Question about Brother DCP-120C All-In-One InkJet Printer
How do I connect to my p.c. ? It doesn't seem to have a cable out let? I didn't receive a cable with the printer ( second hand#) Do I connect through one of the card slots....conused,,,Works fine as a photo copier but don't know how to connect to p,c,...?
  • 433 Answers
You should have a power supply,
Sounds like you do since it works fine as a copier.
The other cord you need is a USB to hook to the computer.
Your computer uses the flat rectangular USB
The other end can be one of three types.
Look on the back side, most usb printers use a small rectangular USB about a 1/4" x 1/4" if so Staples sell them, explain the outlet and they will hand you the 20.00 cable
If I am not correct on the location, just walk the whole unit down to your local Staples, they no where to look.
Posted on Feb 07, 2010
Is there a cord that connects my tv to my dish box? It is a VIP 211k.
Ethan Lensch,
I can definitely provide more assistance with this. The TV doesn't connect to the dish itself. The cable from the dish goes into a switch, then from the switch it runs in to your receiver.
On the back of the receiver is a "SAT IN" slot. Verify the cable plugged in there is hand tight, and follow it back making sure any other connections you see are tight. If the signal doesn't return, unplug the receiver for 10 seconds and plug it back in.
If the signal is still out when it powers back on, run a check switch test. This is done by going to Menu > System Setup > Installation > Point Dish > Check Switch > Test. When it is done it will either go back to the Check Switch screen, or give you a message. If it takes you back to the screen, exit out and see if signal returned.
If the signal still isn't returning, or you get a message saying "Fewer satellites dectected", let me know here or by email at thomas.faust@dish.com and I can look into getting a tech out to fix this!
Tommy Faust
DISH Social Media Representative
Nov 11, 2012 | DISH Network ViP 211K
Why isn't my HP office jet 4500 G510 a-f printer connected?
Maybe you didn't install the driver properly, i guess that model will need you to install the driver 1st before connecting your printer to the PC.
Try uninstalling the driver...restarting PC...reinstalling driver...connecting printer (while in off position)...switching on your printer.
Sep 23, 2017 | HP Office Equipment & Supplies
Power but not printing
Hi Linda,
Did you check if the printer is able to scan or does it makes photocopy? if the printer doesn't respond to any input follow below steps.
  • Power Drain:
  1. Turn the printer OFF using the power button.
  2. Disconnect the power and USB cable from the back side of the printer.
  3. Press and hold the Power button for 30 seconds and release the button.
  4. Connect the power cable and try printing.
  5. If the above steps didn't work try below.
  • Partial Reset: Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button. If you still see the issue try next level of reset.
  • Semi Full Reset:- Remove the ink cartridges; Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
Feb 07, 2012 | HP PSC Photosmart 2355 All-in-One Printer
When I connect the printer esp5 to the computer it doesn't seem to recognize it, why?
remove the cable and insert again.if it doesn't work change the cable
Oct 29, 2011 | Kodak ESP 5 Printer
I have had this aficio 2022 for less than 3 years and have less than 20,000 copies. I only have used it as a copy machine . There is a printer parallel port . I've just connect it to my computer to...
Does the copier have a printer /scanner sd card installed and a network card installed in the machine as this is the best option to use the machine as a printer
Mar 11, 2017 | Ricoh Aficio 2022 All-In-One Laser Printer
I cant connect to internet
There are lots of possibilities here since you didn't give us much info to go on. Some helpful information would be:
1. DSL, Cable Modem, Sat Modem, other ISP
2. Is the problem with the router, or the network connection
3. What are the model numbers on your router, and if that doesn't connect directly to the wall, what does it connect to.
4. are you connecting from a desktop or laptop
5. are you connected to the router over wireless, or Ethernet cable
6. are there any other devices in your house/apartment that can connect to the internet (is 1 device down, or are all the devices down)
With the little information we have, I would suggest unplugging your router for about 30 seconds, then plug it back in. It will take anywhere from 30 seconds to several minutes to reset and reconnect.
If this doesn't fix the issue, give some more details and I will give the next step.
Thanks,
John Vickers
Aug 12, 2011 | Computers & Internet
My HP 3050 Laser printer is not recognizing the print cartridge. I had a paper jamb and the error message started. I have tried to power down the machine, reinstalled a new cartridge, removed and...
Hello, If your cartridges are not empty, but you continue to receive the 'Ink Cartridge(s) are Empty ' error message, follow these steps to override the message. Disconnect any cables (Ethernet cable or USB cable) that connect both the printer and the computer. Restart your computer. (Consider bookmarking this page in your Web browser so that you can easily return to it after the computer restarts.) With the printer turned on , remove the power cord from the back of the printer. Wait 30 seconds. Insert the power cord back into the printer, and turn the printer on. Clear any error messages. Reconnect any cables that connect the printer to the computer. If the above doesn't solve the problem, you will have to download Hp diagnostic utility on your your computer, install is on your computer and it will help to detect and solve the problem. Visit the hp link below, read all the information on the page and download the diagnostic tool from the page. Click here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02114788&tmp_task=solveCategory&lc=en&dlc=&cc=us&product=441125 Keep me informed if none of the above seems to solve your problem. Good luck.
Jul 11, 2011 | HP LaserJet 3050 All-In-One Printer
I get error message: 0xc18a0106
Hi!
That seems to be a problem with your ink cartridges, try this steps.
---- We need to reset your printer, to do that.
- you need to remove the USB cable (data cable) from the back of your printer, it is most likely the grey cable.
- Next, you need to remove all the ink cartridges of your printer.
- Wait for the prompt that says, "insert ink cartridges", then directly unplug the power cable from the back of your printer and wait for atleast 60 seconds.
- After that, reconnect the power cable, if the printer didn't turn on by itself, please press the power button to turn it on.
- Now, re-insert all the ink cartridges and close all the open doors on your printer (top cover or the cartridge door)
- if you receive a prompt to print a calibration page please do it.
- Then, reconnect the USB cable to the back of your printer and try printing a document or a photo from your computer.
Thats it!
Jun 14, 2011 | HP Photosmart 3310 Printer
I have a Bose lifestyle 48 that shuts off seconds after you turn it on. It will also say "storing" in the lower right hand corner before shutting off.
Check all the wires and connections. Check to make sure the speakers are all properly hooked up
in the right place with proper polarity and the unit doesn't have any loose connections. If the wires have been stapled check to make sure the staples didn't cut any wires.
May 02, 2011 | Bose Lifestyle 48 System
Hello, I have an HP Photosmart C6180 All-in-One Printer, Fax, Scanner and Copier. It seems that as soon as I turn it on a message comes up: "Fax Failure" Unable to Send or Receive Faxes" This message has...
try ti perform steps as ---->Disconnect the power cable from the back of the printer and then press the power on button for 3- seconds and then at the same time connect the power cable at the back of the printer and then try to turn on the printer and then try to make copy from the printer
Aug 19, 2010 | HP Photosmart C6180 All-In-One InkJet...
Brother DCP-120C All-In-One InkJet Printer Logo
69 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
