Question about Acer Aspire 3000 Notebook
Acer Aspire 3000 notebook: 1) monitor displays horizontal random lines. This can be fixed by clamping the bezel to the lid, at the position of the lid release catch, using a bull-dog (spring) clip. It works, but obviously isn't a permanent answer. New screen and/or inverter indicated? 2) computer only works from the battery - about 1 hour's use from full charge. Battery charger charges the battery only when the computer is switched off and it isn't possible to run the computer using the charger - even if leaving the charger plugged in, power is supplied only from the battery. New battery/charger/something else? Suggestions welcome!
  • 457 Answers
Monitor: if the inverters were blown, you would be unable to use clamps as a workaround. I suspect a lose or broken contact to the display wafer caused by rough handling of the laptop. This is delicate stuff, you cannot repair without specialized tools and usually its simpler and cheaper to swap the panel for a new one.
Charger: try to remove the battery and connect the charger. Check if the laptop starts now. If yes, the battery probably reached its end of life and drains so much power during inefficient charge that the power supply has not enough extra strength to run the laptop on top. Only one hour of run time hints to a degraded battery, too.
Replace the battery with a new one and check if the problem persists.
If the laptop does not run with charger and without battery, the power regulation in the laptop is fried.
Since there is more than one defect already (replacement batteries are not cheap, too), you should consider to contact Acer repair services. In my experience they provide reasonable priced repairs; they give you a quotation for a small fee before they actually repair the thing, so you can decide how to proceed.
Check if they have a repair site in your vicinity. I went to Acer Hong Kong in 2005 with similar problems and a few days later picked up my machine, repaired to my satisfaction and with a full report what was wrong.
Posted on Feb 07, 2010
Testimonial: "Many thanks for the suggestions. Good advice and surprisingly quick, too. Keep up the good work!"
How to connect external monitor to aspire 3000
plug in the new monitor to the notebook, then right click background and then click properties. Then go to the settings tab, at the bottom of that click advanced. Next Click monitor. There you should see the external monitor for you can set the display to this one.
Oct 25, 2011 | Acer Aspire 3000 Notebook
I have a Acer Aspire 5100 and was working fine, until I came up to it and the display is very dim, you can see but can't control it with Fn brightness keys. The computer works fine if you connect a...
sounds very much like the inverter has blown. they are generally easy to replace and are usually positioned in the frame around the screen. You can get one here
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=2534
Apr 11, 2011 | Acer Aspire 3000 Notebook
I ave a problem with my acer aspire 3000 , I am not sure if it is a black screen because the windows runs normally in the left corner ( about 2 inch wide) I tried to reinstal the windows and it didn't...
That sounds like the display itself is faulty.
To check the display, plug in an external monitor, if the picture is complete, your display is probably faulty. Replace the display, (ebay). If the display is still faulty, the VGA processor may be faulty. Replace motherboard/notebook.
Feb 06, 2011 | Acer Aspire 3000 Notebook
Acer Aspire 3003 wlci laptop. Uses Aspire 3000 display. Problem: part of the display has a black bar on the screen. You can still see through it though. I hooked up the laptop to an external monitor. No...
i think you have the ability to check your laptop and the only i can suggest to you is you have to check the backlight section of your laptop cause there might me cold solder parts that cause the dark side of your screen.
Oct 05, 2009 | Acer Aspire 3000 Notebook
Monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
LCD screen looks like bad TV reception
if the display returns to normal when you press the bezel at on end means there is a bad connection to the inverter behind the bezel itself or the inverter is ready to give up the ghost.
you can attempt to dismantlethe laptop and remone the lid or in some cases just unscrew the bezel and remove the plastic cover, the inverter is at the bottom of the display you can't miss it
hope this helps
regards
Nov 18, 2008 | Acer Aspire 5601WLMi Notebook
Lcd display
Try connecting your laptop to an external monitor.Connect it with a vga cable to your monitor and press Fn+ monitor key(I don't know what it is for acer) to switch displays.If there are no lines on the external monitor then the problem is due to the notebook lcd.If there are lines then it is due to a driver.Reinstalling the driver should fix that then.
Aug 24, 2008 | Acer Aspire 4315 Notebook
Display has lines that run through it
they can be horizontal. I think your graphics card on your motherboard is bad. you should consider sending it to acer so they can replace it with a new one.
May 18, 2008 | Acer Aspire 3000 Notebook
Acer 5100, Lines throughout screen!!
connect to an external monitor, if it works fine then it is the monitor, if not its the video card.
Dec 11, 2007 | Acer Aspire 5100 Notebook
Acer aspire 3000 display problem
i think its ur video card that has a problem.. try bringing ur laptop to the company of yuor laptop 2 fixed your problem.. hope it can help
Nov 07, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
166 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
