Culligan Sediment Water Filter Logo
Posted on Feb 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My water softener is inoperative and is displaying ''E1'' in the status window.
Anonymous
Level 3:
  • Master 10,319 Answers
  • Posted on Feb 07, 2010
Anonymous
Master
Level 3:
Answers
10319
Questions
5
Helped
3075526
Points
30576
E1 IS FOR MOTOR WILL NOT STOP TURNING
E2 IS FOR MOTOR WILL NOT TURN
E3 IS FOR WRONG POSITION
Beerm0nster
Level 2:
Sniper:
  • Expert 82 Answers
Beerm0nster
Expert
Level 2:
Sniper:
Answers
82
Questions
0
Helped
81485
Points
230
Two possible ways to resolve this:
1. (the easiest to try first) - Unplug the unit from the electrical supply for 20-30 minutes and then restore power. This may clear the error code.
2. The error normally means that the motor has encountered some form of resistance - i.e. a blockage of debris in the piston seal inside the valave or possibly it could be due to a microswitch not activating correctly which could cause the piston to stop in an incorrect position. This would normally be a job for the service team; however if you are feeling that you want to tackle this yourself you could refer to the diagram in the user manual to disassemble the unit and investigate further. In all liklihood a clean may well fix the issue
If this helps, please leave feedback
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5468
Points
My platnium culligan water softner is flashing "Aqua Sensor" and is beeping because it missed a rinse. What can I do to try to get it to stop beeping and maybe resetting it
Anonymous
Level 1:
New Friend:
  • Posted on Apr 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5468
Points
A flashing 12 on display
1 Related Answer
Anonymous
  • 8 Answers
  • Posted on Jul 21, 2010
SOURCE: water softener is inoperative and is displaying E1
Usually, an E1 error code means the circuit board is bad. Try unplugging the unit for 5 minutes. Upon plugging it back in, if it does not reset itself, that means you need a new board. It is really easy to replace ( just a few wires) and will cost around $160.
2005 trail blazer-power windows won't work and a/c only blows from the bottom
All the power windows are inoperative ?
Power Window System Components
The power window system consists of the following components:
Driver door module (DDM)
Passenger door module (PDM)
Body control module (BCM)
LR power window switch
RR power window switch
Window up and window down relays in each of the rear passenger window switches
Window lockout switch
Reversible power window motors in each of the doors (circuit breaker protected)
LT DOOR CB 25A (System power for left rear window)
RT DOOR CB 25A (System power for right rear window)
Are you aware of the electronics involved ? control modules - computers ? Are you good diagnosing electrical problems . Do you own a professional scan tool ?
  1. Install a scan tool.
  2. Monitor the Driver Window Status Data parameter in the driver door inputs list.
Does the Driver Window Status Data parameter display an active state?
Your best bet would be to take your vehicle to a qualified repair shop . For both problems .
The Trainer 24 Power Window Troubleshooting
3helpful
3answers
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
2answers
Error E1 for washing machine
AK Techno service is the best service center for repairing and service for all types and brands of washing machines.
For more visit our website. http://aktechnoservice.com/samsung-washing-machine-service-center-in-hyderabad
samsung washing machine service center in hyderabad...-bo0djorvxqfflml1tozu5o0f-5-0.jpg
Whirlpool ADG 8296 error code E1 F8
Check with one of the online "appliance parts" stores. Most likely they know the answer and can help with the part and it's replacement.
How to fix samsung washing machine model TORNADO 7.0kg WA90B error
-Display Shows 'E1'
Error E1 samsung washing machine model TORNADO 7.0KG WA90B
-Display Shows 'E1'
Keep me posted!
I have laars heater model ht 330. there is no hot water and the heater displays error code E1
E1 is only the first part of the error code. There should be one or 2 more digits being displayed, alternating with the "E1" display. Unless you provide the other 2 digits of the error code, I can't help you.
You can get the user manual for your boiler/water heater with the error codes from here:
http://www.blueridgecompany.com/documents/LaarsHT330.pdf
Please, get back to me if you need any more help
Alex
4helpful
2answers
E1 code comes up on the display, but how do you solve this? ...
E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages.
11helpful
Water softener is inoperative and is displaying E1
Top Culligan Measuring Tools & Sensors Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Culligan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
