Question about NRS GMS G28 Acrylic Snare Drum, 6.5X14 Black With Silver
The snare connectors on my premier snare drum are loose. how tight should they be?
  • 31 Answers
It's all a matter of taste and style. If you want a tight, crisp "snap" to your snare, you keep the heads taunt and your snares similarly tight ~ you will get a staccato sound, very crisp and military. Some drummers just like that, others like it more loose. There is no "right" or "wrong" here, it's what you like. If there was, they wouldn't make them adjustable!
Posted on Apr 08, 2010
    President:
  • 1,138 Answers
It should be adjusted just tight enough so the snare doesn't rattle when it is not on.
Posted on Feb 11, 2010
The snare triggers incorrectly
hello....just had the same proble... u probably need to clean or fix the port... (if u try to pull out just a little bit the jack u can see that everything it works properly).
I opened the snare (ccrew it out) , i cleaned the components with some spray and noweverything works.
let me know
ciao
Sep 24, 2012 | Alesis DM7 USB Electronic Drum Kit
Dt express snare sound changes
Check your snare and the red knob next to it, if you turn this knob it will turn off the snare, it could even have a short or etc.
Sep 17, 2012 | Yamaha Dtxpress Iv Special Electronic Drum...
I have the dm10 studio pro 2011 kit, and no matter how i store settings for priority, if the rim of tom 1 or 2 are struck at the same instant as the snare head, the snare does not sound. even if i set no...
Realize first that your "instant" is like eons to the electronics where billionths of a second count... This is an interesting set of symptoms. I would connect one of the other devices to one of the tom inputs and see if the snare acts the same using that devicee. Also try to characterize how much ahead or behind the snare hit the tom hit can occur and have both sound. This problem MAY be embedded in either the electronics or the firmware in the module. It could be an electrical noise issue or any of several other things. I want you to try this using ONLY headphones and NO amp... this is to isolate the possibility that the vibrations of the snare by the amp may be triggering anti-noise gate in the snare circuit. These are some more tests I want you to do the above and give me the results.
Sep 13, 2011 | Alesis DM10 (Module) High Definition Drum...
Two of the pads on my Yamaha DD55c drum machine do not seem to be triggering properly. For example, if I hit the snare pad it seems to always be triggering at a low velocity, but if I strike it flat with...
A weak snare is a characteristic of these... The triggers are typically piezo discs that were often used in musical cards but those have now gone to using very flat little speakers... You may find some have been dislodged or broken loose... worth a look inside.
Apr 11, 2011 | Yamaha DD55 7 Pad General MIDI Digital...
When I hit the snare drum harder than usual, it is making a different sound. Is that supposed to be?
I believe I have found a good part of the solution to this problem. I also had this problem in the snare. The problem was so severe that, when pulled, the snare support, without giving him any beat, the sound appeared. I took courage and opened the snare.Ao open, I realized that a yellow adhesive used to glue the trigger wire had melted and the other touching the trigger. I think this must have happened at some point prior to my purchase that equipment has been under excessive heat and then drained to such a glue. Simply cut the little wire glue "connected" two triggers, and closed the snare ....... ready: is working perfectly.
Mar 15, 2011 | Alesis DM6 Electronic Drum Set
You can not play these drums live the spill of the fold back drum fill bin sets of the snare trigger ive turned down the sens on the red box still doesnt work a big waste of money i need to talk to...
With this kit being acoustic-electric, the only advice I can give is to disconnect your snare trigger and mic the snare. It's either that, or your snare trigger is faulty. A new trigger is going to cost about the same as mics, but mics won't hit your snare, making you sound inexperienced. For miking the snare, you'll want to get two mics, placed on the top and bottom head. Try to position them on the same spot on the rim to avoid voicing problems. Studio drummers do the same thing when recording.
For playing this way live, you'll want to use either the main PA, or run to a separate mixer so you can control the volume of the snare in relation to the rest of the kit.
Hope that helps!
Feb 11, 2011 | Pearl E-Pro Live Electronic Acoustic Drum...
I had just recieved a brand new DM6. Upon setup the kick drum didin't seem to be working. I switched the cable going into the kick drum pad with the Tom 3 cable and the pad was responsive. When I...
THERE IS A TINY SWITCH ON THE BACK OF THE MODUELE
THAT MUST BE SET TO PAD , IF IT IS IN THE WRONG POSTION YOU WILL NOT GET ANY SOUND OUT OF YOUR KICK DRUM
Jan 12, 2011 | Alesis DM6 Electronic Drum Set
Every time i hit it anywhere on the front the snares shake, whats wrong?
Absolutely NOTHING is wrong. The snare drum resonates. The only solution is to NOT let th snare drum "hear" the Cajon... This is a common problem... Other instruments can also trigger the snares... SOME people add clearance of the snares to the drum to avoid some of the problem.
Jan 10, 2011 | Toca Cajon Bordeaux
I need to aassemble a Snare Drum that has been dismantled.
Try here:http://www.ehow.com/video_2379338_replacing-snare-drum-head.html or here:http://www.youtube.com/watch?v=twHxMISI7hg orhttp://www.remo.com/portal/pages/drumming/product_tips/Drumming+Product+Tips+Tuning+Concepts4.html
Oct 13, 2009 | Music
NRS GMS G28 Acrylic Snare Drum, 6.5X14 Black With Silver Logo
104 people viewed this question
Top NRS Music Experts
Michial Gueffroy
Are you a NRS Music Expert? Answer questions, earn points and help others
