Question about Philips Televison & Video
Trancado red message appearing and it turns off after 10 sec
2 Suggested Answers
SOURCE: TV won't stay on
One of two things can be the problem...one the bulb is bad...two the ballast is bad. If the bulb is not bad then the ballast is...it can usually be fixed by replacing a resistor on the board itself...it is labeled R3 and is a 1000 ohm resistor
Posted on Dec 17, 2010
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
Tip
Chevy truck way to reset oil service indicator.
After changing oil on 99 and newer Chevy truck and SUV, there will be your oil change light flashing. just sit in vehicle close door, put seat belt on then turn key on but don't start. then withing 10 sec push and release gas pedal fully then message will appear saying oil change indicator reset. there you go.
on Dec 17, 2009 | Chevrolet 1500 Cars & Trucks
Big red triangle i display and beep 3 times
Is this a volvo or a saab ?? Check the levels under the bonnet first before you go any further
Oct 19, 2012 | Cars & Trucks
Need to replace Whirlpool 2322580
El motor que hace salir el hielo esta trancado Modelo N? 2322580; necesito comprar uno nuevo; favor informar
Apr 09, 2012 | Whirlpool Refrigerators
Hello, I have the Samsung ln40c550 and I have a terrible problem with the speakers hissing. I have tried different connections, and it seems like that is fixing it but it doesnt.
press exite button on remote for 10 sec until message appears select ok tv will turn off turn on tv after 10 sec plug and play seup will appear you must select home use not store demo
Mar 09, 2011 | Samsung LN40C550 TV
I cant get my phone to turn on everytime I hold the reset button the apple logo appears for 5 secs then the screen turns black.
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 30, 2010 | Apple iPhone 3G
Error sc 551
try to SP reset then lets see what code appears
SP RESET
press Clear Mode 2x
107
press Clear Mode for 5 sec or until Copy Sp appears
Press Copy Sp
Exit
Turn off machine then on after 5 to 10 sec.
Aug 23, 2010 | Ricoh Aficio 450 Copier
TV won't stay on
Jul 25, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
I am getting an error message "S545"
Fuser unit malfunction code.Check the connectors,thermistors and thermofuses.Reset the code :enter in the service mode (press total clear yellow key and pres 1-0-7 press and hold down more 3 sec.the Clear key (red C key)) turn OFF the machine,umplugged the cords wait 10 sec,plugg the cords amd turn ON the copier.
Aug 14, 2009 | Ricoh Aficio 1035 Copier
Optoma RD50 TV which shuts down on #1 fan failure
This could be a variant of, or a newer (or older) version of the "DMD fan failure" message.
Symptoms I had are, I stop hearing a fan when the message is displayed.
Then the temp LED keeps flashing RED until I either try to turn the TV on again,
Or turn MAIN power off/on again. BUT it repeats when I try to turn the TV on.
The picture appears normal until this happens ( about 15 sec.)
The solution is to FORCE a normal shutdown by hitting the TV off button
before the message appears.
You should see the power LED flashing RED/GREEN (cool down) and then RED (standby).
Apr 20, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Televison & Video Logo
51 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
