Question about Crosley CDE6000 Electric Dryer
Installed new timer forget to mark one wire on timer
I have one wire that is a hot wire and can not find a place for it on the hot side of the timer
  • drdill Feb 22, 2008
    Now I have no heat
  • coreysmom Dec 26, 2008
    wont heat to dry clothes
I was just looking at the site and thought I could help. I know it has been a long time since your post but here it is. If you only have one wire left, put it in the last position remaining to tie/clip into. If there are more than one remaining, investigate for wear on the connections. There should be some scarring where you removed the old one. Match up the old with the new. Hope this helps.
Posted on Nov 26, 2008
Wall light switch timer inline with Extension cord GE 15313
Black to black (hot), Green to green (ground) and the only one left is of course white to blue. The (neutral) white wire can be many different flavors (blue, red, orange, brown, etc.).
If the outlet your plugging into (or controlled by the service panel breaker) is 15 Amps use a minimum of 14 gage wire (or 12 gage is even better), if its a 20 Amp outlet use 12 gage wires (or 10 gage). Don't use a 16 or 18 gage wire because it may get hot and start a fire because its undersize for the Amps.
Nov 13, 2012 | Hardware & Accessories
Im trying to change out my automatic sprikler timer, the new one is Intermatic model T8845PV. Its an old house I have two hot wires going in to the old timer, and I only see one spot for my hot wire in the...
Open following links for resources:
If you have 2 hot wires, then you have 240Volt circuit from breaker box.
T8845PV is 120Volt timer.
How to wire for 120Volt: Use one hot wire to connect to LINE terminal. Cap off other hot wire. Then connect bare ground wire to terminal marked NEUTRAL.
This is not code, but it will work until you have time to run 120Volt line from nearby 120Volt outlet.
Read about 120 and 240Volt circuits
T8845PV is 120Volt timer, made to control 24Volt sprinkler valve.
Inside the timer, there are two wiring terminals marked LINE and NEUTRAL
120Volt cable from circuit breaker has black hot wire and white neutral wire.
Connect black hot to terminal marked LINE
Connect white neutral to terminal marked NEUTRAL
The yellow wires are 24Volt output.
Yellow wires connect to sprinkler valve.
Do not connect 120Volt to yellow wires.
This timer does not have terminals for rain sensor:
Jul 31, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Two wall sconces: pulled out old dimmer: 2 sets of romex and no ground. white wires wired together; two black wires, one hot. Installed new dimmer: on-off OK but only one light dims with buzzing. Dimmer is...
Okay. This is going to be easy.
You're in the middle of a circuit and that's why you have 2 Romex'.
The HOT black is the line side. It comes from the panel. The not-hot black is the load side. These 2 blacks go to the brass screws on the switch. The whites tie together and don't go to the switch, UNLESS there are 2 silver screws on it, then they go there. Watch the switch to see if it's clearly marked for LINE and LOAD. In that, the HOT black goes to LINE and it's white companion (from the same Romex) goes to the LINE silver screw. The 2 from the second Romex go to the screws marked LOAD.
In the sconces, you're going to find one that has 2 sets of wires and the other has one set. (I'm betting) The one that's working better, is the first one from the switch wiring.
Open the working one with the switch turned off, of course. Disconnect the wiring going to the second light. Make sure the first light works just like you want it to.
Now, take the 2nd sconce down and see if the wires are in the right places. White to white, black to black, grounds in place, protecting wires from the others. If all that looks fine, reconnect the wire running from the first light to the second. Even though these are still opened up. turn on the switch and see if the 2nd sconce works.
If it's still buzzing, try to determine exactly where the noise is coming from.
Some dimmers won't work with florescent bulbs, some don't like halogen bulbs. SOME don't like the energy-efficient curly bulbs!
The box/instructions for the new dimmer may point out what it's NOT compatible with.
If everything's connected correctly and there's still buzzing, I'm guessing that there's some mis-match between the new dimmer and the lights.
Feb 02, 2011 | Leviton Decora Light Dimmer Switch
Need wiring diagram SPST power to timer timer to light . two screws marked timer 1 nc 1no 1 com
Here are two possible solutions, since timers are made different ways:
1) Diehl timer has 5 terminals
Drawing below shows wiring for Diehl SPST:
2) Your timer might also be wired as follows:
Two screws marked 'timer' are for 120Volt Hot and Neutral that power the clock motor (in drawing above, these are terminals 1 and 2).
Another Hot wire connects to COM. (in drawing above this hot wire shown connecting to terminal 3)
Load wire connects to terminal NO (in drawing above this wire shown connecting to terminal 4)
3) NO is Normally-Open turns ON when tier turns ON
NC is Normally-closed is ON all the time, EXCEPT when timer turns ON. So NC terminal turns OFF when timer turns ON.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 31, 2010 | Diehl TA-4150 24 Hour Electromechanical...
I have a red wire in the box. What does that get connected too on the switch. Right now I have the black swithc to the black hot; white switch to white neutral; red switch to black hot; and no place for...
