Question about Maxon MCB-30 40-Channels Base CB Radio
Ch 9 When power up always on channel 9 - how can i get it to stay on last channel used?
Just like another post in this thread mentioned, your radio has a switch on it that, when set to the channel 9 setting will go to 9 automatically. Same with channel 19 if selected will always default to 19. Set this switch to either CB or NOR for normal operation and you will be able to select any other channel.
Posted on Jun 29, 2012
    Problem Solver:
  • 5 Answers
The orange wire goes to a fuse that is always on. That's how it remembers things when it is powered down.Like the clock on a Car stereo.
Posted on Mar 11, 2008
  • 204 Answers
Hi larry, That is a normal ch 9 default on electronic channel changers. Small midlands/cobras also do that. Try taking the red/hot power wire loose and attaching it to a power source that is hot all the time. That way there will be power going to the radio with the key shut off and it should retain the last channel you were on.
Hope this is what you were looking for, let us know,, Mechanic
Posted on Feb 22, 2008
Just installed midland 1001z. When powered up, it sequentially flashes the channels (1,2,3,...etc.) over and over, but never stops so I can't tune it to a station. The exception is that when I flip the ch....
Well the CB you have should not cycle through channels like that for sure. It is not a progressive scan. Try messing with the channel 9/normal switch again. In rare occasions that switch will **** to the side just a tad. there is a PCB board inside that is responsible for the channels responding to the channel as the channel knob is turned. This board could be going haywire. If fooling with that switch does not take care of the issue then I would contact the person you got the Midland from immediately and have them get you one that works properly.
Regards, Tony
Apr 25, 2011 | Midland 1001Z 40-Channels Base CB Radio
What is the DW button/switch for on the Cobra 18 WX ST II?
It is dual watch. you can set it to have two channels monitored. like ch 1 and ch 13 it will flip between those two channels. but if you use say 6, 19, 26 along with another ch it will stay on the channel with the most noise. and you would have to turn up the squelch to compensate.
Dec 13, 2010 | Cobra 18 WX ST II 40-Channels Base CB...
How do I do get to the set up mode using controls on the TV set? Want to do a channel search
Hello
To autotune do the following steps.
1.1 Press MENU to access MAIN MENU screen,
then press CH UP (8) or DOWN (9) to
move the " " mark to "SET UP".
1.2 Press VOL (+) or (-) to access SET UP
mode, then press CH UP (8) or DOWN (9)
to move the " " mark to "CH SETTING".
1.3 Press VOL (+) or (-) to access CH
SETTING screen.
1.4 Press CH UP (8) or DOWN (9) to move
the " " mark to "CH SEARCH", then press
VOL (+) or (-) to access CH SEARCH
mode.
START
2.1 Press VOL (+). The tuner will search
through all available channels in your area
and add them into the TV's memory.
STOP
2.2 Press VOL (-). CH SEARCH will stop at
the current channel and will not add any
higher channels.
2.3 Press MENU to exit.
Nov 21, 2010 | Sharp 25K-S180 25" TV
Unable to change channel DIR-615
IF NO PROBLEMS , WHY YOU ARE UP-TO CHANGE CHANNELS. IF YOU DID NOT STOP FINGERING HABIT THE ROUTER YOU WILL MESS IT UP AND WILL NOT POST ANY QUESTION ON FORUMS.
Apr 11, 2010 | D-Link DIR-615 Wireless Router
Wont change channels...stuck on channel 8
on this radio you have to put the norm and channel 9 switch to normal or up if it is on ch 9 positon it will not change channels.
Apr 16, 2009 | Midland 1001Z 40-Channels Base CB Radio
Cobra CB
is any wires in the mic catching in the plug as this is a common fault with a lot of radios . eg. pulled mic wires.
Apr 09, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Local channels gone?
You need to go to set up menu & select the cable & start
Feb 01, 2009 | Televison & Video
#4 & #5 buttons do not work on my remote. Channel 55 wont come in either on my tv
I had that problem 2 my channels disapeared one by one and some will skip yes...
I always use on my remote controll :
1 menu
2 Ch tuning
3 auto
and then wait untill it has found all the channels
Oct 02, 2008 | Orion1934 19" TV
Weird remote action, no cable, worked fine last night.
called for reset on programming by Cox Cable. Worked...amazing!
Mar 10, 2008 | Sylvania 6432TE 32" TV
Maxon MCB-30 40-Channels Base CB Radio Logo
148 people viewed this question
Top Maxon Radio Communications Experts
Steve
AnyMHz.com
AnyMHz.com
Mike Charette
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
