My dvd is stuck in the player, and will not eject. It made a chugging noise going in and operated correctly, but will not eject. Help
This is what LG customer service will instruct you to do. I have a LG LDA-511:
1. Unplug your unit.
2. After unplugging, wait a few seconds then press and hold the power button (yes, while the unit is unplugged). This resets the unit.
3. Plug in your unit.
4. Press the eject button.
If the disc does not come out, then you need service from an authorized service representative.
Same thing happened to me.
just took it apart and found a broken gear
Try to unplug the player and plug it back in.
I finally called the company and was given the same advise. After attempting this solution, it did not work!
I have the same problem with the LDA-511. I've used it maybe a dozen times. Last time I used it, the dvd played, but now is stuck in the player. The player makes a chunking/grinding noise when the eject button is pressed, but the disc is stuck
