. Press Scan Menu.
Jul 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hp photosmart c6180 all in one printer will not scan or copy
The scanner bulbs ahve gone bad.U need to get it them replaced.Before that try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
Mar 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer will only print, not copy fax or scan
It is possiblethat the all in one solution software you used in XP doesn't work with Vista, after some update or other. You did the right thing by uninstalling and reinstalling. Make sure you have the correct driver from the HP site..
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP C6180) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have a HP 3180 and it prints just fine but will not scan and I have Windows Vista.
The all in one solution software you used in XP doen't work with Vista.
3. Highlight your scanner icon (ie HP C3180) then click import.
Hope that helps.
Chris (ziraffa)
Jan 03, 2009 | HP Photosmart C3180 All-In-One InkJet...
I have a Photosmarat 2710, and my computer runs software Version X (not Vista). I can copy and print but not scan. When I try to scan it says I need to install or run HP software. The only software I got...
If in case the software is completly installed then try the steps mentioned bellow.
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Dec 23, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
211 people viewed this question
Seeker5211
Seeker5211
