Question about Home Security
What is error code 08 on my digimerge DHT304161 DVR
What is error code 08 on my digimergeDHT304161 DVR ? record and hard drive light are not lit. when i reboot i get the error 08 ?
  • 50 Answers
SOURCE: optical drive dvr k16a
1)uninstall the cd/dvd writing software and reinstall again.
2)check whether the source file is ok or not.Because,if it is corrupted then the message will be appear again.
Posted on Mar 14, 2009
  • 375 Answers
SOURCE: Can I get my recordings off a HD DVR with a damaged hard drive?
Sorry, no. Not unless you have a working unit you can put the faulty drive in, but as you say, it's faulty... by its nature a faulty drive isn't useable.
Posted on Aug 20, 2009
SOURCE: Dish 625 DVR recorder won't play recorded shows.
Hi I will be more than glad to assist you in this concern. First press the power button on the front panel of the receiver for 10secs. once you press it the receiver will turn off and it should turn on by itself, once it turns on by itself you will see attention 015, press the menu button on the upper left of the remote, once you see the menu button press 6, 1, 1 on the remote and it should show on the screen point dish, select on check switch, once u are on the installation summary screen, select on test and it should do a test of 1 of 3 or it depends on your sat orbital location that u have.. once its done, it will show the installation summary screen and you should see sat input 1 & 2 with port1 up to 2 or 3 depends on your sat orbital location, all the trans on the sat 119, 110 or 129 if you have should be ok and green. once you see that all ok, select done on the screen, and it will be back to point dish, select done again, and then cancel all the way out of the menu, it should show on the screen attention 015, let it finish until it download the programming guide, once its done it should show a tv pic. press the dvr button and access your recorded event, it should play the dvr event. if the problem still exist, unplug the power of the dvr from the power outlet for 1 minunte then plug it back again and it should acquire the sat signal and download the programming guide, once it shows a pic. press again the dvr button and access the recorded event. it should play the recorded event, just incase the problem still exist, check what will be the exact error msg, write it down in a piece of paper and please feel free to get in touch or you can call on 1-800-333-3474..in order to for the dish tech support replace the receiver, this is a dvr lost of function.
Posted on Sep 05, 2009
SOURCE: Funai VCR/DVD recorder DVR 2737. My -R discs
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
Posted on Oct 18, 2009
  • 56 Answers
SOURCE: I want to record to a external hard drive in order to take to Ira
If you have a dish network system as listed in post a DVR 625 this is NOT possible, it will only work with VIP series Dish Network recivers. and they must be used on teh same model reciever such as Vip 722, tranfer to EXT HD then Watch on another 722!
Posted on Nov 13, 2009
How do I fix a Digimerge security system keeps blinking and beeping and wont record?
Your hard drive might be defective and the beeping alarm is the warning that there is no device to record on.
Jul 21, 2014 | Digimerge Home Security
How do I fix my digimerge dvr problems?
You have an issue with your hard drive.
Jul 21, 2014 | Home Security
How do i reset password for h264 dvr
Hello, There are two things you can try, the default password for the system should be 000000. If that is not the password if you go into the System Menu under the "General" tab there will be an option that says Factory Defaults, this will reset the settings to the default and should remove any password that is in place, but be warned that this will possibly wipe the dvr.
May 08, 2014 | Digimerge H264 16 CHANNEL DVR WITH USB CMS...
Digimerge dvr stuck at 99%
there should be a settings in recording.. its either something like Linear or circular.. select circular and it will record over the earliest footage on a continuous loop.
Nov 09, 2012 | Digimerge Home Security
Need help please. I have a Digimerge DH200 DVR with one camera. I've set is up and can view my camera locally over the internet and on the CMS DH software. Now I need to view it remotely. I have a
I have the ame problem. also need help with email setup. digimerge will not help. horrible co. they say I have to pay a tech to come out. no support whatsoever.
