I tried to backup my Hard drive last night and during the backup at approximately 87% through it an error 'a disc error was found - insert new disc ' was displayed. My problem is that I could not remove the existing disc to insert a new one. The only way I found to remove it was to cancel the backup. I thought I had a bad disc so I tried the backup again - the same thing happened. I formatted the discs first then ran the backup. I am using MEMOREX CD-R discs 700MB. Can you help me? Barbara Sweeney
    President:
  • 3,278 Answers
Hello, Barbara.
You don't need to format the discs first. If fact, I wonder if the formatting may have caused problems.
Test your CD-R discs and disk drive by just trying to copy a file. If it works OK, you won't be able to use that disk again, since it's a CD-R.
If a simple copy doesn't work, then either you have a bad batch of CD-Rs or your disk drive is faulty or needs cleaning (use a disk head cleaner).
Also, try updating your backup software.
Hope this helps.
Posted on Feb 07, 2010
Error is no hard dis found
Replace the hard drive it is defective or unrecognized ,u can start the computer n hold f8 this should bring up the bios if not try f1 or f12 whichever brings up your boot sequence , then try inserting your recovery disc w the o.s on it in the drive and try booting from disk drive, from there you may be able to format disk and install new partition, this is a last attempt and may not work ,either way I'm afraid without expensive help retrieving your data will lost if this won't work
Nov 06, 2015 | Miscellaneous
Tip
Hard Disc Drive Troubleshooting and Repair
Troubleshooting Hard Disc Drives (HDD)
Hard drives don't last forever and they commonly fail.
Indications that your HDD maybe be failing or has failed
- S.M.A.R.T. error
-Error on computer start up saying no boot device has been found
-Any other windows error that states in the error it is HDD related
Now if your HDD hasn't totally failed and you can boot into windows the first thing you want to do is backup all your important files to some form of storage that is not on the affect HDD
Their is still some hope the problem can be fixed many times in one or two ways
1. windows built in disk repair tool chkdsk
-open a command prompt by typing cmd into a run window the shortcut to open a run window is windows key + r
in the command prompt type chkdsk /r this will scan your hdd for any errors and attempt to fix them
2. The second way to try and repair the drive is by using tools provided by the HDD manufacturer to be able to do this you need to:
determine the maker of your HDD by opening your computer and looking at the label on the disk
find the hdd diagnostic utilities on the drive manufacturers website you will have to do this on a working computer then burn it to a cd
then boot the affected computer off the cd you burned and running the provided diagnostic utility
If neither of these works I hope you were at least able to save the important data off the affected computer, and in the future keep backups.
In this case you will have to buy a new HDD and reinstall the operating system, drivers, programs
hoped this helped
regards
djbr1ck
on May 12, 2011 | Computers & Internet
I have an error code in the install operation tell me how to fix it
Common PS3 Error Codes and required Network Ports.
Additional PS3 Error Codes:
80010514 - Dead BD lens.
80010516 - Dead BD lens (happens at different occasions, code above is more common).
80710092 - Connection error (usually the connection is dropped), you will be signed out of PSN.
8002AD23 - Unidentified error (cause unknown), happens in Burnout Paradise (when game starts) and sometimes SARPBC.
8002A227 - PSN account suspended.
8002A212 - error returned by the PSN servers during authentication (invalid version).
80029945 - Can't playback burn BDr movie (error in picture above)
80029946 - Attempting to play burnt Dual layer NTSC disc on a Pal ps3
(workarouns is to transfer files to ps3 via TVersity)
(added 24th Sept 2007)
80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card) (added 15sept2007)
80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them) (added 04-sept-2007)
80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured (added 30thAug2007)
8003041F - An error occurred during the copy operation (using media server) (added27aug2007)
80010006 - An error occurred during the start operation (added 22aug07 - corrupted folding install)
80010007 - An error occurred during the start operation (added 17aug07 - during disc swap tests)
710102 - DNS Error; No DSN server available.
8013030 - System Error due to failed update download
80010001 - Major Error , Game ability stopped
80010017 - Can't start Blu-ray Game
80010510 - Will not play hard drive games - Cause unknown
80010516 - An error occured during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again
80029023 - Exchanging Key Information exchange has timed out
80029024 - "Cannot Obtain an IP address".
