Question about Epson Stylus Photo 1290 InkJet Printer
Paper going straight through - Epson Stylus Photo 1290 InkJet Printer
  • 4,041 Answers
Hi
It must be you printer driver try reinstaling it
Posted on Feb 07, 2010
Paper gets folded and jams as the paper gets pulled into the machine from the paper tray below in my image class MFN
clean the roller's with some rubbing alcohol and the paper should go straight, UNless something got stuck in there, Ripped piece of paper might also be the cause, the older the unit the more it needs the rollers cleaned,
Jun 05, 2014 | Canon imageCLASS MF6530 Monochrome Laser...
Paper does not feed straight and does not print straight on paper
Do the following:
1.) Check the paper input tray, there is a slider on the left side only that must be slid to meet your paper, in order to get it to go through the printer in a straight fashion.
2.) At the rear of the printer there is a large access hatch. On the left side of the hatch there is a handle to open it. Pull the left handle, the hatch opens from the left and then needs to be taken out pulling leftwards as the right hand side has pins that hold it in place.
Check his area for obstructions. Now ensure that this hatch is properly seated. The right side pins need to be pushed into the two corresponding holes and then the left side is to be pushed into the rear of the printer, it should click into position securely.
3.) Allign the printer's ink head by using the software that came with the printer. Go to your control panel and double click the printer to access HP's options menu.
Do this last as it is possible that the ink head is fine and the only problem is that the paper is not being fed in straight.
Take care!
damnor01
Aug 22, 2011 | HP Officejet 6500 Wireless All-in-One...
Printer will not feed paper straight grabs one side and pulls the paper crooked and crumples the paper
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Aug 07, 2011 | Dell 922 All-In-One InkJet Printer
I have a borrowed Casio FR 105S printing calculator. How do I load the paper?
Make sure the paper has a straight clean edge. Feed the paper into the slot in the back - make sure the paper is straight. Paper will go in about 1/4 inch. Push the feed button and the paper should feed through the printer.
Feb 05, 2010 | Casio HR-8TMPlus Calculator
Paper jam, but no jam + paper feed problem
check to make sure there aren't little pieces of paper jammed at the ends of the roller. if you can pop out the roller easily you may find tiny pieces of paper still lodged in there
Dec 29, 2009 | Office Equipment & Supplies
Paper won't load straight
you will need tools, remove back cover and clean rollers and maunually rotate. hope that helps
Oct 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
All recieved faxes going straight to memory
Either it needs toner/drum unit replaced or it's hungry for paper....is it displaying an error code?
Aug 03, 2009 | Canon LaserClass 2050 Plain Paper Fax
My paper won't go through my canon ip90v straight
You may need to clean the pickup rollers. These are the ones that pull the paper out of the tray and begin feeding them into the printer. It is likely that one side may be slighly gummy and the paper is sticking to it or the other side may be slick with miniscule paper particles that is causing it to slide right over the paper surface and not grabbing it at all.
Apr 07, 2009 | Canon PIXMA iP90 Mobile Printer
Paper won't go in straight
check paper quality (wight, adsorbed humidity etc,) change it and reduce humidity where you store anf use it.
Feb 07, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Printing is crooked
if paper comes out straight, and lines in paper are not straight then there is problem wit laser unit, its not installed corrrectly, also you can check drum unit and transfer belt for correct installation.
Apr 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Epson Stylus Photo 1290 InkJet Printer Logo
73 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
