Question about Microsoft Xbox 360 Console
My x box wont connect to wireless router after power cut
  • 340 Answers
Turn off your router and wait 30 seconds before turning it back on, if this does not work check that all your router info is all ok, you want your my xbox page,scroll over to the right to the systems settings page, click network settings,click configure network.
If that is all ok, click test xbox live conection, this will tell you where your problem is and give you some suggestions on what to do.
Remember thumbs up if this helps.
Posted on Feb 07, 2010
My DLink DIR-655 Wireless N Gigabit Router will keep cutting out the wireless every couple hours or so. I am running a PC Notebook off of the wireless signal, and it is the only PC in the house that is...
Try rebooting the router. Does your laptop "drop out" when connected to other networks?
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Apr 27, 2011 | D-Link Xtreme N DIR-655 Wireless Router
My wireless light on the box isnt lit up. and my ipod wont connect to the router
If the wireless light on the router is not lit that is a sign of something wrong with the router , what you can do here is to reset the router.
To reset the router you can press and hold the reset button of the router for 10 seconds while power is ON and then power it OFF and power back ON and now check if the wireless light is ON and then if its ON now you can now reconfigure the router.
Apr 06, 2011 | Belkin F5D72344 Wireless G Router 54Mbps...
My hp lap top wont connect to the internet through the usb the ethernet or wireless and it was working fine until 24 hours ago. I think it may be the network adapter. I re installed the driver for it but...
Try turning off the wireless router fo 30 secs and then power it up again. When the LEDs light up, then boot up the HP laptop.
If this doesn't work, then check the laptop to see if the wireless router issued the HP laptop with an IP address. to do this - click on Start - Run - type cmd and press Enter. This will open a DOS command box, then type ipconfig and press Enter.
If the IP address returns 0.0.0.0 then the wireless router didn't issue the HP with an IP address and either the wireless router is faulty or the wireless card is faulty or it has lost its LAN configuration.
If the wireless router LEDs are all on, try connecting a LAN cable direct to the LAN port on the router and the laptop to see if it connects to the Internet. If it connects then install the latest wireless card driver and configure it with the wireless router's settings.
Jan 25, 2010 | HP Computers & Internet
Wont connect to internet
Yes you hve to setup the router again, the wireless setting especially.
Turn mac control off in wireless security and let me know how you get on.
Jan 21, 2010 | Linksys Wireless-G WRT54G Router
Can not set up x box live error message states
Hello
First try a router reboot.Unplug all cables from router except power.
Find reset button on router,small use a pen tip or paperclip to hold button in for 60 sec.
Power router off.reconnect all cables.power router up.
Next activate wireless on the router.You will need to enter your wep or wireless code of router into the x box.
If your hard wired you will need to enter your username and password for the router into the x box.and the ip address of router.
username=admin
password=admin or password
Jan 17, 2010 | Microsoft Xbox Live 12 Month Gold...
Connection cuts in and out.
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 15, 2009 | Dell Wireless 2350 Router
Xbox live cannot connect to network
I would suggest power cycling it, both the xbox and the router, sometimes routers can be funny with there connections.
Jun 30, 2009 | Linksys Wireless-G WRT54G Router
Router wont connect to the internet
Two things, first try power cycling the modem and router. Unplug both of them for about 30 seconds then plug the the modem in first let, let it cycle through and then power up the router. If that does not work you might need to reset the router and restore the factory defaults. Let me know how it goes. Thanks
Apr 15, 2009 | Encore 802.11G WIRELESS LAN ROUTER...
Linksys Power cut problem
With regard to power cuts, i highly suggests you to buy a UPS (Uninterruptable Power Supply) to prevent further damage to your router. You can simply reconfigure the wireless settings of the router by accessing the router's Setup Page. Go to http://192.168.1.1, go to wireless tab and you can change the network name as well as enable the wireless security.
Jan 19, 2009 | Linksys Wireless-G WRT54G Router
Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Jan 01, 2008 | Zyxel P660HW-D1 Router
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
