Question about Cornea CT 1700 17" Flat Panel LCD Monitor
When computer comes on the screen only shows power sharing mode
  • 24 Answers
If u r getting this errror after POST then restart the computer and keep pressing F8 key to enter into advanced mode then select Enable VGA Mode Option.
Posted on Feb 07, 2010
Unable to have safe mode screen come up from hitting f8
When the F8 key doesn't work, there is another (less desirable) way to force the computer to start up with the option screen to go into safe mode is to interrupt the Windows start-up process. As soon as the Windows screen comes up showing that it is booting up, remove the power from the computer. When you restart, Windows will detect that it did not start up correctly on the last attempt and will automatically go into the option screen to allow you to choose Safe Mode.
Feb 22, 2010 | Sony VAIO PCV-RS710G PC Desktop
Computer screen goes into "digital power saving mode"
You should be able to adjust the settings on the monitor to prevent it from going into power save mode, or at least to delay how long it takes before it goes into power save mode. Press the menu button and look for settings that might disable or change power save mode.
Also, does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your newer monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PC's video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG L1915S 19" LCD Monitor
Vista computer HP in sleep mode. How to get it
Typically you can just press the power button once, and the computer should come out of sleep mode.
Be sure to power off your comptuer regularly to reduce risk of freezing when computer enters sleep mode
To chance Sleep Mode Settings follow instructions below:
First click on the start icon at the bottom left hand corner of your screen and type into the start search box :power options , now click on "power options" it will be at the top under programs, next, under perfered plans section you need to click on " change plan settings" that is under the plan that has already been selected, this plan has a blue dot on it , come down to and click on " change advanced power settings" , now you need to scroll down to "multimedia settings " in the window that has just been displayed, click on it's box to open it up , then do the same to " when sharing media "' now click on the text to the right of "setting" it is light blue ,this will high light it and you now click on the little arrow . select " allow the computer to sleep ", lastly click on ok!
Jan 06, 2010 | HP Pavilion dv9000z Notebook
How can i get my computer out of power saving mode? i use it for about 1/2 hr and it goes into power saving mode. very frustrating. screen just goes black
ya i bet it is, this is a bad virus from file sharing programs.
use virus removal tools,
or restore to factory with restore disc/ wipe hard drive and reinstall OS
Oct 21, 2009 | LG Flatron L1750S 17" LCD Monitor
My Philips plasma only shows half the screen. The other half is just blacked out.
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
Sep 14, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
When I connect the lcd to my laptop, the lad shows
hi atuire,
try hooking up the lcd screen toanother computer and if it shows the same double screen again then there is aomething wrong with your lcd monitor,
you may want to use another monitor with your laptop to ensure the problem is not on the laptop's side.
if issue stays same with another monitor, then just right-click onto desktop background, goto properties and have a look whether you have enabled the shared monitor feature
(meaning that u can use two screens with just one graphics card parallel, to work on a 'wider' range of sight.
Therefore your machine's graphics card sually must be equipped with both: a standard vga out and a HDMI-out as well.)
if your machine ddoes not have these capabilities but still the monitor sharing is turned on from the software side, this might cause the problem. To disable simply change the graphics card's
propertiers as descried above.
Good luck
Sep 06, 2009 | Gateway Computers & Internet
My acer X193w screen went blue and wont show red
I once had that problem, I think you need to make sure that the power supply cable is fitted well and your monitor receives enough power. if its shares the power cable with your CPU try and separate it then restart your computer.
Jun 24, 2009 | Acer X193W LCD Monitor
Server just stops!
Did you check to see if it is going into Hibernate mode in the power settings?
Apr 12, 2009 | Dell Computers & Internet
Screen shows no signal
Hold down the power button for about 6 seconds continuously, this should wake it.
Sep 19, 2008 | Compaq Presario 5000 PC Desktop
Cornea CT 1700 17" Flat Panel LCD Monitor Logo
61 people viewed this question
Top Cornea Computers & Internet Experts
giarcnameloc
Level 1 Expert
Tom Chichester
Are you a Cornea Computer and Internet Expert? Answer questions, earn points and help others
