Question about Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5
Parts and service manual for ingersoll compressor t30
I'm trying to renove an ingersoll compressor t30 3"&1-3"/4 x2-3"/4 model 234.
The serial number is 8802263. I have ordered a seal kit, valve finger for the full unit but some seals do not fit one cylinder head (the "small cylinder" => is there different T30 models?
I received a plate with 2 valves on it but this cylinder use 2 separates valves...
Do you know where I can find the parts and service manual for this compressor ?
Regards,
Daniel
4 Suggested Answers
  • 76 Answers
SOURCE: Ingersol T30 won't shut off and blows pressure release valve
the wire juction box on your compressor has a pressure switch that may be wound in to tight take the cover off the box there should be a switch with a machine screw with nut and washer and spring back this nut off and see if that helps if you go to far you just crank it back in until the switch hit although it may be the other way around you may have to tighten to lower the pressure some of them are made that way if this does not solve your problem send me a picture of the switch and can solve it from there
Posted on Jun 26, 2009
  • 98 Answers
SOURCE: I need the head bolts torque specs for an
With Graphite gaskets the torque is 34 lbs.
Posted on Jul 21, 2009
  • 1388 Answers
SOURCE: How do I adjust shut off pressure on an Ingersoll
The best way to go about the task of adjusting the pressure switch is to remove the cover to switch and note the brand/model number. Sometimes instruction are under cover of switch. With switch information, look for mfg. instructions. You will most likely see one or two springs with lock nuts. Do not turn them yet. Most pressure switches are sold with factory adjustment and are sold in pressure ranges. For two stage compressors as yours, the pressure is usually factory set at much higher (150-175) pressures than single stage which is usually about 120 -125. If you change the pressure setting it will also change the differential cut on pressure. The factory will actually use different springs to achieve desired pressures and are color coded. There are too many different brands of switches to recommend how to change pressure setting. You may discover that you can only change the pressure just a small amount (+or -15-20psi ). If you find the information about your switch, make sure that you count the turns exactly so that you can return to factory settings if things go wrong. You can extend the life of the comperssor by lowering the pressure as more amperage /heat is produced to achieve higher pressures. Good luck
Posted on Sep 23, 2010
WILL T21 SELECT OIL WORK IN A MODEL 2475
The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
Jun 25, 2014 | Ingersoll Rand - Rand Type - 30...
SINGLE PHASE WIRING DIGRAM
You need a single phase motor to do that. A 3 phase motor cannot be made to run on one phase.
May 16, 2013 | Ingersoll Rand - Rand Type - 30...
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
Ingersol rand single phase t-30 compressor with twin cyl slow/ dragging
Quincy QT-5, with an 80 gallon tank. I was very patient and found this on CL. If you are flush with cash, do as you wish. If you are looking for the best bang for the buck, CL will produce!
X2 on the CL find....
Picked up a basically new Ingersoll Rand, T30 220v/2 stage for $500
Increase Engine Horse Power.
Jun 04, 2012 | Ingersoll Rand - Rand Type - 30...
Need to remove t30 2475 pump pully
Hi Mike,
Your problem is very simple please do he following.
1. Remove V-belt.
2. Loosen the lock nut of the compressor pulley.
3. Use a 3 jaw puller to pull-out the pulley.
3. Slowly tighten the puller and thats it.
Hope i can help in your problem,.
Apr 23, 2012 | Ingersoll Rand - Rand Type - 30...
I have just bought an old ingersol rand T30 A2955 it has a knocking noise I would like to investigate it further but would like to have a manual handy before I strip it down do you know were to get one...
T30 compressors have changed very little over the years. You can use practically any t30 parts list for an aid in looking at how things line-up.
The link below is pretty much what you will find. Your local ingersol rand repair center will have parts and service manual for your unit. Easy way to look into interior of the pump without tearing many gaskets is to remove cylinder at the base of the pump. Quite heavy so you will need a lift of some sort. Good luck with your repair.
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/SCD-749.PDF
May 30, 2011 | Air Tools & Compressors
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5 Logo
1,112 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
