Question about Apple iPod MA446LL/A MP3 Player
MENU BUTTON Hello, My Ipod nano 8G menu button is not working I cannot change to another song and I also have a problem resetting it using the menu and select? button what can I do? Thank You Dee
  • Anonymous Nov 04, 2008
    I have same problem as this, Ipod Nano works just fine, except that you cant use the menu button. Once you choose a play list you're stuck in it until I hook it to my pc and sync it again. Where do i send it?
  • Apple Master
  • 13,433 Answers
If the buttons are broken they need to be replaced, I supose apple can do this. Contact apple, your dealer or a local professional.
But to make sure they really are broke
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If your unable to perform a reset then most likely they really are broken.
If you need more assistance let me know. Good luck.
Posted on Mar 30, 2008
  • Ekse Apr 02, 2008
    If my solution fixed your problem, could you give me a Fixya rateing? Becouse Im trying to reach the guru rank and its up to you if I get there or not.
    Thanks alot!
    If you need more asistance, let me know.
Volume wont turn up on my mp3 - volume too low
How to Reset the Volume Limit on the iPod Nano
Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume.
Instructions
1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
3 Select "Playback" from the menu choices that show up.
4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on.
5 Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Tips & Warnings
If you set up a combination and forget it, you can reset your iPod Nano and start over again. Resetting will not lose any of your downloads, but you will need to restore or reset many of the settings you initially chose when you first set up your iPod.
Changing the volume limits on your iPod Nano covers everything on your player, but the sound levels for songs, audio books and shows will vary based on how they were recorded.
Dec 10, 2011 | Apple iPod nano
My Ipod froze
You can usually reset a frozen iPod by holding down the menu and center buttons for about 10 seconds. Hope this helps!
Jun 23, 2009 | Apple iPod nano
IPod 8G Nano completely doesnt work.
ResetTo reset your iPod nano:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. 5rs_reset_clickwheel.png
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jan 16, 2009 | Apple iPod nano
Broken ipod
To reset an iPod Nano
  2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Jan 10, 2009 | Apple iPod nano
8G ipod nano wont play music or has any volume
go to settings on the menu and select volume and set it to maximun it should work then
Dec 21, 2008 | Apple iPod nano
The new ipod nano
Dear,
you have to hold the the menu and middle ong for 10-20-30 secs ,hold the menu +center button and it will turn off and reset .
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Cheerup
Mar 26, 2008 | Apple iPod nano 3rd Generation
Will not stop shuffling songs
to reset your ipod
switch hold button off and on again then press the menu and the center button simutaneausoly until the apple logo appears and goes bright and there .has been reseted
rate the solution plzzzz thank u
Mar 13, 2008 | Apple iPod nano
Hello
to reset switch hold button off and on again then press the menu and the center button simutaneausoly until the apple logo appears and goes bright and there .has been reseted
Feb 01, 2008 | Apple iPod nano
10sec play
try reseting it. then resyncing your ipod. to reset it, simply push the middle button down, and the menu button at the same time. a few seconds later and the ipod should reset. then sync the song that had the problem onto the ipod and see if it works. (no point in syncing all your songs becuase if reseting it doesnt work you wasted alot of time syncing songs for nothing)
best of luck : )
Jan 22, 2008 | Apple iPod nano
Applie ipod nanao
hi your ipod will shut itself if no action is on you can determine the period of time that will happen good luck
Mar 22, 2006 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
22 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