Oct 12, 2012 | Computers & Internet
Need to recover data from DirecTV R15 DVR receiver hard drive
First, sorry for the delay in respoding to your post. I did notice that you had a prior question about the Power Supply on an R15 DVR. Does the unit have a manufacture code of 500(found on the right hand front Flip Door of the DVR)? If so, I might be able to help you in repairing the Power Supply. As far as I know, getting your DVR up and running again is the only way to watch your previously recorded programs. As far as retreiving programs from your old Hard Drive via other methods, I probably won't be able to help you there. When I had both of my identical DVR 15 500's apart for a parts swap to diagnos a failed Phototransistor(infra-red sensor for the remote control), I also tried to swap out the Hard Drives. This is what I found: When you swap a Hard Drive into another DVR, it won't play any of the programs previously recorded. However, if you record new programs on the swapped Hard Drive then they will be playable on this current setup. Now, if you swap the Hard Drive back to the original DVR it came out of, the programs will once again be accessible except for any that you might have recorded while the Hard Drive was in the other DVR. So, in conclusion, when programs are recorded on a particular DVR, it is encoded electronically to play back only in that DVR via communication from the Motherboard and the Hard Drive. I know, it sucks, but that is why I was asking if you are pretty sure the Power Supply is at fault. If so, I received info from this forum on how to fix the issue. Also, if the attempt fails, Ebay has some previously owned DVR's for sale and maybe you can get one for spare parts. Remember, the Power Board and Front Display Control Panel are the only interchangeable parts IF you want to view the programs on your DVR's Hard Drive. Let me know what your DVR does when you plug it in. That will go far in further diagnostics of your DVR.
Nov 28, 2011 | Directv Plus DVR DTV Receiver / 100-Hours...
I am attempting to repair a Digimerge VCE 308301 (the 8 channel network DVR system) The client is able to view the setup menu but unable to to get an output signal from the cameras. The system runs it is...
The problem did not have anything to do with the DVR (Digimerge VCE 308301). It did however, have everything to do with the cameras' power supply system.
First, I contacted the company's (Digimerge) tech department; and they were of no help since the DVR system is obsolete. There are no replacement/spare parts available; e.g. mainboard and daughter boards...and of course, they don't have schematic diagrams for the DVR either. And due to its obsolesence- there is no tech support. (It makes me wonder why, though, how security and electronic vendors can in good conscious sell this obsolete model DVR for $1,400 and upwards of $2,200.00 to the unsuspecting consumer/end-user.)
Since I was able to boot up the DVR system and access the BIOS menu; and considering that the screen was showing that it was in record mode- and the system BIOS was keeping the proper date and time, I believed that there was something else going on with the security system.
I contacted the customer and went out to their home- as I was about to hook up the cameras to each input behind the DVR- by happenstance, I checked the power supply panel to make sure that the power supply had been turned off (which the home owner failed to do). Having turned off the cameras' power supply, I then made all my camera hook-ups to the DVR. When I turned the power supply to the camera system on, I was able to get a video signal, hence a nice clear picture. I did check the voltage draw on each power terminal at about 12.5 vdc and a visual check on the infra- red led's on each of the security cameras were lit.
Problem solved, right!?...WRONG!
Several hours later, I received a call from the homeowner that his security system was not working again. The first thing I noticed as I pulled into the customer's driveway was that all the cameras' infra-red led's were out. I immediately placed my volt meter on the output side of the transformer at each of the cameras' power terminal- and waddya' know- I was barely reading over 1 vdc. Apparently- over time, the transformer starts to overheat and the voltage drops out. After it cools down though, the voltage resumes to 12.5vdc to power up the cameras.
This is my first experience working on a secuirty camera system so I hope this has been as much of a learning experience for you novices as it has been for me!
Oct 01, 2009 | Home Security
WE HAVE A DIGIMERGE 9 CHANNEL DIGITAL VIDEO RECORDER MODEL DGR109. ALL THE LIGHTS ARE ON AND NONE OF THE PUSH BUTTONS WILL REACT TO ANY FUNCTIONS ALSO THE MEMORY BOX SAY IT IS FULL.
if you can access the menu start by formatting the hard drive
here is a link to the manufacturers website they have manuals and most importantly updated firmware
http://digimerge.lorextechnology.com/cgi-bin/new_digimerge/index.cgi
Jan 30, 2009 | Digimerge DGR104000 Video Recorder
Error code 05
delete all recordings from hard drive unplug the receiver from the wall for 5 minutes and plug it back in, if 311 error message appears call dish network
Jul 27, 2008 | DISH Network DVR-625 DTV Receiver /...
Home Security Logo
83 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
