Question about RTO 50cc Moped Scooter
Malaguti f12 phantom 50cc starts but takes along time to pick revs up . drives for about 100 yards then looses power and drive why please help for my 16 year old son thanks
    Problem Solver:
  • 12 Answers
Change rollers in the variator
Posted on Jul 20, 2010
I've not bin on my malaguti 125 for 2 days was running fine now won't start
Hi, John and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.apriliaforum.com/forums/showthread.php?179110-Malaguti-f12-won-t-start Scooter Troubleshooting Scooter won start All about Scooters
Malaguti MADISON 125 Manual
MALAGUTI MADISON 125 150 Wiring Diagram Parts and Electrical Components...
MalagutiScooters and Motorcycles Spares Parts and Accessories Fast Free UK...
Oct 22, 2016 | Malaguti Motorcycles
Engine running problem
air mass meter try unplugging it
Dec 30, 2013 | 2002 BMW 3 Series
Why dose my 2002 audi A4 loose power and almost stop?
First, check the condition of the following:
1) Spark plugs
2) Spark plug leads
3) Air filter
4) Fuel filter
5) Coils
6) [Assuming the first items are found in good working order] Idle control valve operation and cleanliness.
Nov 10, 2012 | Cars & Trucks
Hi i have a julin fighter scooter 50cc this morning the drive belt broke replaced the drive belt got the bike to start and it revs high when on the stand but when we kick it off the stand it will only tick...
Hi, Anonymous and the usual suspects are:
1. Severely drained or faulty battery.
2. Faulty regulator/rectifier or high output coil.
3. Faulty power valve, solenoid or installation.
4. Clogged air filter or exhaust.
5. Cracked or incorrect float level.
6. Float needle is not seating.
7. Faulty reed valve.
Good luck and have a wonderful day.
Jul 03, 2017 | Motorcycles
Is it easy to remove battery from malaguti phantom max 125
The battery is underneath the rear seat.Lift the driver's seat, remove the two bolts holding the rear passenger seat and you will see the battery.This will help I thinkwww.malagutiscooterspares.co.uk/spares/epcimages/7585/14.jpg
Feb 05, 2012 | 2007 Malaguti Phantom Max 125
Where is battery situated in a phantom max 125
Feb 05, 2012 | 2005 Malaguti Phantom Max 125
Loose of power at low revs
idle control valve, intake manifold leaks, other vacuum leaks, fuel pressure regulator fuel filter.
Jun 19, 2010 | 1999 BMW 5 Series
2 stroke engine not starting
Head or base gasket leak, spark is happening at the wrong time. Any of these will cause it to not run.
Oct 02, 2009 | 1976 Honda CB 100
Intermittent high revving!
Throttle position sensor.
Jun 25, 2008 | 1998 Ford Escort
RTO 50cc Moped Scooter Logo
538 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
