Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Green light convergence is about 2" to 3" up in the bottom middle section. Some time the above problem start after few minutes and most of the time the problem is there. I try to fix the problem by adjusting the blue and red convergence but than I have bump in the midle og the TV at the bottom side. Kumar
  • chaklashiya Feb 22, 2008
    I can can adjust the other two colors to match the green but than its like roller coster ride in the bottom middle portion of the TV.
  • 92 Answers
SOUNDS LIKE YOU NEED TO REPLACE THE STK's
IF YOU CAN SOLDER YOU MY BE ABLE TO HANDLE THE JOB BUT IF YOU AREN'T PERFECT IT COULD CAUSE MASSIVE DAMAGE THE STK'S (2 OF THEM) ARE ON A BOARD ATTACHED TO 2 SQUARE,SILVER, RIBBED LOOKING BOXES
Posted on Feb 22, 2008
Hi. My Sony Videoscope XBR's Convergence Allignment
I happen to share this same problem. The alignment of the gridlines on the standard convergence panel are completely abnormal, and if I attempt to auto-adjust the TV, it flashes different colors on the sides of the screen , and then turns off the convergence settings.
Feb 01, 2010 | Sony Televison & Video
Screen blury,very pink,green edging on picture almost colorless!
This would be a convergence issue you can run the convergence setup that is in your user manual if that does not work you are going to need service.
thanks
Sep 17, 2009 | RCA HD52W56 52" Rear Projection HDTV
Sometimes after the my TV is one for 20 mins or so the screen warps, shooting white/pink/green lights across the top and bottom of the screen and placing a horizontal black line at the bottom like hal
Your TV most likely has a problem in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 19, 2009 | Hitachi 50FX20B 50" Rear Projection...
Hitachi 61UDX10B
I would check for burnt resistors as the 150s are interchangeable with the 110s however in alot of hitachis I have seen resistors blow after upgradeing to the higher wattage ICs. I Usually switch out the convergence resistors whenever I go to a higher wattage IC just to be sure. If you need more help let me know.
May 18, 2008 | Hitachi 61UWX10B 61" Rear Projection...
TOSHIBA 65H82
you need to replace your 2-convergence ic's #STK392-110 you need to replace both ,,they are attached to 2 big heat sinks and identified as q-751 & q-752 you can get the ic's you need plus free tec support and installation instructions including pictures at the link I gave you.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Toshiba 65H82 65" Rear Projection...
SONY WEGA KF60WE610
I would suggest going to the folowng link you can get the full service manual with full trouble shooting and parts section emailed to you for 10.99. your model is listed on page 2 of the sony section. They also provide free help to help you with diagnosis. I have used them countless times they have excellent sevice manuals. Here is the Link.
Feb 25, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Wave at bottom of screen with green and pink shadows
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Feb 17, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Suspected Convergence Issue on Toshiba 51H83?
Needs chassis pull & convergence IC's replaced....then
Touch Focus will work again..................T.
Nov 19, 2007 | Toshiba 51H83 51" Rear Projection...
Update and a few questions (Convergence Problems - VS-55601 55 in Projection)
yes, they go bad interment because they have a large current go thru them and they generate heat, they are mounted on a heat sink with white silicone to help disapate heat. replace both not just one, try MCM Electronics get heat sink compound also
Oct 06, 2006 | Mitsubishi VS-55601 55" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
