On a Mitsubishi VS-50VF1, I can't adjust the color alignment completely. When I go to the convergence menu, the blue line won't move up or down, yet it will move left and right. Red moves in all directions. Green doesn't move at all (is that proper on this model)? Any advice?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 07, 2010
62" mitsubishi tv wavy picture
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 07, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi RPTV has a blue shadow/image alignment problem
  • Screen looks 3D
May 23, 2010 | Mitsubishi WS-65809 65" Rear Projection...
The picture arced and looks 3D. Plus the screen
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 10, 2010 | Mitsubishi VS-50607 50" Rear Projection...
PICTURE HAS BLUE AND YELLOW SHADOWS AND cc is in yellow not white vs 50609
  • Screen looks 3D
Mar 11, 2010 | Mitsubishi VS-50605 50" Rear Projection...
Hey I have a mitsubishi vs-80803 i have picture but it is a bit bowed on the right side and bottom of picture (black curvature space showing no colors or picture) maybe the convergence needs to be reset?...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 05, 2010 | Mitsubishi VS-80803 TV
Mitsubishi WS55859, was getting 2 and 2 blink, replaced the pico fuses and convergence chip - 3 times, each fix worked better than the next but evenually failed - now have it working, trying to adjust...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Mitsubishi WS-55859 55" Rear Projection...
No picture and the colors are distorted
  • Screen looks 3D
Jul 27, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi WS 55711 convergence problem only with some inputs
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
Nov 12, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Convergence
  • Screen looks 3D
Oct 09, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
