Question about Microsoft Premium System for Xbox 360
3 red flashing lights on xbox360 - Microsoft Premium System for Xbox 360
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 364 Answers
XBOX 360 Red Light error, or Red ring of Death RORD is a very common issue, and can happen anytime. There are different Error numbers related to RoRD, and appears on screen starting with "E".
Red light problem can be fixed! there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console. Please feel free to message me if you need further assistance click here
Posted on Dec 19, 2010
  • 28 Answers
General Hardware Failure
usually caused by the E-73 Error from defective X-Clamps/Heatsinks
Posted on Feb 07, 2010
I have 3 flashing red lights on the console and a yellow light on the power supply
3 red flashing lights is known as the red ring of death. Your power supply showing a yellow light is ok, that just means that your power supply is on standby. The first thing you should do is check with microsoft to see if your unit is still under warranty with this site: http://support.xbox.com/support/en/us/xbox360/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/xbox360/registerdevice.aspx?step=repair
If your unit is not under warranty, go to www.wiredextreme.com. We are a console repair company based in Texas, and we can fix your console. We give a free diagnoses on your unit(excluding shipping), and will call with an estimate before any work is done on the unit. All our work is covered by a 90 day warranty, and you can buy up to 4 years worth of warranty coverage.
Nov 16, 2009 | Microsoft Xbox 360 Console
Red flashing lights ,3 flashing red lights ,when we turn it on.
this looks like a useful page to diagnose your problem:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Oct 29, 2009 | Microsoft Xbox 360 Console
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
Xbox360 e74 error
Section 4 is flashing red
- Hardware Failure
Jun 06, 2009 | Microsoft Xbox 360 Console
Red lights flashing
3 Red Flashing lights problem is one of the most common problem of Xbox 360. You will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Dec 25, 2008 | Microsoft Xbox 360 Console
RED LIGHTS FLASHING
Check the cable leading to the TV is plugged in securely both ends. If it is, it is probably a faulty cable, and you will need a new one.
May 27, 2008 | Microsoft Xbox 360 Console
Red lighted
if its 3 red lights it has to be sent in for repair
Jan 17, 2008 | Microsoft Xbox 360 Console
My xbox 360 not on ,its flash red light
http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Dec 17, 2007 | Microsoft Xbox 360 Console
4 FLASHING RED LIGHTS
4 red lights is not necessarily a hardware failure or ring of death. The cause is usually from AV cable not being detected or not connected correctly. The Eraser trick is good for Error 0102 make sure which error number you have! Suggested Solutions: 1. Try to connect and disconnect the cable and see if it makes any changes on the red lights status. Note that not inserting the AV fully will cause the 4 lights error to appear. 2. Make sure the AV Cable and the connector in the Xbox console are proper and there is nothing banded or twisted. 3. Try to connect it to a different monitor maybe this is where the problem is. 4. Find the metal area where it plugs into the console this is called the AV Pack metal area. Use a dry, lint-free cloth and wipe it. Then try to plug the AV again. * If you still can't make it to work and you have your warranty just send it in. If you don't have warranty I suggest trying the live chat support on Fixya!
May 26, 2007 | Microsoft Xbox 360 Console
Microsoft Premium System  for Xbox 360 Logo
71 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
