Question about Vanguard International Blue Flame - Large Open Flame Mid-Size Heater
I have 2 fireplaces.. 1 always starts out when I ignite it with the Yellow/orange flames on the first logs/rocks - then within a few seconds the flame jumps and sits on the back log with a huge blue flame...Is that normal?
  • Vanguard Master
  • 3,238 Answers
Hi it might be a slight blocked burner could well need a service ?
Posted on Feb 07, 2010
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
I have a Rheem Furance that has turned off. Just a few hours ago the main fan turned off. The Furnace doesnm't light even the draft fan does turn on and then the main fan blower motor turns on. I can hear...
You will need to reset the furnace by turning the power off to it. Then as the furnace tries to light, watch the LED for blinking. Hopefully it will give a code other than 1. Try checking the air filter for blockage, make sure all hoses are free of moisture and any drains are not blocked. Check the air intake and exhaust pipe for sags where water could block it.
The sequence of operation is this:
Thermostat calls for heat, the LED may blink telling you it registers the call. The inducer (exhaust) blower starts closing contacts in the pressure switch (small disc shaped thing), the igniter glows orange (seen thru a small window high up on furnace front), gas valve opens allowing main burner to light, flame travels to all other burners, flame rod senses flame within a few seconds and keeps gas on. Room air blower starts within 90 seconds.
Any deviation or delay in this sequence and it goes into lock-out.
Jan 22, 2011 | Heating & Cooling
Not staying lit
Remove the front panel and tape down the door safety switch so the unit can turn on when door is off. Turn up thermostat to make sure there is a call for heat. The circuit board should indicate a call for heat with either a blinking light or a solid light. Then the exhaust fan should turn on clearing the venting from any fumes. When the fan has ran for a few seconds, the igniter should start glowing orange. After it reaches a predetermined temperature, the gas valve should open with a click. The flame will start at the burner closest to the igniter and travel away from the igniter. There is a small flame rod located in the flame path on the last burner that tells the circuit board it feels the flame. If the flame goes off within a few seconds of starting, you have a dirty flame rod. Clean it with a scotch-brite pad. Once you get the flame to stay on for 90 seconds or so, the room air blower will turn on. If it tries 2 or 3 times to start but does not, the circuit board will record a code and display it with a blinking light. Look on the door panel for a wiring diagram. There will also be a Diagnostic chart that will tell you what the pattern of blinking lights represent.
Good Luck!
Nov 23, 2010 | Goodman GMS80453ANA Open Flame Mid-Size...
Fireplace will start but shuts off in about 30 seconds
Here's a few things to look for. After you light the pilot and turn on the burner, look at the pilot flame. Is it still a strong blue flame and it is still heating the thermocouple? If the pilot flame is a lazy yellow, it may not be able to keep a good enough flame on the thermocouple to keep it hot. The solution? Turn it all off and let it cool down. Take a can of compressed air, like you use to clean computer keyboards, and using the attached straw, blow out the dust or spider web that's partially blocking your pilot orifice. Where the pilot flame is usually lit, blow right down that flange, as well as through the air hole that is on the side of the pilot assembly. If you do it right, the pilot flame should be a nice and strong blue color. Another thought. Is this a vented or unvented fireplace? If it's vented, make sure it has the oxygen it needs to burn by checking for blocked vents or opening a closed fireplace fume above it.
Douglas
Nov 19, 2010 | Desa International CGCFTP Compact Heater
I turned my propane fireplace on and it set my smoke alarm off. We have lived here for three years and never had this problem before. Please advise.
check to see if the flame is pure blue. if not you have incomplete combustion letting CO or CO2 into the room. The flame will look yellow if this is the case. An orange flame indicates dust and dirt around the burner assembly. If it is yellow, the should be 1-2 set screws on the back of the burner assembly that will let you adjust the primary air being mixed with the propane.Adjust until you get blue flame and tighten set screws.
Dec 05, 2009 | Vanguard International Blue Flame - Large...
The pilot is off and I don't have the manual. How do I start the pilot to turn on the logs
You will need to find the gas valve. Open up the lower section of the fireplace and look foe a small cube of aluminum with a knob on it that says On-Off-Pilot. Turn the knob to the Off position by lining up the word with a small dot or line indicator on the body of the gas valve. Then turn the knob to the Pilot setting. You will know when you are in the correct setting because you will be able to depress the knob into the gas valve body. Hold the knob depressed and click the larger red button. It will snap so don't be startled. Continue to hold the knob in while looking between the logs for a blue flame. If you don't see one, keep snapping the red button. Once you see the flame, continue to hold the knob depressed for 30 seconds or so. Release the knob and make sure the flame stays on. If it does not, repeat nthis procedure and hold down the knob for 45 seconds. If the flame continues to go out, you need a new thermocouple. Once the flame stays lit, rotate the knob to the On setting. The main burner should start within 15 seconds.
Nov 26, 2009 | Leisure HOMEPRIDE Electric Fireplace...
My heat n glow fireplace comes on fine with all burners running but shuts off about 5 seconds later. it seems the sensor that detects a flame thinks the fire has not started and shuts down the gas. Is...
You may have a few sensors, one may be a thermopile that energizes the pilot. It is a very thin but long bulb located in the pilot flame. Then you may have something called a thermopile which is also located in the pilot flame that energizes the main gas valve. It is a larger diameter bulb and will have metal wrapped wireg going to the gas valve. If the pilot stays on but the flame goes out under the logs, change your thermopile and look for a bad connection at the gas valve or switch. If both the main burner and the pilot goes out you may have a gas valve problem or a plugged vent pipe. If the flame just disappears it is most likely a gas valve. If the flame changes colors and lifts from the burner, that is a sign of a plugged vent. Good luck.
Nov 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Vanguard International Blue Flame - Large Open Flame Mid-Size Heater Logo
64 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