This page has a schematic under the picture of the item marked click here for other views.
White supply connects to white on the switch and the white going to the light.
Black supply connects to black wire on the SWITCH.
Red wire on the switch connects to the black wire going to the light.
Green grounds all connect together.
Dec 18, 2010 | Woods 59028 Programmable Timer Switch...
My lighting timer seemed to have burnt out. We thought that the switch was bad, because light was out - replacement one does not work either.
If I understand correctly you installed a new timer and it does not work.
You posted under EJ351 timer.
Problem sounds like it's electrical instead of timer.
1) Check electricity at wall box where timer is located. Remove both wires from timer. Separate wires for testing. Turn on power. Test each wire to bare ground wire. If box has power, then one wire will light up tester. This is Hot wire. Next test Hot wire to white wires inside box to make sure circuit can be completed to the neutral. If box doesn't have Not or Neutral then check other local boxes on same breaker to find where loose wire is.
2) Check that Load (light, fan, motor) is not burned out ... you can do this by putting regular light switch in place of timer. Box must test positive for Hot and Neutral wire.
3) Check that breaker is delivering 120V. Test from screw on breaker to any bare copper wire inside breaker box. Tighten screw on breaker. There is a white wire associated with black wire on breaker ... track this wire over to neutral busbar and make sure it is tight.
4) If electricity checks out, then timer is suspect. You may have gotten bad timer.
Nov 26, 2010 | Intermatic Programmable 24 Wall Switch...
I found out the intermatic did not work as usual, just change new battery, i try to program the schedule, but it did not work.
If you have a battery operated timer, it is probably the Intermatic ST01C or EJ500.
The link above will help you identify your timer.
As a general rule, if a new battery does not revive the Intermatic timer, then timer needs to be replaced. Make sure you have electricity. And be sure to mark your wires before removing timer. Mark the black wire that connected to timer-black wire. It's the hot wire from breaker box.
You can replace with same model and brand so your wiring is EZ.
The ST01C and EJ500 are 7-day timers with up to 40 programs per week. They each connect with 2 wires. Black and Blue with red wire capped off. Just mark your wires before you disconnect old timer. And then reconnect new timer wires just as old timer was connected. The red wire is capped off.
The Aube T1032 is also a 7-day timer with 7 programs per week. This timer connects a bit differently. It connects with 3 wires. You put the black where old timer-black wire connected. And then you connect the red and blue together and connect them where the old timer-blue wire connected.
Other timers require wiring that is bit different, but the page link above shows the wiring ... and you can re-post another question any time >>> or respond to this answer.
Keep us posted.
Oct 22, 2010 | Hardware & Accessories
Woods In-wall Timer Heavy Duty, Model #59018 -- I just installed my timer and was able program and set the time, but when I push the manual override button to turn the light on, the light flashes and turns...
Quick answer:
1) Programming steps say 'press clock key to return to current time and day'
2) Use mode button and change between AUTO & RND >> try manual override in each mode
3) Does timer turn lights on-and-off with program, or do they blink too?
4) Swap Black and Red wires
5) Try timer on light in different room, on different circuit breaker
6) Timer might be defective
Longer answer:
Woods 59018 manual does not show troubleshooting steps except 'check wiring; switch Red and Black leads; and/or reset programming'
Seems unlikely you could program timer unless timer is wired correctly ... unless there is a short of some kind.
To review wiring.
Green goes to bare ground wire.
White goes to Neutral white wire (neutral is usually 2 or 3 white wires twisted together and shoved to back of box)
Black must connect to Hot from circuit breaker
Red must connect to Load (light, fan, motor etc)
How to test wiring
Disconnect timer and set aside.
Mark each wire
Separate wires in box so they don't touch
Use ordinary tester (you can tape tester leads to wood sticks)
Turn on power
You should have two black wires that were originally connected to switch
Test black wires to bare ground > when tester lights up, that is the Hot wire.
The other black wire goes to Load
Now you want to find the neutral.
Test the Hot black wire to white wires in box.
When tester lights up, that is neutral.
If everything checks out, I guess timer is defective.
Sep 29, 2010 | Woods InWall 7 Day Digital Programmable...
How to wire to attic fan? Old Sping loaded timer has two wire connections Marked LINE and LOAD . There are two Romex- Three wire cables with Black , White (Common) and bare (Grd) wires coming into this box...
OK, your new switch will require the use of a neutral wire. So you will have to do what is called a pigtail. You will have to twist another white wire in with your other white wires to attach your neutrals to your switch. Note: white wires are called neutral not common. Hook the wires that were originally hooked up to your LINE to your HOT (Black) on your new timer, and the what was originally LOAD up to the new timer LOAD. SO as far as wiring all that will change is your white wires that need to attach to your timer NEUTRAL.
Jul 10, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Clock does not turn on
make sure the small white wires coming from the clock itself are installed on the "line" side of the terminals, those power the clock. If not, the switch will power the pump but the clock will not run.
Sep 15, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Crosley CDE6000 Electric Dryer Logo
53 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
