Question about Motorola Mobility RAZR V3
NEED TO PAIR BLUETOOTH HS850 TO RAZOR V3 - Motorola Mobility RAZR V3
  • 78 Answers
A With the headset’s boom closed, press and hold the Multifunction Button E until the headset indicator turns on (about 3seconds). The headset indicator turns on.
b Release the button, then open the headset boom. The headset indicator remains on.
2. Perform a device discovery from the phone. 3.select motorola hs850 and click pair 4 When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone. The device ID is now stored in the phone’s memory. Pairing is successful when the headset indicator flashes 10 times rapidly.
Posted on Feb 09, 2010
SOURCE:
How to connect motorola bluetooth hs850 to motorola V3 chandrabose
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 10, 2009 | Motorola Mobility S9 Headphones
I can't my new bluetooth headset to work on my v3 razor phone.
You probably need to do pairing again. Watch the video on how to pair RAZR to the bluetooth headset on www.HandBookLive.com. The direct link to this video is http://tinyurl.com/aprhqp
Apr 07, 2009 | Motorola Mobility RAZR V3
Need to pair up my BLUETOOTH # N136 headset with my Razr V3 phone
if you need the code it should be 0000
could also be
6789
9876
4321
1234
9999
hope this helps
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 06, 2009 | Motorola Mobility HS850 Consumer Headset
PIARING MY MOTOROLA RAZOR V3 WITH MY MOTOPURE H12
turn your bluetooth on and on your phone go to bluetooh or settings(if not under bluetooth) and select trusted devices or pair devices, then on the left or right corner it will say (search) once you have found your bluetooth it will say(motopure h12) select and then it will say pair device and you put in the code that came and your instructions and your good to go.
Feb 27, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Pairing
power the bluetooth all the way off
when pairing hold the bluetooth power button down this will sync up the bluetooth up with your motorola
Jul 07, 2008 | Motorola Mobility H350 Wireless Headset
Bluetooth pairing on Motorola Razr V3
try to check the setting of your blutoot, check te find me option.
Jun 05, 2008 | Motorola Mobility RAZR V3c Cellular Phone
HS 850 won't go into pairing mode
Usually to solve some pairing problems shut off bluetooth completely(no lights) Push and hold button until bluetooth comes on,flashes then steady light,you may have to hold button for ten seconds or more.Then put phone in pairing mode.
Feb 29, 2008 | Motorola Mobility HS850 Consumer Headset
Bluetooth hs850
On the following link you will find a very useful pairing guide that will take you through the setup. http://www.motorola.com/consumer/v/index.jsp?vgnextoid=38b5f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=fd13e7af976c9010VgnVCM1000008206b00aRCRD Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 20, 2007 | Motorola Mobility Universal Wireless...
HS850 Signal Light Wont stay on to be able to pair w/ V3 razr
When I paired my headset to my Blackberry - I had to do the following... Set my phone into the pairing mode.. quickly press button on HS850 and when blue light comes on, hold button and open boom - It has worked this way several times for me.
Aug 14, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility RAZR V3 Logo
83 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
