Viera wont hook up 2 my set top box video reorder
Viera tv wont hook up 2 my set top box video reorder
SOURCE: Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Posted on Nov 20, 2008
  • 2187 Answers
SOURCE: My Phillips 32pw8759 TV screen is Permanently blank
There might have been a power surge that had damaged the two units. For the reset, having the tv unplugged overnight should do it. If it does not work you may want to check the power supply of the tv for leaking capacitors or burned resistors or loose solders.
Posted on Aug 15, 2009
Testimonial: "Thank you for your advice I will try your suggestion to reset the TV & let you know the outcome."
  • 11800 Answers
SOURCE: My Panasonic Viera 50" 1080i
The Panasonic doesn't detect the presence of the signal on the antenna input so it just skips it. shut down the player and turn the cable box on before attempting to switch sources.
But why aren't you using the Composite RCA connection on the cable box ? Not only you would get a much better image but the tv would detect that change in the AV source and should switch by itself. If it doesn't then the control processor is faulty and the entire mainboard will will have to be replaced
Posted on Nov 05, 2010
budmrtn
  • 11361 Answers
SOURCE: trying to set up digital
The RED and White RCA jacks on the set top box are for Right and Left channel audio to go into the TV Video 1 or Video 2 input jacks of the TV. The Yellow jack is for the Video, that will go into the Yellow jack on the TV Video 1 or Video 2. If you want to use Video 1 INPUT, then all 3 jacks (RED, WHITE, YELLOW) will be use. Just match the color, they should be grouped together per each set of input on the TV.
I hope I explain it well enough.
Posted on Mar 24, 2011
SOURCE: whats the best way to install a panasonic viera tc-p50x3 to a yamaha home theater receiver rx-v371 to a panasonic blueray dmpbd75 using dishnet work hddvr set top box
connect your blue ray and your dish net with hdmi cables to the amplifier than monitor out hdmi to tv .in your dvd configuration you must make sure that hdmi audio is activated .ps not to be mean but this is a very low quality dvd because it does not have fiber optique audio output but it can still work, for your dis net it all depends on what type of digital audio output
is available , ill be honest with you this is a good job .
Posted on Dec 09, 2011
I want the steps to connect playstation 2 to my Panasonic Viera tv
I have panasonic viera led , push AV on remote end pot on AV2. It works fantastic.
Aug 25, 2012 | Sony PlayStation 2 (PS2) Console
When I use the wi-fi connection with the LAN cable provided and run the connection test, all of the tests are successful except for the Viera connection. It is saying the connection failed 006. How do I...
Viera has a set-top box in the TV and the lan wifi router can be connected to cable plant for internet. TV can also send out programs on the set-top box to other wifi receivers. Error code 006 is server failed, Panasonic had a fix on jan11, 2012.
Feb 11, 2012 | Computers & Internet
I CANT TURN ON THE CLOSED CAPTION ON MY PANASONIC VIERA PLASMA TV
I have a Comcast HD DVR set top box and had to enable closed captioning from the Set Top Box, not from the TV
Hope it helps
Mar 07, 2011 | Panasonic TCP42C2 42 in TV
Cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Mar 23, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
Oct 03, 2009 | Zenith Analog to Digital Audio Converter
How to connect Panasonic Plasma tv with satelite hookup to playstation 2
U can't hook the satelite signal to the PLaystation 2.The satelite hook up to the main in the Antana input.The playstation 2 must use the RCA cable came with the Playstation 2 hook up in any Audio,Video in put in the the tv.Tune in what input u hook up like 1,2,3,extra..use ur Playstation 2.
Aug 25, 2009 | Panasonic Viera TH-50PX80U Plasma TV
Unlock regional video restriction
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock and to set the device region free procedure of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
May 01, 2017 | Panasonic Viera TX-32LX77 LCD TV
Nov 19, 2008 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
