Question about LG KU990 Viewty
CHARGING PORT FAULTY..WHAT TO DO..REPLACED BATTERY AND CHARGER BUT FAULT SEEMS TO BE WITH THE PORT ITSELF AS THEY ARE VERY FLIMSY.
Took charger connector apart and soldered pins a bit thicker to make a tighter connection and now works fine !
Posted on Feb 08, 2010
Tip
Laptop not charging
Hello there,<br /> <br /> My dear friend, there are basically three things to check on this laptop if it tends not to charge. Which are the charger, the battery and the laptops charging connection port.<br /> <br /> You need to test them to find out which is faulty, it might be one of them or two or all. carry out the following test on them.<br /> <br /> Try to charge the laptop using another charger to see if that will charge it. If it charges it, then it means your charger is bad and need to be replaced. Then try to use your charger on another laptop to confirm if it truly is a problem with the charger. If the charger does not work, then all you have to do is to replace it with a new one, but if it charges, it means it is some other component that is faulty.If you charger is faulty, have it checked to know if it is a bad capacitor that needs to be replaced if it is not, then replace the charger with a new one.<br /> <br /> Next to test is the battery, if the laptop comes on when you plug the charger in, and the laptop works normally but as soon as the charger is disconnected it goes off, then it means the battery is bad and is not holding a charge. Try to insert the battery into another laptop to see if it will work there, then try to charge it there to see if it will hold a charge. If it does not, that confirms the battery problem and the solution to that is for you to replace the battery as there is not way to have it fixed.<br /> <br /> Then finally, the charging connection port, that sometimes gives a fault when there is a high voltage that hits the laptop when connected to the power supply. To confirm this, have a well tested charger connected to the laptop, to see if it will charge, if it does not charge that confirms it, but if it does, then it means the connection port is okay. But if it is not working, then it means the port needs to be replaced and that needs a very careful process for it to be repaired.<br /> <br /> Hope this was helpful to you.<br /> Goodluck<br /> Elect_Comp<br />
on Aug 10, 2011 | Computers & Internet
Why will the battery not charge?
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 27, 2012 | HP G60-120US Laptop
I have an Acer 7736Z the battery isn't charging. The BIOS on the acer support website give me version 2.10 which doesn't seem to match the directions given from previous questions and solution
To test the laptop:
http://www.chargerbuy.com/replacement-acer-aspire-7736-ac-adapter-19v-90watt.html
Nov 16, 2012 | Computers & Internet
Not charging
There are a few things you can try (you may have done some of them already):
  1. It may seem simple, but try plugging your charger into another outlet.
  2. Check the charging connector on the phone. Make sure that it's free of any dirt that could be blocking the connection to the charger.
  3. Buy another charger. If it doesn't help, return it afterward.
  4. It could be the battery itself that's dead. You could try looking for a replacement battery, but that may be harder to return if it doesn't help. You could also try taking the battery out, and then plug in the charger... some phones (very few) will work without the battery, but this will tell you right away if it's the battery.
  5. The charging port on the phone itself could be loose. Try jiggling it with the charger connected to it.
  6. The charging port could be dead or there could be some other type of electrical issue with the phone (water damage, maybe, or something else).
Hopefully this helps. Good luck.
Mar 02, 2011 | Sanyo SCP-2700 Cell Phone
Charging fault
Phone not charging.
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 31, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
My battery wont charge on my motorola rival i bought a new battery and it still wont charge.
If your phone does not seem to charge. It is as a result of either the charger or the charging port.
To test if it is the charger;
Try to use a tested okay charger on your phone.
Try your charger on another phone to see if it would charge the phone.
If it does not work,then it is the charger.
All you have to do is to replace the charger.
Test if it is the charging port;
Try to use a tested okay charger on your phone,
If it does not charge the phone,
Then it is the charging port that has a fault.
To fix the charging port;
  1. get the appropriate screwdriver,
  2. remove the back cover, the battery and the sim,
  3. Then you will remove the stickers, you will find some screws at the angles of the phone, unscrew them,
  4. Run an object like a credit card around the line across the phone and apply a little force to separate the stainless part of the phone,
  5. You will have access to the panel of the phone,
  6. Try to locate the charging port of the phone,
  7. Disconnect it and replace it with the new you got for it,
  8. Reverse the process to reassemble the phone.
Take care
Jun 21, 2010 | Cell Phones
Batteries won't charge
Hi. Sounds like there is a faulty connection somewhere between the charger and the batteries. Are the batteries connected correctly. The charger uses the voltage level in the batteries to regulate itself. If there is a faulty connection, then the charge will not operate. Use a multi-meter to check if the batteries are connected correctly. There should be 24 to 26 volts across both batteries.
This fault can also be caused by a faulty charger socket. Check for any signs of melting or heat damage. There might also be a disconnected wire in the plug on the charger itself.Good luck. Neil.
May 29, 2010 | Drive Medical BLUE 3 Wheel Compact Mini...
Charging problem
I think the charging port is bad and this could be as a result of factory error since the fault is not from you. The phone restarts probably because the charging ports is bridging.
I will advice that you purchase a desktop charger that will enable you charge the battery seperately and when the battery gets full, you insert it into the phone. You could get another battery so that while you charge one, you use the other.
Or if you can look for a repairer, that will help you fix the fault of your phone.
Best wishes
Nov 16, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
LG KU990 Viewty Logo
202 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
