Question about Philips GoGear HDD6330 MP3 Player
My charger doesnt work what i do to solve this
    President:
  • 2,923 Answers
First, try to isolate the problem to make sure that the charger is defective.
Try using a known working charger and see if your device will charge. If it does, then buy another charger. But if not, slowly wiggle the charger connector and see if the power jack is loose.
If you find out that the power jack is loose, try to use a long nose pliers and turn the power jack clockwise to tighten it.
Good luck and have a great day!
Posted on Feb 07, 2010
Kyocera mita km-5530 error C5100 How can I solve this problem
Main charger problem MC ALM signal is detected continuously for 400 ms when MC REM signal is turned on.
The main charge corona needs to be cleaned or replaced. If that doesnt work then its an High Voltage Power Issue
Jan 19, 2016 | Kyocera Office Equipment & Supplies
Dell inspiron battery will not charge
It could actually be the charger. Some chargers do allow the laptop to power on but are not able to charge the battery. Try a replacement charger as it maybe this thats at fault. If this doesnt solve it then the chargeback circuitry on the laptop could be faulty and require repair.
Hope this helps
Leon
Feb 09, 2013 | Dell Inspiron Computers & Internet
My E system 3086 ust stopped coming on what coud be the problem thecharger looks oky
Well if the charger looks ok, it doesnt necassarily mean it is, my friend had this problem, what we had to do was test the charger in another laptop to see if it works,in their case the charger was broken, but it may also be that the hole that you put the charger into is broken, have a close inspection of it, to see if anything is out of place, if that doesnt work you may want to consider buying a replacment charger, if that doesnt work you can always get a refund on it. notebooks generally have these power issues, try pushing the charger in fairly hard and keeping the pressure on it, does this cause the charge light to come on? if it does it means that the hole is broken and needs to be repaired.
Mar 30, 2011 | Toshiba Satellite A60-S1591ST Notebook
My phone reads the charger, but it reads it as a USB? doesnt charge and says insert battery, but its there.
Did this just start happening, did it work before or is this a new charger, is it an AT&T charger or a 3rd party charger? You need to provide more info, but the most common cause of the problem you report is that the phone thinks you have a SYNC USB cable attached, not a CHARGE USB cable. This is a problem with many phones and can often be solved with a mini-USB-B to mini-USB-A adapter. This is often supplied, usually as a right angle adapter in universal charger kits. Otherwise, get the OEM charger. Hope this helps. If not, repost with more details.
Feb 24, 2011 | AT&T Quickfire Cell Phone
Sony Vaio VGN-FS315E......At first the laptop could not detect the battery, so i was using the charger only but with the battery inside for sometime.I switched it on one morning and the laptop went of...
The battery might be damage for the time of use or maybe you put in a inadecuate space, the computer works perfectly without the battery but if it doesnt occure and the computer dont works with out the battery and the charger dont supply the energy of the pc maybe you can try with a new battery and a new charger if it doesnt solve the problem your internal hardware is damage or your software is corrupted or damage too.
Oct 11, 2010 | Sony VAIO VGN-NR430E/S NoteBook
My phone is not charging
If your phone is not charging, try use a similar charger to charge to see if it is charger problem, if the similar charger did not charge your phone, it means the problem is the charging port on your phone.
The charging port of your phone is bad and will need to be replace. Replace the charging port on your phone to solve the problem of your phone not charging.
Once the charging port is replaced, the not charging problem with your phone solve.
Take care.
Jul 23, 2010 | Sony Ericsson Walkman® W880i Cellular...
New battery will not charge on inspiration 6000 works fine when plugged in?
a hundred to 1 your chrger is ****. Though it will still keep it powered on....it doesnt have enough connection to give it a full charge. I had this same laptop and with the same problem. go to ebay and buy a new charger for 15 bucks and your problem is solved. In the future always try the charger first ...they are always cheaper than a new battery!
Mar 13, 2010 | Dell Inspiron 6000 Notebook
Hp compaq nc6320 doesnt charge
i thibk the charger head went out thats what happend to my gateway just cut the part of the charger that goes into the computer (if its not the prob u can fix it back later) cut it open and see if any of the wire has broke off if so use a soutering iron (i dont know how to sourtering)
and some souter and souter it back on thats the best i can help
ps i done this to my gateway labtop and it worked fine
Oct 02, 2009 | HP Compaq nc6320 Notebook
The charging light doesnt come on anymore and it doesnt charge. I tested the charger and it works just fine, what is the problem?
When a battery gets charged over and over again it will lose its effectiveness. My best guess is the lithium battery is dead. A replacement battery should solve your problem. All the best!
Greg
Jun 06, 2009 | Philips Magnavox MPD845
My sidekick 3 doesn't turn on
well i had the same problem but i solved it by taping the charger to the device in an upright fashion it will glow brighter orange and that means its charging duct tape works best
Aug 08, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Philips GoGear HDD6330 MP3 Player Logo
88 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
