Question about Technics SA-EX140 Receiver
Overload message in technics model SA- EX400P-K
    Genius:
  • 1,665 Answers
Get a manual for ex-140 here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000031494.pdf
or try ( i didnt check it) for ex-400 "Unsorted Technics Service Manuals" at
http://www.user-service-manuals.com/technics-service-manuals.htm
Posted on Feb 28, 2008
When I turn on unit, a message "overload" appears.
Check the speakers and the power supply for any signs of shorting.
This is due to the fact that the safety circuit works to switch off the set preventing a high damage.
So check the output for short or the presection .
Sep 28, 2010 | Technics SA-DX940
Technics SA-AX7 OVERLOAD problem
hello there are 2 big capacitor behind the metal heatsink see if one has swelled up if so change them both then check the output chip to see if there are any dry joints then when you've check all and still the same then you may have to change the output transistor g ood luck
shaun
Oct 01, 2009 | Technics SA-AX7
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Overload signal
The overload is the same as protect mode. Remove the speaker wires and turn the unit back on. If the message remains, there is a problem internal to the unit in the final stage of the amp.
Please let me know the results of the test above.
Thanks,
Dan
Mar 02, 2009 | Technics Audio Players & Recorders
Overload message in technics model SA- EX400P-K I have an older Technics system. It has worked great for years but now I get overload whenever I turn it on. Have changed speaker wires but no use. Any...
The overload message is the old version of "protect" mode. This means that a problem has been detected in the output amp section and that section is shutdown to prevent further damage. Your unit uses amp-pacs. One or more are bad. These are marked RSN3305P and cost about $66 each.
Dan
Jul 15, 2008 | Audio Players & Recorders
"OVERLOAD" message-Technics SA-AX730
You can't do it yourself only a good technician or repair center.I don't know the fix it cost.
Jul 07, 2008 | Technics SA-AX730 Receiver
Receiver overload problem
The overload message is indicating that a problem was found and the system is shutting down the output section to prevent further damage. There are probably poor connections on the main board and failing capacitors in the front end. Expect a parts vcost in the $10 range. Add in the local labor rate for the total repair bill.
Dan
May 23, 2008 | Technics SA-DX930 Receiver
Overload on Technics SA DA10
Cracked solder joints due to excessive heat cycling. Do not place in a shelf system. Top MUST be open for 1 ft. or better for proper convective cooling effect. Mine suffered same fate but repaired locally.
Feb 23, 2008 | Technics SA-DA10 Receiver
"Overload"
Check your wires for cross polarity
Dec 20, 2006 | Technics SA-DX940
Technics SA-EX140 Receiver Logo
1,080 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