80029564 - Downloaded Game will not install - Cause unknown
80030920 - An error occurred during the copy operation. The file may be corrupt or there isnt enough memory. Try copying data from original source.
80031150 - System Settings Fail to Save - Possible Blue Screen "Setting information is corrupted.Pre
80031601 - Error Creating Account
80130203 - PS3 connects to internet but not to network - Typically means that the required ports are
80410418 - DNS Error
80710016 - Playstation Network is down.
80710092 - "An error has occured. you've been signed out from the ps network" -(connection dropped?
80710101 - Conneciton error
80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router
80710541 - The connection to the server timed out. press the x button to repair and restore default"
80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
8001050D - An error occured during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again
80028EA5 - Unknown?? User cannot connect to PS3 network. Sony told the user to send the machine in.
80028ea6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 mintues, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sycn.
Reconnect your power cable and flip the back swtich up again. Then make a new network connnection.
80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automactic,
80028f17 - Ps2 disc Boot Error , An error occured during the start operation; Ps2 game swapped using the eject function and then play pressed quickly -Backup ps2 game inserted again
80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).
80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it
80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error
80029C68 - Corrupt data usually on external device
8002A10D - Unable to Add friend in XMB
8002A4A6 - Cannot load game to play online
8002A515 - Error Signing in
8002A548 - Unable to remain logged in - either to game or server
8002A705 - Unable to connect to server/host. Check router port configuration.
8002a71a - Possible NAT Error , Can log onto Game Server but can't join game and can't host game
8002b241 - DVI has no audio
8002F994 - To many people downloading the update just sit back until the morning around 5am - 11am and you should be able to get it.
8002F997 - Trying to Update the Firmware, copying to a file and installing from a USB drive falied".
8003051E - Game will not Save
8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the conneciton drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only
WPA or none
8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security
8013030F - Check Router Page, SSID Broadcasting possibly off.
8013030F - Access Point not detected
80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.
807101FF - An error occurred during communication with the server. This is a DNS error This is a DNS error
8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back swtich and remove the
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond
80710D23 - Turn the PS3 off for a bit (30 minutes give or take) with the power toggle (not standby mode)
80029513 - Copyright Violation when attempting to install game
8003200D - Server side issue, much like the trophy syncing problems.
8001050F - System Clock Error.
8002A227 - You account has been banned, either temporary or permanently, (Check here for reason why you may have been banned).
80029780 - Unable To Activate System - You have reached the maximum downloads for an unactivated system. This will not affect systems that are already activated on your PSN account.
80010002 Invalid argument.
80010003 Invalid syscall number. A lot of the addresses in the syscall table at 0x2EB128 point to a function that only returns this value.
80010009 Operation not permitted.
8001002B Filesystem mounting failed.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
I have had to replace my hard drive on my pc how can i get my music back on to pc from my ipod and back into i tunes
Backing up your iTunes library to a CD or DVD To burn a CD (CD-R or CD-RW), your computer must have a compatible CD burner. To burn a DVD (DVD-R or DVD-RW), your computer must have a compatible DVD burner. Check in iTunes Preferences to see if a drive is compatible. See below for steps.
To create your backup disc
  1. Choose File > Library > Back up to Disc.
  2. Select the option you want from the resulting dialog and click Back Up.
  3. The two options you can select from are:
    • Back up entire iTunes library and playlists
    • Back up only iTunes Store purchases
    Whichever of these two options you choose, note that you can also choose "Only back up items added or changed since last backup" to perform an incremental backup.
  4. Insert a blank disc (CD or DVD) into your computer's optical drive. iTunes will scan the disc and begin burning.
  5. Note: If the disc you insert does not have enough space to hold all of the content you will be backing up, a dialog will appear asking whether you wish to backup to multiple discs. You can click Data Discs to continue.
iTunes burns the number of items that fit on one disc and then asks you to insert subsequent discs to continue burning the remaining files. Don't eject a disc while a backup is in progress.
Spoken programs purchased from the Audible.com website are not backed up.
Discs you create using the iTunes backup feature can be used only to restore; they can't be played in a CD or DVD player.
Restoring from a backup disc
  1. Open iTunes.
  2. Insert your backup disc.
  3. iTunes will ask whether you want to restore from this disc. Click Restore.
