Question about Jl Audio 13W7 Car Subwoofer
Jl 13 w7 burnt voice coil
Is there anyone who knows where to ge these things fixed besides jl?
  • prw1971 Mar 15, 2008
    talked w/ jl $550.00 flat rate on all repairs for the w13 guess i'm gonna start saving
Nope!! I burnt up my 12W6 from supposedly under powering it. Your going to have to pay for a new coil if under factory warranty. Other wise ..... spent good money on a paper weight. Sorry for your loss, I know that I was pissed. :-(
Posted on Mar 13, 2008
A kicker 600.1 wired to a jl w7 10" sub? Will that work?
The kicker 600.1 provides 600 watts at 2 ohms and 300 watts at 4 ohms the 10" JL W7 has 2 1.5 ohm voice coils so you will have to wire them in series. Take about 1.5 feet of 14 gauge wire and connect the positive of one voice coil to the negative of the other then the positive and negative that are left go to the amp. Your impedance should be 3 ohms and that amp should work just fine.
Jan 14, 2016 | Kicker Car Audio & Video
How can I tell what coil is burn from my 13 jl audio w7
the way i do it is much easier. please find an old electronic and cut the plug off of it snd wire it to your sub and plug it in to the wall socket but do not touch any part of the wires or subwoofer for your own safety. and when the sub stops producing volume the bad voice coil will rattle let me know how this work out for you
Apr 28, 2014 | Car Audio & Video
My 12w7 has like a springing sound inside it, what is it?
Blown voice coil,,,,it was connected to a JL AUDIO amp correct? w7`s can ONLY be powered by JL amps due to ohm load.Advice buy a better quality sub,w7 is over-rated
Feb 07, 2013 | Jl Audio 13W7 Car Subwoofer
I think its my voice coil but I might as well ask to make sure. At higher volumes, my W7 will make a wierd rattling sound from inside the sub. Is it the voice coil or something else?
tinsel lead on terminal needs to be coated with a layer of black rtv sealant where it comes out of voice coil on back of speaker temporary fix since you have OVERPLAYED your subs,
Feb 22, 2011 | Jl Audio 10W7 Car Subwoofer
My 12 w7 makes a noise when I push down on it, what's wrong?
first of all the coil might have overheated and slightly made the voice coil go out of round or one of the biggest problems that jl has with their w6 AND w7's is that the magnet shifts because of the glue they use if its not annoying just keep using it or you can contact jl which by the way they charge about 250 to recone it plus at least 50 to ship and i dont think they pay for shipping to send it back you pay that also
Sep 10, 2010 | Jl Audio 12W7 Car Subwoofer
My cone on my JL W7 cone is cracked, How can I replace?
JL has good customer service, and usually you can get a drop-in replacement core/coil/former/spider. Call/e-mail the techsupport listed on their website, or contact your local dealer for replacement parts/service.
Jun 16, 2010 | Jl Audio 12W7 Car Subwoofer
Jl audio w7 13 subwoofer system 3ohm driver bridge it 2 ch amp
How much is your speaker max wattage?
If it is 750 or below, it can only be used on one channel, either the right or the left.
If speaker can handle 1500 watts then hook the positive speaker wire to R+
Hook black negative speaker wire to L-
Now it is bridged
Aug 19, 2009 | Jl Audio 13W7 Car Subwoofer
Jl 1000\1 v2 and 13 w7
it depends on how you wired your 13 w7 did you wire the dual voice coils up or down?? the w7 comes with a book and it has the 1000/1 settings you need and then there is a guide that comes with your 1000/1 v2 and on page 14 it tells you how to set the gain accordingly to your ohm load for perfect sounds with little to no gain overlap (you can set the gain louder if you don't want maximum sq and are not worried about clipping cause a 1000/1 shouldn't blow a 13 w7 from overpowering only from clipping (and since the w7 are practically bullet proof clipping takes a long time)
Nov 06, 2008 | Jl Audio 1000/1 Car Audio Amplifier
JL AUDIO 12W7-3 SUB
the rottem electronic smell is the voice coil burned up as well as the bad sound, isn't the 1st time i have seen a JL sub blown. not worth fixing buy a new one the cost is not that much more repair on them is 250 - 450 depending on how bad it is and only JL can do the repairs as they dont authorize repair shops access to their voice coils. however i can sell you a new sub with full JL factory warranty drop shipped to your door for about 475$ or I could do you a way better sub ( the baddest competion sub made in the last 5 years) an olympus 2412 dual 2 ohm 5000 watt monster that has user replaceable voice coil options and is killing the competition circuit right now for about $275.00 shipped. it will stomp 2 13 w7's into the ground all day long. 2 subs vs just 1
Sep 17, 2008 | Jl Audio 12W7 Car Subwoofer
JL audio hook up problems!!??
your w7 13's are dual 1.5 Ohm, but according to JL website, are 2.41 Ohms when the coils are in series. Each 13 connceted to each amp with voice coils in series is your best bet. The amps are designed to put out the same amount of power from 1.5 to 4 Ohms. If you parallel the voice coils, you end up with .6 Ohms and the amp will go into protect mode. You'll be drawing a lot of current, so you may want to think about 1/0 guage power wire, upgrade the wire from the alternator to battery (usually only 8 guage) and think about multiple batteries.
Feb 09, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Jl Audio 13W7 Car Subwoofer Logo
1,287 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
