Question about Panasonic Home Theater System System
My panasonic sa-ht855 keeps displaying F61 wheni try to open the disc tray. I have checked the peaker connections as advised by the manual but to no avail.
appman67
  • 33 Answers
SOURCE: panasonic home theater sa-ht920
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
Posted on Sep 21, 2008
marsrover
  • 682 Answers
SOURCE: Fault code
speaker cord connector problem:-
remove all speaker connectors and insert it one by one each time until you find the bad one and change its connector with a new one.
(you must play something and listen).if all above does not work you will have problem in power supply and need to fix.
Posted on Apr 04, 2008
  • 5 Answers
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Posted on Jun 22, 2009
heavyice
  • 374 Answers
SOURCE: panasonic surround sound system model # sa-ht95
Error code ' F61 ' on most Panasonic models indicate that the built-in diagnostics has sensed a fault at the output stage. This would normally refer to a failed output amplifier IC (?P/N RSN704D66P?). In some instances, the fault could also be triggered by:
  • strands of Speaker wires inadvertently touching each other;
  • faulty speakers;
  • failed Cooling Fan of the output IC.
Options then are:
  • consider a DIY (do-it-yourself) repair only if familiar with electronic components & circuitry, use of a DVM/VOM and a soldering iron. Access to a Service manual would be an advanatge;
  • seek the services of an authorized service center specially if the unit is still under warranty;
  • consider other options based on downtime, cost of repair, parts of availability, age of unit and prices of comparable but newer models.
Good luck
Posted on Mar 06, 2010
SOURCE: My Panasonic SA-HT75 clicks off seconds after I
Hello.
I have a Panasonic HT-75 codes It F61 appears. What is the problem?
Posted on Apr 25, 2010
Panasonic SA -VK950.Problem F -61 is displayed when power buton is pressed.
F61 is a fan error code. Most people advise to clean the fan, or take it out to make certain it turns. Get rid of any dust or fluff from it. And I would say keep it that way!
Nov 18, 2016 | Panasonic Audio Players & Recorders
Panasonic sa-pt770 will not power on
When power is applied do you get any LED light or display that shows?
Dec 27, 2014 | Panasonic Sa-pt770 Receiver
Hy i have a PANASONIC SA-HT855 and when i open the dvd its show's error F61
Hi Can anyone tell me what the IR data rate is for the Panasonic Home theatre SA-HT855 I want to know for the remote repeater I have will only work in the 30/40 range I hope this makes sense to someone as it makes very little to me!
Dec 19, 2010 | Audio Players & Recorders
Unable to Open F61 error flash on screen
TIMING ADJ...AC DISCONNECT !!
OPEN TOP LID
CHANGE MAIN BELT BY MOVING THE TRAYS.
PLUG IN AND CHECK
IF NOT NEED ADJUST TIMING FOR THE WEELS.
ONLY EXPERTS
FREDDY.R
ISRAEL
Nov 11, 2009 | Panasonic SC-VK31 220 Volt 5-VCD/CD...
My SA-VK70D got F61 and imediatelly turn off..:(
i have vk70d and i have same problem .....your cooling fan not working ...chand it ...its work ....
Sep 03, 2009 | Panasonic SCAK410 5-Disc CD Changer
My panasonic SA-AK57 it is displaying error code F61
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
I have a panasonic sa-ht855 dvd player showing error code f61 on display then shutting down.
Your sound/power stage is not working. Set needs to be taken in for repairs.
May 12, 2009 | Televison & Video
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
Sa-ht680 service manual
The F61 indicates protect mode. There is a problem with the output stage of the amplifier section and the unit shuts down to prevent further damage. This unit will require service of the amp section. You can try to contact Panasonic for the service manual.
The output amp pac is an RSN311W64D at a cost of $95 plus shipping.
Dan
Apr 09, 2008 | Panasonic SC-HT930 System
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
Panasonic Home Theater System System Logo
533 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
