Question about Epson Stylus 880 InkJet Color Printer
Red and green nozzle check doesn't work, nozzle clear doesn't clear up the problem
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
  • JM Alvis Feb 07, 2010
    Supplies needed:
    paper towels
    latex gloves
    warm water
    PROCEDURE:
    Hope this helps. .
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Nozzle chek clear but photo is not good
Is the "clear" nozzle check little diagonal lines or some colored patches. Printer may be able to supply enough ink to print the little nozzle check but not enough to supply all the heads ink under heavy picture printing demands- you might try going into the advanced print settiing (where you can set the actual print dot size:720dp / 1440 dpi / etc and try the highest settiing available) - some people think t uses more ink- it doesn't, but it will take longer to print- giving the printer more time to provide the ink to the printhead- we call the INability to supply ink to the printhead fast enough - Starvation- this may be a quick fix, but not an actual cure for the rea problem
Sep 04, 2012 | Epson STYLUS R230 InkJet Photo Printer
Replaced the Magenta cart. and it still doesn't print anything red. I did clean the contacts that HP suggests.
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
Jul 14, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Printer has worked perfectly since purchased, suddenly started printing only the black portions of a photo. Did a nozzle check which confirmed only black cartridge functioning. Deep cleaned all heads....
The print head is still probably still partially blocked. Cleaning/deep cleaning tries to clear the head by flushing ink through, doesn't always work but does use up your ink.
You can get print head cleaning kits, PC shops,ebay etc. Try one of those.
Here's a really useful ebay url. with some youtube links, if you run the second video down you should get a pretty good idea.
http://www.ebay.co.uk/itm/Printer-Print-Head-Printhead-Cleaning-kit-Epson-Canon-/130479422758?pt=UK_Computing_Printer_Paper_Accessories_ET&hash=item1e612dfd26
Here's a direct link :- http://www.printheadhospital.co.uk/quickshop/
You don't have to buy this one, there may be cheaper, have a shop around.
Aug 27, 2011 | Canon PIXMA iP5000 InkJet Photo Printer
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
Epson CX7450 paper jammed
In some cases, this is cause by a nozzle that got clogged during the jam. You can run head cleaning utility either from the printer or from the computer.
1. Make sure that there are no error lights (red lights), just a solid green light.
2. Take out all cartridges from the printer and put them back in.
3. Once the printer is done charging the inks and you have a solid green light again. Hold down the Ink Button for 3 seconds, after this you'll hear movements within the printer, this is the head cleaning process.
4. Once the printer stops making noises, and you have a solid green light again. Power Off the printer
5. Once the unit is OFF, hold down the paper button while turning the printer ON. Once you see the blinking green light release BOTH buttons. The printer will then print the nozzle check pattern.
* Note: The nozzle check pattern should display all colors in the printer and there should be no gap or break between the lines itself.
6. Do this step 3-4 consecutive times. and that should resolve you concern
Feb 21, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Can not get rid of gaps with repeated Nozzle head cleaning
first of all, the nozzle check just tells you if there is a clogged nozzle, which you already know. you have to use the head cleaning feature on the same screen right below nozzle check. run that about 2 to 5 times and it should be cleared up!
Dec 09, 2008 | Epson Stylus 880 InkJet Color Printer
Kirby ultimate g
Vibrating – that usually happens on some short fiber or very dense carpets. When nozzle goes against the carpet fiber Kirby starts jumping. Try vacuuming the same place while facing opposite way.
Belt – red arrows means DISENGAGE. When you install the nozzle on the Kirby unit while green arrows match you will not be able to turn it on red. You must follow sequence (starting from nozzle off the Kirby, green arrows match, Kirby front lifter all the way up by pressing one of the pedals):
1. Turn Kirby knob to match red arrows. You will feel some tension and hook inside of the nozzle is supposed to catch the belt and stretch forming a loop for the Kirby shaft.
2. Put the nozzle on the Kirby and lock it on with the latch.
3. Twist the knob back to match the green arrows. YOU ARE DONE
Go to GoodVac.com Kirby vacuum online manual. There are some small details that you may want to pay attention to if you have removed the brush roll to install a new belt. Also there are some pictures that will help you understanding the process.
Sep 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Epson Stylus 880 InkJet Color Printer Logo
114 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