Check drive compatibility
  1. Choose a playlist on the left side of the iTunes window.
  2. Click the Burn Disc button on the bottom right corner of iTunes.
  3. If the drive is listed, it's compatible.
Aug 16, 2010 | Apple iTunes
Error loading operating system
What operating system? Windows? If so, what version? Linux? Mac?
It could be a corrupt system file or a corrupt section in the MBR of the drive. If you have critical data on the drive that needs backed up, then I recommend that you (from another machine of course) download a live cd version of linux to boot into along with an external usb hard drive. You can then mount your existing drive and copy your data to the external usb drive for a backup of data. I would recommend either PclinuxOS, Knoppix or Puppy Linux. Exit once backup is complete.
Next, boot your machine with either a restore disk received with the purchase of your computer, or if unavailable, boot to a system disk of your current operating system (such as windows xp, etc.). This MIGHT require a fresh install of the operating system - thus the reason for doing a backup of data first. If however, there is a bad sector in the drive's MBR then you're ultimately looking at replacement of the hard drive and then performing a restore or a fresh install of the operating system.
If you find this solution to be helpful, then please take a moment to rate this post. - Thanks.
Jun 19, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
NO disk error Exception Processing Message
if the usb drive when trying to access it says insert disc, the usb drive was not 2gb. if you can test it with "H2testW" google this.
if during test unit comes back as fake, there is one program that might work to restore it to correct specifications. good luck!
"PD V1.08 B3"
Jan 25, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have just purchased a HP 2133 mini-note. On first installation, installation failed and now it just loops and wont do anything. How can I facilitate first installtion bearing in mind there are no disks...
The majority of these PCs have a recovery partition on the internal hard drive, here is the instructions for using it.
Recovering information using Windows Recovery Environment (WinRE)
Windows Recovery Environment (WinRE) can perform a recovery from either an optional external hard
drive or from recovery discs.
CAUTION: Using Windows Recovery Environment (WinRE) will completely erase hard drive contents
and reformat the hard drive. All files you have created and any software installed on the computer will
be permanently removed. When reformatting is complete, the recovery process will restore the operating
system, as well as the drivers, software, and utilities from the backup used for recovery.
To initiate recovery using WinRE, follow these steps:
NOTE: This process will take several minutes.
1. If possible, back up all personal files.
2. Restart the computer, and then press f8 before the Windows operating system loads.
3. Select Repair your computer.
NOTE: The "Repair your computer" option is displayed only if the WinRE partition is intact. If the
option is not displayed, refer to “Recovering information using a Windows Vista operating system
DVD (purchased separately).”
4. Follow the on-screen instructions.
5. Click Next.
6. Select your user name, type your password (if applicable), and then click OK.
7. If you are using recovery discs, insert the last disc of the recovery disc backup set.
NOTE: Inserting the last disc of the backup set confirms the presence of a valid backup. If you
insert any other disc, the backup will not be recognized.
– or –
If you are using an optional external hard drive, connect it to the computer.
8. Click Windows Complete PC Restore.
9. Follow the on-screen instructions.
this is getting long , so ill will post more steps in comment.....
Nov 20, 2008 | HP Computers & Internet
Disk error searching for boot rercord from CDROM not found
Hi rmirish,
The hard drive has built in SMART diagnostics to check itself to make sure all is well. If the SMART is showing status BAD then the hard drive is either either starting to go out. Your best bet is to try to backup any data (if you have any) on the hard drive and replace the hard drive.
Hope that helps,
Take care,
Michael
Nov 17, 2008 | NEC Computers & Internet
Cd/dvd drive problem
Try with another brand of disk; the Matsushita UJ870 drive of our 5315 burn my Sony CD's but not my Philips CD's (my Compaq V2617LA with an older Matsushita UJ840 drive has burned Phillips CD's in the last two monts)... Remember: CD and DVD lassers are different. I think because of that, i haven't see problems with Sony, Philips and Samsung DVD's... only with CD's...
Jun 04, 2008 | Acer Aspire 5315 Notebook
Hard disc
try taking the harddrive out and put it back in or u may have to try a new hard drive
Nov 17, 2007 | Sony Playstation 3 (PS3) Console
22 people viewed this question
k24674
